Canon Support for 8 x 20 IS | Canon U.S.A., Inc.
8 x 20 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 10.17.19
File Size 1.56 MB
Type Prism Binoculars
Magnification 8x
Objective Lens Effective Diameter Approx. 0.79 in. / 20mm
Real Field of View 6.6°
Apparent Field of View 49.5°
Objective Lens Construction 3 elements in 2 groups
Eyepiece Lens Construction 4 elements in 3 groups
Exit Pupil Diameter Approx 0.1 in. / 2.5mm
Eye Relief Approx. 0.53 in. / 13.5mm
Prism Type Porro I prism
Eye Width Adjustment Approx. 2.2 – 2.83 in. / 56 – 72mm
Focusing Method Manual focusing by turning the focusing knob
Coating Super Spectra Coating
Closest Focusing Distance Approx. 6.6 ft. / 2.0m
Image Stabilizer Provided (Image Stabilizer button)
IS Compensation Angle +-0.9°
Amount of Adjustment for Difference in L/R Visual Acuity ±5.9 diopters
Power Source 1 lithium battery (CR123A)
Dimensions (W x L x H) Approx. 4.6 x 5.6 x 2.7 in. / 118 x 142 x 69mm
Weight Approx. 14.82 oz / 420g (excluding batteries)
Canon Image Stabilized Binocular Limited Warranty
The Limited Warranty set forth below is given by Canon U.S.A., Inc. with respect to Canon Image Stabilized Binocular Products purchased in the U.S.A.
This Limited Warranty is only effective upon presentation of a bill of sale, warranty card or other valid proof of purchase.
This Canon equipment is warranted against defective materials or workmanship for three years from the date of original purchase.
Equipment covered by this Warranty will be repaired or replaced in the U.S.A. without charge by Canon Factory Service Centers and Canon Authorized Service Facilities.
When returning equipment for warranty service, the shipping charges must be prepaid and the equipment should be shipped in its original carton or box, or an equivalent, properly packed to withstand the hazards of shipment, and be fully insured.
A bill of sale, copy of this warranty card or other proof of purchase should be enclosed, as well as a description of the problem, etc.
Repairs will be made and the equipment will be returned, shipped at no charge.
This warranty covers all defects encountered in normal use of the equipment and does not apply in the following cases:
  1. Loss or damage to the equipment due to abuse causing deterioration, mishandling, accident or failure to follow operating instructions.
  2. If equipment is defective as a result of damage by water, sand, dropping, leaking batteries, etc.
  3. If equipment has been serviced or modified by other than our Authorized Agents.
  4. Malfunction resulting from the use of supplies such as case, straps, lens cap, batteries, etc.
  5. Damage resulting during shipment. (Claim must be presented and examined by the shipper.)
No implied warranty, including merchantability, applies to this equipment after the three year period stated above, and no other express warranty or guaranty, except as mentioned above, given by any person, firm or corporation with respect to this equipment shall bind the undersigned, some states do not allow limitations on how long an implied warranty lasts. So the above limitation may not apply to you.
Neither the undersigned nor any other person, firm or corporation is responsible for any consequential damages caused by the equipment. Some states do not allow the exclusion or limitation of incidental or consequential damages, so the above limitation or exclusion may not apply to you.
This warranty shall not extend to anyone other than the original purchaser of this equipment or the person for whom it was purchased as a gift.
This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
This warranty is given by Canon U.S.A., Inc., with respect to equipment purchased in the United States.
Canon U.S.A., Inc.
Should Service be necessary for this product, please call our Toll Free Number in the U.S.A.: 1-800-828-4040 or write to:
Canon Customer Relations
One Canon Park
Melville, NY 11747
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
