Canon Support for CanoScan 8000F | Canon U.S.A., Inc.
CanoScan 8000F
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
CanoScan 8000F Quick Start Guide
File Name
CanoScan 8000F Scanning Guide
File Name
SELECT ERROR CODE
WINDOWS
Products | Windows 7 | Windows 8 | Windows 10 | Windows 10s |
CanoScan 8000F | 1 |
Scanner Type | Flatbed, color and monochrome |
Scanning Element | Charge-Coupled Device (CCD) |
Light Source | Cold Cathode Fluorescent Lamp |
Scanning Mode | 48-bit internal/external, Grayscale - 16-bit internal/external, Black & White, Text Enhanced |
Max. Document Size | 8.5" x 11.7"; Film - 35mm x 12 frames (negatives), 35mm x 4 frames (mounted slides) |
Interface | USB 2.0 Hi-Speed |
Dimensions (W x D x H) | 11.2" x 19.5" x 4.2" |
Weight | 8.8 lbs. |
OS Compatibility | Windows® 98/2000/Me/XP, Mac® OS 9.0 - 9.x, Mac OS X v10.1 or later (classic mode), Mac OS X v10.1.3 (native mode) |
Software | CanoScan Setup CD-ROM****** Including: ScanGear® CS (Windows/Mac), CanoScan Toolbox (Windows/Mac), ArcSoft® PhotoStudio® (Windows/Mac), ArcSoft PhotoBase™ (Windows/Mac), ScanSoft® OmniPage® SE OCR™ (Windows/Mac OS 9.1 to 9.x, Mac OS X (classic mode)), NewSoft® Presto! PageManager® (Windows only) and NewSoft Presto! BizCard® (30-day trial version, Windows only); Adobe® Photoshop® Elements |
Power Source | 120V AC, 60 Hz |
Max. Power Consumption | 15 W (10.6 W standby) |
Operating Temperature: | 50° - 95° |
Operating Humidity: | 20% - 80% RH |
Warranty | 1-year limited warranty with InstantExchange program (subject to certain conditions and restrictions. See www.canontechsupport.com for full details.) |
† Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary. * Based on Canon Inc. testing, using Pentium 4, 1.7 GHz, 256MB RAM, using Adaptec DUO CONNECT. Scanning an approx. 8.5" x 11" image at 600 dpi. Results may vary. ** Available only when using 2400 dpi or less. *** Windows users only. **** Systems with Pentium® III or higher, Celeron® (566MHz or higher), AMD: Athlon™, Athlon MP, Athlon XP or Duron are recommended for optimal performance. ***** ScanGear CS driver (Plug-in compatible) and CanoScan Toolbox, quick scanning utility are available in Mac OS X native mode. ****** System requirements vary by application. |
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
