Canon Support for CanoScan FS4000US | Canon U.S.A., Inc.
CanoScan FS4000US
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Scanner Type | Desktop Film Scanner |
Scanning Element | Charged-Coupled Device 3-line color image sensor |
Light Source | Cold cathode mercury fluorescent lamp |
Scanning Speed | (Positives, at 500dpi/1000dpi/200dpi/4000dpi)*: 35mm: 6/12/24/48 seconds ; Advanced Photo System (IX240): 4/9/18/36 seconds |
Scanning Mode | 14-bit scanning for each color (RGB)/16-bit**, 8-bit output |
Optical Density Range | 3.4 in 24-bit mode; 4.2 in 42-bit mode |
Max. Film Size | 35mm: Color (Positives/Negatives), Monochrome (Positives/Negatives), Mounted slide film***, Filmstrip ****; Advanced Photo System (IX240): Color (Positives/Negatives), Monochrome (Negatives), Mounted slide film, Cartridge ***** |
Scanning Pixels | 35mm: 3,780 X 5,669 pixels; Advanced Photo System (IX240): 2,457 X 4,315 pixels |
Scanning Area | 35mm: 24.0 x 36.0 mm; Advanced Photo System (IX240): 15.6 x 27.4 mm |
Interface | USB1.1/SCSI-2; Connectors: USB connector x 1slot/SCSI half-pitch 50-pin (Use interface switch on bottom panel.) |
Dimensions (W x D x H) | 92 x 144 x 368 mm (3.6 x 5.7 x 14.5 inches) |
Weight | 2,400g (5.3lb.) |
OS Compatibility | Windows 98/98SE/2000 Professional/Me, Mac OS 8.6/9 |
Power Source | 100-240 Volts AC, 50/60Hz (switches automatically) |
Max. Power Consumption | Operating: 35W, Stand by: 12W |
* Scanning time only; data transfer and image showing times are not included. Scanning speed depends on the film. ** 16-bit output will be available in case of connecting with its supported software, such as Adobe Photoshop LE to be bundled. *** With Slide Mount Holder bundled. **** With 35mm Filmstrip Holder bundled. ***** With IX240 Film Cartridge Holder bundled. |
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
