Canon Support for Color imageCLASS MF820Cdn | Canon U.S.A., Inc.
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows NT
- Linux
SELECT ERROR CODE
WINDOWS
macOS X
ChromeOS
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
Products | ChromeOS |
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Printer Specifications
Printer Type | Color Laser |
Print Speed | Up to 36ppm color (letter)4 |
First Print Time | 9 seconds or less (letter)7 |
Printer Language | UFR II, PCL6(5c,XL), PostScript® 3™, PDF |
Print Resolution | Up to 600 x 600 dpi (1200 x 1200 dpi quality) |
Maximum Print Size | Up to Legal |
Duplex Print | Yes |
Print Modes | Poster, Booklet, Watermark, Page Composer, Toner Saver |
Print Memory | 1 GB (Shared) |
Copier Specifications
Copy Type | Color Laser |
Copy Speed | Up to 36cpm (letter) |
Duplex Copy Speed | Up to 36cpm (letter) |
Copy Resolution | Up to 600 x 600 dpi |
Original Type | Text/Photo, Photo, Text |
Halftones | 256 Levels |
Warm-up Time | Approximately 34 seconds |
First Copy Time | Black/Color: Approximately 5.9/7.4 seconds8 |
Recovery Time | Approximately 10 seconds |
Maximum Number of Copies | 999 copies |
Reduction/Enlargement | 25%, 50%, 64% 78%129%, 200%, 400% |
Zoom | 25 - 400% in 1% increments |
Copy Size | Platen: Up to Legal ADF: Up to Legal |
Copy Features | Frame Erase Memory Sort 2 on 1 4 on 1 ID Card Copy |
Copy Memory | 1 GB (Shared) |
Fax Specifications
Modem Speed | Up to 33.6 Kbps (Super G3)9 |
Fax Resolution | Up to 406 x 391 dpi |
Transmission Time | JBIG (approx. 3 seconds) |
Memory Capacity | Up to 512 sheets10 |
Speed Dials | 300 coded dials |
Group Dialing | 199 destinations |
Sequential Broadcasting | 310 destinations |
Duplex Fax | Yes |
Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
Fax Features | Dual Access, Remote Reception, PC Fax (TX only), DRPD, ECM, Auto Redial, Fax Archive |
Activity Reports | Activity Result & Activity Management |
pC Fax | Sending only |
Fax Forwarding | Yes |
Scanner Specifications
Scan Type | Color Contact Image Sensor (CIS) |
Color Depth | 24-bit |
Scan Resolution | Up to 600 x 600 dpi (optical) 9600 x 9600 (interpolated) |
Scan Size | Platen: Up to Legal ADF: Up to Legal |
Duplex Scan | Yes |
Compatibility | TWAIN, WIA |
Scan Features | Push Scan, Pull Scan |
Pull Scan | USB and Network |
Push Scan (Scan to pC) | USB and Network |
Paper Handling Specifications
Standard Paper Source(s) | 550-sheet cassette plus 100-sheet multipurpose tray11 |
Document Feeder | 50-sheet duplex11 |
Paper Output | 250 sheets (face down) |
Paper Weight | 16-38 lb. bond (cassette) 16-38 lb. bond (multipurpose tray) |
Media Sizes | Letter, Legal, A4, A5, B5, Executive, Statement |
Media Types | Thin, Plain1, Plain2, Plain3, Heavy1, Heavy2, Recycled1, Recycled2, Recycled3, Color, PrePunched, Bond Paper |
Envelope Types | Com 10, Monarch, DL, Custom(Min. 98.4 x 190.5 mm to Max. 216.0 x 355.6mm) |
Connectivity and Software Specifications
Standard Interface(s) | USB Device 2.0 High-Speed, 10/100/1000 Base-T Ethernet (Network) |
Mobile Functions | Canon Mobile Printing1, Apple AirPrint™2. Mopria™ Print Service3, Canon Mobile Scanning for Business12 |
Embedded Web Server (Remote UI) | Yes |
Web Browser Support for Remote UI | Microsoft Internet Explore 7.0 or higher, Safari 3.2.1 or higher |
Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6) |
TCP/IP Set of Application Services | Bonjour(mDNS), HTTP, HTTPS, POP before SMTP (IPv4,IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6) |
Network Management Protocols | DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4) |
OS Compatibility | Windows Server 2003, Mac® OS X 10.5.8 and up, Linux® Drivers available for download from www.usa.canon.com |
Bundled Software | Printer driver, Fax driver, Scanner driver |
Environmental Specifications
Power Consumption | During Operation: Approx. 500W Standby: Approx. 30W Energy Saver: Approx. 1W (wired) |
Typical Energy Consumption | 0.43kWh |
General Specifications
Dimensions | 20.1"(W) x 22.3"(D) x 24"(H) |
Unit Weight (without/with cartridge) | 94.8 lbs. (w/cartridge) 97 lbs. (w/o cartridge) |
Package Weight | Approx. 99.2 lbs. |
Cartridge Type | Canon Toner 034 CMYK (CMY Yields approximately 7,300 pages, Black/K Yields approximately 12,000 pages) *Yields based on ISO/IEC Standard |
LCD Display | 3.5" customizable touch-panel |
Duty Cycle | Up to 88,000 pages per month |
Security | IP Address Filtering, MAC Address Filtering, Native Secured Print, IEEE802.1x, SNMPv3, HTTPS, IPSEC, Department ID Management |
Languages | English, French, Spanish |
Warranty | 1 year limited onsite warranty13 (Extended warranty available) |
CANON imageCLASS SERIES ON-SITE PRODUCT LIMITED WARRANTY
Canon U.S.A., Inc. ("Canon USA") warrants the Color imageCLASS MF800 Series product and Canon brand options designed for use with the imageCLASS product (collectively, the "Product") to be free from defects in workmanship and materials under normal use and service for a period of one year after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider") to, without charge, repair or replace any defective part with a new or comparable rebuilt part. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as waste toner containers or paper, as to which there shall be no warranty or replacement.
Drums and toner bottles for the Product are covered by separate warranties. Accordingly, this limited warranty does not cover any drums and toner bottles for the Product, whether shipped with the Product or purchased thereafter.
Canon USA offers assistance for installation, operation and support* of the Product as follows:
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.usa.canon.com/support (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
If Canon USA's remote assistance above cannot fix your Product's malfunction, Canon USA shall schedule an on-site service call via a Service Provider, except where the malfunction involves a user replaceable item, in which case Canon USA will send you a replacement part with installation instructions. You will be responsible for installing the user replaceable items in your Product.
If on-site service is performed, and (1) the Product malfunction is not covered by this limited warranty, or (2) the applicable warranty period has expired or has not been sufficiently established by appropriate documentation, then you will be charged for such service at the then current service rates of Canon USA or the Service Provider.
This warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON USA, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
NEITHER CANON USA NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCAHSE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Click Here to download the Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
