Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 11.04.22
File Size 142.00 B
Software Development Kit
Product name Directional Microphone DM-E1
Type Back electret stereo condenser type stereo microphone
Directivity Sharp directivity (SHOTGUN: monaural)
Single directivity (90°/120° stereo)
Sensitivity -42 dB (1 Khz, 0 dB=1 V/Pa)
Frequency 50-16000 Hz
Output Impedance 550 O
Working Temperature Range 32104°F / 0-40°C
Working Humidity 85% or less
Dimensions (W x H x D) Approx. 1.57 x 3.31 x 5.12 in. / 40.0 x 84.0 x 130.0mm
Weight Approx. 3.88 oz. / 110g (main body only)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Firmware Notice: EOS RP: Firmware Version 1.5.0
Advisory Type
Date 07.23.20
Title Canon Support | Firmware Notice: EOS Rebel SL2: Firmware Version 1.0.1
Advisory Type
Date 11.27.17
Title Canon Support | Firmware Notice: EOS 5D Mark IV: Firmware Version 1.3.2 discontinued
Advisory Type
Date 06.02.21
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
