Canon Support for DP-V1710 | Canon U.S.A., Inc.
DP-V1710
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
Panel Type | IPS LCD panel |
Screen Size | 17.3 inch (43.8 cm) |
Aspect Ratio | 16:9 |
Resolution | 3840 x 2160 (8.3 megapixels) |
Active display area | Approx. 381.9 x 214.8 mm |
Pixel Pitch | 99 µm / 255 ppi |
Panel Driver | 8 bit for each RGB color |
Brightness (Standard) | 100 cd/m2 |
Viewing Angle (Up, Down, Left, Right) | 89° (contrast ratio 10:1 or higher) |
Surface Treatment | Anti glare coating |
Backlight Type | White LED, direct down type |
Power | Rated voltage: AC 100-240 V Rated frequency: 50/60 Hz DC 12 V Max. 10 A, XLR terminal |
Power Consumption | At Maximum Load (including change in brightness through aging): Approx. 140 W At Factory Shipment: Approx. 85 W |
Environmental Conditions | Operating Temperature and humidity: 0 to 40 °C (32 - 104 °F) (20 - 85 % RH no condensation), recommended: 15 - 30 °C (59 - 86 °F) Pressure: 700 - 1060 hPa Storage / Transporting Temperature and humidity: -20 - 40 °C (-4 - 104 °F) (20 - 85 % RH no condensation) 41 - 60 °C (105 - 140 °F) (20 - 30 % RH no condensation) Pressure: 700 - 1060 hPa |
Dimensions (Width x Height x Depth) | With stand and handle: Approx. 435 x 356 x 194 mm (17.1 x 14.0 x 7.6 in.) Display unit only, without protruding parts: Approx. 435 x 308 x 154 mm (17.1 x 12.1 x 6.1 in.) |
Weight | Approx. 17.6 lbs (8 kg) |
Mounting Hole Pitch | VESA standard 100 x 100 mm (3.9 x 3.9 in) |
6G/3G/HD-SDI | 4 (6G:2 pass-thru systems, 3G/HD-SDI: 1 pass-thru system) |
Display Port | - |
HDMI | 1(1 system) Type A terminal (4K 60P Support) Copy protection: HDCP 2.2 |
6G/3G/HD-SDI | 4(6G:2 pass-thru systems, 3G/HD-SDI: 1 pass-thru system) |
Headphone | 1 stereo mini-jack. Supported impedance: 32-64Ω |
USB | 1 USB A receptacle terminal. Universal Serial Bus Specification Revision 2.0 compliant LS (Low Speed) / FS (Full Speed) / HS (High Speed) mode compatible. Enhanced Host Controller Interface Specification for Universal Serial Bus Revision 1.0 compliant. |
LAN | 1 RJ-45 terminal IEEE802.3 10BASE-TX / IEEE802.3u 100BASE-TX compliant |
Remote | 1 RJ-45 terminal, GPI 8 pin |
Supplied Accesories | AC Power Cord, Instructional Manual, AC Power Cord Clamp |
Accessories | Protect Panel (PP-17U) Rack Mount Bracket (RB-02) |
CANON PROFESSIONAL DISPLAY LIMITED WARRANTY |
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to Canon Professional Display Equipment ('the 'Equipment') accompanying this limited warranty in the Equipment's original container, when purchased in the United States. This limited warranty is only effective upon presentation of your Bill of Sale or other proof of purchase. This Limited Warranty covers all defects encountered in normal use of the Equipment and does not apply in the following cases:
This Limited Warranty does not apply to Equipment purchased outside the United States. This Limited Warranty does not apply to accessories or consumables for the Equipment, which are sold "AS IS", without warranty of any kind by Canon USA. Please retain this warranty card and your Bill of Sale as a permanent record of your purchase. This card ensures that you are contacted promptly should there be a safety inspection, modification or product recall under applicable laws or regulations. This warranty gives you specific legal rights, and you may also have other rights which vary from state to state. |
Luminance Boost Service Upgrade
Thank you for using Canon products. Canon is offering luminance upgrades for its 17” reference displays. Interested parties can call our support centers to make arrangements for this service.
Overview
An optional license upgrade is available to increase the maximum luminance value of the Canon DP-V1710 and DP-V1711 reference displays from 300 to 600 nits.
Above images are simulated and do not represent the true white point/luminance values of DP-V1710 and DP-V1711 reference displays
Models
DP-V1710
DP-V1711
Pricing
The price of the upgrade is fixed: $1,000 per unit.
Contact Information for Inquiries | |
Canon Customer Support Center | |
Phone: | 1-855-4K-CANON, (1-855-452-2666) |
Email: | CinemaEOS@cits.canon.com |
For additional support options: pro.usa.canon.com/support |
Benefits
Calibration Services
This service supports both standard and high dynamic range (HDR) workflows, and ensures your device meets industry standard specifications (SMPTE, DCI, and ITU).*
What to Expect
Our Imaging Science Foundation (ISF) certified professionals will travel to your site to ensure that any calibration is tailored specifically to your viewing environment. During a calibration session, several key image quality elements will be measured including: white point, grayscale, primary and secondary color chromaticity, luminance and gamma.
Customized Service
For added flexibility, our team can perform calibrations on virtually any type of display technology. Whether it be a consumer grade PC monitor or professional reference display, our service helps ensure your panel is operating to the best of its ability.
Additionally, to remove any ambiguity of your display’s performance, clients will also be provided with detailed pre and post calibration reports.
Canon’s Color Calibration Service offers one-time calibrations, recurring service contracts, and customized training. For more information or to request a free consultation, please fill out the form below.
