Date 04.19.10
File Size 352 KB
Date 01.01.04
File Size 500.84 KB
Date 04.01.07
File Size 408.81 KB
Date 04.19.10
File Size 3.79 MB
Date 04.01.07
File Size 209.08 KB
Date 01.30.08
File Size 204.09 KB
Date 01.01.04
File Size 199.32 MB
Date 04.01.07
File Size 352.99 KB
Date 04.01.07
File Size 398.74 KB
Date 04.19.10
File Size 209 KB
Date 01.01.04
File Size 379.56 MB
Date 04.01.07
File Size 1.05 MB
Date 04.19.10
File Size 204 KB
Date 04.19.10
File Size 1.16 MB
Date 01.01.04
File Size 1015.63 KB
Date 04.01.07
File Size 3.79 MB
Date 01.01.04
File Size 500.84 KB
Date 04.01.07
File Size 1.17 MB
image icon
Camera Connect
image icon
image icon
image.canon
Power Supply (rated) 7.4 V DC (Battery); 7.2 DC (DC IN)
Power Consumption 4.4 W ( using viewfinder), 5.4 W (using LCD screen)
Television System EIA standard (525 lines, 60 fields) NTSC color signal
Video Recording system 3 rotary heads, helical scanning system DV system (consumer digital VCR SD/SDL system); Digital component recording
Audio Recording system PCM digital sound, 16 bit (48 kHz/2 ch, 12bit (32 kHz/4 ch); 2x SP and 3x SP: 12-bit only (32 kHz/2 ch.)
Image Sensor 1/4" Progressive Scan CCD (charge coupled device) 680,000 pixels (360,000 effective pixels)
Tape Format Videocassettes bearing the MiniDV mark
Tape Speed SP: 3/4 ips (18.81 mm/sec.); LP 1/2 ips (12.56 mm/sec); 2x SP: 3/8 ips (9.41 mm/sec); 3x SP: 1/4 ips (6.28 mm/sec)
Maximum Recording Time (with an 80-min. cassette) SP: 80 min; LP: 120 min; 2x SP: 160 min; 3x SP:240 min
Fast Forward/Rewind Time 2 min 20 sec (with a 60 min cassette)
Lens f/1.6-2.6, 10x power zoom, 3.5 -35.0mm
Focusing System TTL autofocus, manual focusing possible
Focusing System 3ft. 3 3/8 in. (1m); 3/8 in. (1cm) on maximum wide angle
Minimum Illumination 7.5 lux using the Low-Light program
Recommended Illumination More than 100 lux
Viewfinder 0.44 in. color LCD; (approx. 113,000 pixels)
LCD Screen 2.5 in measured diagonally (approx. 200,000 pixels)
Microphone Stereo electret condenser microphone
DV Terminal Special 4-pin connector (based on IEEE 1394)
Video Terminal 1 Vp-p/75 ohm unbalanced
S-video Terminal 1 Vp-p (Y signal) 0.286 Vp-p (C signal)
Audio Terminal Input level: -10 dBV/47 kohm, unbalanced; Output level: -10 dBV, less than 3 kohm, unbalanced
Operating Temperature range 32-104&deg F (0&deg - 40&deg C)
Dimensions 1 7/8 x 4 1/8 x 3 3/8 in. (48 x 106 x 86mm)
Weight 13 3/4 oz. (390g)
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
