Canon Support for EOS-1D Mark II | Canon U.S.A., Inc.
EOS-1D Mark II
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Type
Type | Digital AF/AE SLR |
Recording Media | Type I or II CF card, SD memory card |
Image Format | 28.7 x 19.1mm |
Compatible Lenses | Canon EF lenses (except EF-S lens) |
Lens Mount | Canon EF mount |
Image Sensor
Type | High-sensitivity, high-resolution, large single-plate CMOS sensor |
Pixels | Approx. 8.20 megapixels |
Total Pixels | Approx. 8.50 megapixels |
Aspect Ratio | 3:2 |
Color Filter System | RGB primary color filter |
Low Pass Filter | Located in front of the image sensor, non-removable |
Recording System
Recording Format | DCF 2.0 (Exif 2.21): JPEG and RAWRAW+JPEG simultaneous recording provided, Backup image recording enabled (Same image recordable on CF card and SD memory card) |
Image Format | JPEG, RAW (12-bit) |
File Size | (1) L (Large): Approx. 2.8 MB (3504 x 2336 pixels)(2) M1 (Medium1): Approx. 2.2 MB (3104 x 2072 pixels)(3) M1 (Medium2): Approx. 1.7 MB (2544 x 1696 pixels)(4) S (Small): Approx. 1.0 MB (1728 x 1152 pixels)(5) RAW: Approx. 8.3 MB (3504 x 2336 pixels)JPEG quality: 8.Exact file sizes depend on the JPEG quality, subject, ISO speed, etc. |
Folders | Folder creation/selection enabled |
File Numbering | (1) Consecutive numbering(2) Auto reset(3) Manual reset |
Color Space | Five standard types plus two types that can be registered with color matrix |
Interface | IEEE1394 for personal computers; USB for direct printing; Video output (NTSC/PAL) |
White Balance
Settings | Auto, daylight, shade, cloudy, tungsten light, fluorescent light, flash, custom, color temperature setting, custom white balance (Total 10 settings) |
Auto White Balance | Auto white balance with the image sensor |
Color Temperature Compensation | White balance bracketing: ±3 stops in full-stop increments, White balance correction: ±9 stops in full-stop increments*Blue/amber bias or magenta/green bias possible |
Viewfinder
Type | Eye-level pentaprism |
Coverage | Approx. 100 percent vertically and horizontally with respect to the effective pixels |
Magnification | 0.72x (-1 diopter with 50mm lens at infinity) |
Eye Point | 20 mm |
Dioptric Adjustment Correction | -3.0 - +1.0 diopter |
Focusing Screen | Interchangeable (9 types), Standard focusing screen: Ec-CIII |
Mirror | Quick-return half mirror (Transmission:reflection ratio of 37:63, no mirror cut-off with EF 1200mm f/5.6 or shorter lens) |
Viewfinder Information | AF information (AF points, focus confirmation light), exposure information (shutter speed, aperture, manual exposure, spot metering circle, ISO speed, exposure level, exposure warning), flash information (flash ready, FP flash, FE lock, flash exposure level), white balance correction, JPEG recording, number of remaining shots, memory card information |
Depth Of Field Preview | Enabled with depth-of-field preview button |
Eyepiece Shutter | Built-in |
Autofocus
Type | TTL-AREA-SIR with a CMOS sensor |
AF Points | 45 AF points (Area AF) |
AF Working Range | EV 0-18 (at ISO 100 at 20°C/68°F) |
Focusing Modes | One-Shot AF (ONE SHOT); AI Servo AF (AI SERVO); Manual focusing (MF) |
AF Point Selection | Automatic selection, manual selection, home position (switch to registered AF point) |
Selected AF Point Display | Superimposed in viewfinder and indicated on LCD panel |
AF Assist Beam | Emitted by the dedicated Speedlite |
Exposure Control
Metering Modes | 21-zone TTL full aperture metering(1) Evaluative metering (linkable to any AF point) (2) Partial metering (approx. 13.5% of viewfinder at center) (3) Spot metering Center spot metering (approx. 3.8% of viewfinder at center)AF point-linked spot metering (approx. 3.8% of viewfinder)Multi-spot metering (Max. 8 spot metering entries)(4) Center weighted averaged metering |
Metering Range | EV 0-20 (at 20°C/68°F with 50mm f/1.4 lens, ISO 100) |
ISO Speed Range | Equivalent to ISO 100-1600 (in 1/3-stop increments), ISO speed can be expanded to ISO 50 and 3200 |
Exposure Compensation | AEB: +/-3 stops in 1/3-stop increments. Bracketing methods:1. Shutter speed or aperture2. ISO speed, Manual: +/-3 stops in 1/3-stop increments (can be combined with AEB) |
AE Lock | Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved. Manual: By AE lock button in all metering modes. |
Shutter | Electronically-controlled focal-plane shutter1/8000 to 30 sec. (1/3-stop increments), bulb, X-sync at 1/250 sec.Soft-touch electromagnetic release10-sec. or 2-sec. delayRemote control with N3 type terminal |
Type | Electronically-controlled focal-plane shutter |
Shutter Speeds | 1/8000 to 30 sec. (1/3-stop increments), bulb, X-sync at 1/250 sec. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. or 2-sec. delay |
Remote Control | Remote control with N3 type terminal |
External Speedlite
EOS Dedicated Speedlite | E-TTL II autoflash with EX-series Speedlite |
PC Terminal | Provided |
Drive System
Drive Modes | Single, low-speed continuous, high-speed continuous, self-timer |
Continuous Shooting Speed | Low-speed continuous: Approx. 3 shots/sec. High-speed continuous: Approx. 8.5 shots/sec. |
Maximum Burst | JPEG: Approx. 40 shots (Large, JPEG 8) RAW: Approx. 20 shots |
LCD Monitor
Type | TFT color liquid-crystal monitor |
Monitor Size | 2.0 in. |
Pixels | Approx. 230,000 |
Coverage | 100% with respect to the effective pixels |
Brightness Control | Five levels provided |
Playback
Display Format | Single image, single image (INFO.), 4-image index, 9-image index, magnified zoom (approx. 1.5x - 10x), rotated image |
Highlight Alert | In he single image and single image (INFO.) formats, any overexposed highlight areas will blink in the image display. |
Image Protection and Erase
Protection | Erase protection of one image, all images in a folder, or all images in the memory card can be applied or cancelled. |
Erase | One image, all images in a folder, or all images in the memory card can be erased (except protected images). |
Sound Recording
Recording Methods | The voice annotation recorded with the built-in microphone is attached to the image. |
File Format | WAV |
Recording Time | Max. 30 sec. per recording |
Power Source
Battery | One Ni-MH Pack NP-E3 AC power can be supplied via the AC adapter and DC coupler. |
Number of Shots | At 20°/68°F: Approx. 1200 At 0°C/32°F: Approx. 800 The above figures apply when a fully-charged Ni-MH Pack NP-E3 is used. |
Battery Check | Automatic |
Power Saving | Provided. Power turns off after 1, 2, 4, 8, 15, or 30 min. |
Back-up Battery | One CR2025 lithium battery |
Dimensions and Weight
Dimensions (W x H x D) | 6.1 x 6.2 x 3.1 in. / 156 x 157.6 x 79.9mm |
Weight | 43 oz. / 1220g (Body only. battery: 11.8 oz. / 335g) |
Operating Environment
Working Temperature Range | 0° C- 45° C / 32° F - 113° F |
Working Humidity Range | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
CONTACT US
