Canon Support for EOS 60DA | Canon U.S.A., Inc.
EOS 60DA
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | High-sensitivity, high-resolution, large single-plate CMOS sensor |
Pixels | Effective: Approx. 18.0 Megapixels: 5200 (H) x 3462 (V) pixels |
Total Pixels | 19.0 Megapixels: 5432 (H) x 3492 (V) pixels |
Aspect Ratio | 3:2 (Horizontal: Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Fixed position in front of the image sensor |
Dust Deletion Feature | (1) Self Cleaning Sensor Unit · Removes dust adhering to low-pass filter. · Self-cleaning executed automatically (taking about 2 sec.) when power is turned on or off. Manual execution also possible (taking about 6 sec.). · Low-pass filter has a fluorine coating. (2) Dust Delete Data acquisition and appending · The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images. · The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots. (3) Manual cleaning |
Recording Format | Design Rule for Camera File System 2.0 and EXIF 2.3 |
Image Format | Still Image: JPEG, RAW (14-bit Canon Original), M-RAW, S-RAW, RAW+JPEG, M-RAW+JPEG, S-RAW+JPEG Video: MOV (Image data: H.264; Audio: Linear PCM) |
File Size | 1. Large/Fine: Approx. 17.90 Megapixels (5184 x 3456) 2. Medium/Fine: Approx. 8.00 Megapixels (3456 x 2304) 3. Small 1/Normal: Approx. 4.50 Megapixels (2592 x 1728) 4. Small 2/Fine: Approx. 2.50 Megapixels (1920 x 1280) 5. Small 3/Fine: Approx. 0.35 Megapixels (720 x 480) 6. RAW: Approx. 17.90 Megapixels (5184 x 3456) 7. M-RAW: Approx. 10.10 Megapixels (3888 x 2592) 8. S-RAW: Approx. 4.50 Megapixels (2592 x 1728) Exact file sizes depend on the subject, ISO speed, Picture Style, etc. |
Recording Functions | 1.Card access indicator (access lamp blinking) 2.Read error warning (the respective error warning is displayed in the viewfinder and on the LCD monitor, and the shutter release locks 3.Card formatting (normal formatting and low-level formatting are possible 4.No card warning provided |
Backup Recording | N/A |
File Numbering | The following three types of file numbers can be set: (1) Continuous numbering * The continuous numbering of captured images will continue even after you replace the camera's card. (The numbering continues even when the folder changes.) (2) Auto reset * When you replace the camera's card, the numbering will be reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image in the card. (3) Manual reset * Resets the file number to 0001, and creates a new folder automatically. |
RAW + JPEG Simultaneous Recording | The image-recording quality can be selected in any combination of the three RAW and eight JPEG recording quality settings. |
Color Space | Selectable between sRGB and Adobe RGB |
Picture Style | Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3 |
Settings | Auto (AWB), Daylight, Shade, Cloudy, Tungsten light, Fluorescent light, Flash*, Custom (Custom WB), Color Temperature * Automatically adjusted by the built-in flash and EX-series Speedlite with color temperature communication feature. Set to approx. 6000K if the flash unit does not have the color temperature communication feature. |
Auto White Balance | Auto white balance with the image sensor |
Color Temperature Compensation | · Blue/amber bias: ±9 levels · Magenta/green bias: ±9 levels * Correction based on the current WB mode's color temperature. |
Color Temperature Information Transmission | Provided |
Type | Eye-level pentaprism |
Coverage | Approx. 96% vertically and horizontally (At approx. 22mm eyepoint) |
Magnification | Approx. 0.95x / 27.0° (with 50mm lens at infinity, -1 m-1 (diopter)) |
Eye Point | Approx. 22mm (At -1m-1 from the eyepiece lens center) |
Dioptric Adjustment Correction | -3.0 to +1.0m-1 (diopter) |
Focusing Screen | Ef-A provided as the standard focusing screen (Interchangeable. Ef-D: Grid lines, Ef-S: Point of focus) |
Mirror | Quick-return half mirror (transmission: reflectance ratio of 40:60) |
Viewfinder Information | · AF information AF point, focus confirmation, AF status indicator · Exposure information Shutter speed, aperture, ISO speed (always displayed), AE lock, exposure level, exposure warning · Flash information Flash ready, flash exposure compensation, high-speed sync, FE lock, red-eye reduction light · Image information Highlight tone priority (D+), maximum burst (2-digit display), card information · Battery check · Electronic level (Horizontal only) |
Depth Of Field Preview | Enabled with Depth-of-field preview button |
Type | TTL-CT-SIR AF-dedicated CMOS sensor |
AF Points | All nine AF points are cross-type (center AF point with dual cross sensor for f/2.8) |
AF Working Range | EV -0.5 to 18 (at 73°F/23°C and ISO 100) |
Focusing Modes | (1) Autofocus · One-Shot AF · Predictive AI Servo AF · AI Focus AF (Switches between One-Shot AF and AI SERVO AF automatically) (2) Manual focus (MF) |
AF Point Selection | (1) Automatic selection * With C.Fn III -2 to 1, the Multi-controller can be used to select the AF point directly. (2) Manual selection * Set automatically in Basic Zone modes. |
Selected AF Point Display | Indicated by superimposed display in the viewfinder and on the LCD panel |
AF Assist Beam | Intermittent firing of built-in flash: Effective range: Approx. 13.1 ft./4m at center, approx. 11.5 ft./3.5m at periphery. * With an EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead. |
Metering Modes | Max. aperture TTL metering with 63-zone SPC with the followingselectable modes: (1) Evaluative metering (linked to all AF points) (2) Partial metering (center, approx. 6.5% of viewfinder) (3) Spot metering (center, approx. 2.8% of viewfinder) (4) Center-weighted average metering |
Metering Range | EV 0 to 20 (at 73°F / 23°C with 50mm f/1.4 lens at ISO 100) |
Exposure Control Systems | (1) Program AE (shiftable) (2) Shutter-priority AE (Safety shift possible) (3) Aperture-priority AE (Safety shift possible) (4) Manual exposure (5) Bulb (6) Full Auto (7) Flash Off (8) Creative Auto (9) Programmed Image Control modes * Portrait, Landscape, Close-up, Sports, Night Portrait (10) E-TTL II autoflash program AE * Evaluative metering, Averaged metering |
ISO Speed Range | ISO 100 - 6400 (in 1/3-stop or whole-stop increments) · ISO 12800 can be enabled with a Custom Function. · With [Highlight tone priority], the ISO speed range will be automatically set within 200-6400. 1.In Creative Zone modes, the maximum settable ISO speed (400-6400) will vary within the automatic ISO speed range. 2.If overexposure would occur with fill flash, ISO 100 will be the lowest set. 3.In the and Basic Zone modes (except Night Portrait), bounce flash will be set automatically within ISO 400-1600 (or maximum ISO speed limit). |
Exposure Compensation | Manual: ±5 stops in 1/3 or 1/2-stop increments AEB: ±3 stops in 1/3 or 1/2-stop increments * Indicated up to ±3 stops on the LCD panel and in the viewfinder. |
AE Lock | (1) Auto AE lock ·In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved. (2) Manual AE lock ·With AE lock button. (AE lock is updated each time you press the button.) Enabled in all metering modes. |
Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled |
Shutter Speeds | 1/8000 to 1/60 sec., X-sync at 1/250 sec. 1/8000 to 30 sec., bulb (Total shutter speed range. Available range varies by shooting mode.) |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. or 2-sec. Delay |
Type | Auto pop-up, retractable, built-in flash in the pentaprism |
Flash Metering System | E-TTL II autoflash |
Guide Number | 43/13 (ISO 100, in feet/meters) |
Recycling Time | Approx. 3 sec. |
Flash Ready Indicator | Flash-ready icon lights in viewfinder |
Flash Coverage | Up to 17mm focal length (equivalent to approx. 28mm in 135 format) |
FE Lock | Provided |
Flash Exposure Compensation | Up to ±3 stops in 1/3- or 1/2-stop increments |
EOS Dedicated Speedlite | E-TTL II autoflash with all EX Series Speedlites |
Zooming to Match Focal Length | Provided |
Flash Exposure Compensation | ±3 stops in 1/3- or 1/2-stop increments |
External Flash Settings | The camera can set the following with Speedlite 600EX-RT, 580EX II, 430EX II, 320EX, 270EX II, or 270EX: (1) External flash control * Flash mode, sync setting, FEB (not possible with 270EX), flash exposure compensation, E-TTL II, zoom, wireless master flash (not possible with 430EX II/ 270EX), and clear settings. (2) Flash Custom Function setting |
PC Terminal | None |
Drive Modes | Single, High-speed continuous, Low-speed continuous, Silent Single Shooting and Self-timer (10 sec. self-timer/remote control, or 2-sec. self-timer/remote control) |
Continuous Shooting Speed | High-speed: Maximum approx. 5.3 shots/sec. Low-speed: Maximum approx. 3.0 shots/sec. |
Maximum Burst | JPEG (Large/Fine): approx. 58 RAW: approx. 16 RAW+JPEG (Large/Fine): approx. 7 · The number of possible shots and maximum burst apply to a 4GB SD card based on Canon's testing standards. · The image file size, number of possible shots, and maximum burst will vary depending on the shooting conditions (aspect ratio 3:2, subject, memory card brand, ISO speed, Picture Style, etc.). · The "F" after the number indicates that continuous shooting is possible until the card becomes full. |
Shooting Modes | (1) Live View shooting (2) Remote Live View shooting (with a personal computer installed with EOS Utility) |
Focusing | (1) Autofocus (One-Shot AF) · Live mode · One-point, contrast AF. Switching to another AF point possible. · Face detection Live mode · Face detection, contrast AF. Face selectable. · Quick mode 9-point, phase-difference AF, same as normal shooting. (2) Manual focus * Magnify the image by 5x or 10x and focus manually. |
Metering Modes | Real-time Evaluative metering with the image sensor |
Metering Range | Real-time evaluative metering with image sensor: · Metering range: EV 0 - EV 20 (At 73°F/23°C, 50mm f/1.4 lens, ISO 100) · AE lock possible · The active metering time can be changed. |
Grid Display | Two grid displays provided |
Exposure Simulation | Possible |
Silent Shooting | Provided (Mode 1 and 2) |
File Format | MPEG-4 AVC / H.264 Variable (averaged) bit rate |
File Size | Recording Sizes: 1920 x 1080 (Full HD), 1280 x 720 and 640 x 480 |
Frame Rates | [1920 x 1080]: 30 fps / 25 fps / 24 fps [1280 x 720]: 60 fps / 50 fps [640 x 480]: 30 fps / 25 fps |
Continuous Shooting Time | [1920 x 1080] 30 fps: 22 min. 25 fps: 22 min. 24 fps: 22 min. [1280 x 720] 60 fps: 22 min. 50 fps: 22 min. [640 x 480] 60 fps: 46 min. 25 fps: 46 min. · The file system limits the file size of a single movie clip to 4 GB. If the movie clip reaches 4 GB, the shooting will stop automatically. This translates to around 11 min. for 1920 x 1080 and 1280 x 720, and around 22 min. for 640 x 480 and Cropped 640 x 480. · Even if the file size of a single movie clip is within 4 GB, movie shooting will automatically terminate when the movie time reaches 29 min. 59 sec. |
Focusing | Same as focusing with Live View shooting * During movie shooting or if movie cropping has been set, the image cannot be magnified for manual focusing. |
Exposure Control | (1) Program AE for movie shooting * For shooting modes other than manual exposure and bulb. * Shutter speed (1/30 - 1/4000 sec., signal accumulation time), aperture, and ISO speed automatically set. (2) Manual exposure * For manual exposure. * Shutter speed (signal accumulation time), aperture, and ISO speed (auto/manual) manually set. The shutter speed (signal accumulation time) is limited to 1/4000 sec. at the maximum and to 1/30 sec. at the minimum for 24/25/30 fps or 1/60 sec. or higher for 50/60 fps. |
Exposure Compensation | Up to ±3 stops in 1/3-stop increments * For movies, even if exposure compensation has been set beyond ±3 stops, exposure compensation up to only ±3 stops will be applied. * For still photos, exposure compensation up to ±5 stops can be applied. |
Type | TFT color, Vari-angle LCD monitor (3:2) |
Monitor Size | 3.0-inches |
Pixels | Approx. 1.04 million dots |
Coverage | Approx. 100% Approx. 160° vertically and horizontally |
Brightness Control | Adjustable to one of seven brightness levels |
Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
Display Format | Single image display (Two types of single-image full display and two types of shooting information display), Index display (4-image index and 9-image index), Jump display (1/10/100 images, shooting date, by folder, video, stills, rating), AF point display, Histogram (1. Brightness 2. RGB), Magnify zoom display (1.5x to 10x enabled in 15 steps), Rotated display (Manual, Auto) Slide Show (Image selection: Playback according to All images, Date, Folder Movies, Stills, or Rating; Display time: 1, 2, 3, 5, 10, or 20 sec.; Repeat: Enable/Disable; Transition effect: Off, Slide in, Fade 1, Fade 2) |
Highlight Alert | With single-image display (Info.) and single-image display, overexposed highlight areas will blink |
Protection | Erase protection can be applied or canceled for a single image, all images in a folder or all images in the card |
Erase | Erase a single image, selected images, all images in a folder, all images in a card or erase only unprotected images |
Compatible Printers | PictBridge-compatible printers |
Printable Images | RAW and JPEG images complying to Design rule for Camera File System ·Movies cannot be printed |
DPOF | Version 1.1 compatible |
Compatible Images | JPEG and RAW images and movie For RAW+JPEG, only the RAW or JPEG image or both images can be transferred |
Custom Functions | 20 Custom Functions settable with the camera |
Camera User Settings | Current camera settings can be registered to C1, C2 and C3 on the Mode Dial (Automatic registration update is possible) |
My Menu Registration | Up to six top-tier menu options and Custom Function settings can be registered |
USB Terminal | For personal computer communication and direct printing (USB 2.0 Hi-Speed) |
Video Out Terminal | (1) Video OUT terminal: NTSC/PAL selectable (2) mini-HDMI OUT terminal |
Battery | One Battery Pack LP-E6 AC power can be supplied with the AC Adapter Kit ACK-E6 |
Battery Life | 1)Camera body only 2)With Battery Grip BG-E9 ∗Based on CIPA testing standards |
Battery Check | Automatic battery check when the power switch is turned on: Displayed in 6 levels: · Battery level displayed on LCD panel and in viewfinder. · Battery information can be checked with the [Battery info.] menu · If Battery Grip BG-E9 is used with size AA/LR6 batteries, the battery level is displayed in four levels instead. |
Power Saving | Power turns off after the set time (1, 2, 4, 8, 15 or 30 minutes) of non-operation elapses. |
Date/Time Battery | Built-in secondary battery |
Start-up Time | Approx. 0.1 sec |
Dimensions (W x H x D) | Approx. 5.69 x 4.17 x 3.09 in. Approx. 144.5 x 105.8 x 78.6mm |
Weight | Approx. 26.6 oz./ 755g (CIPA) Approx. 23.8 oz./ 675g (body only) |
Working Temperature Range | 32-104°F/0-40°C |
Working Humidity Range | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
