Canon Support for EOS D30 | Canon U.S.A., Inc.
EOS D30
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Type
Type | Eye-level single lens reflex (SLR) digital camera, 36-bit full color RGB capture (12bits per channel), one-shot type |
Recording Media | CF (CompactFlash) card, Type I or II, single slot |
Compatible Lenses | Canon EF lenses |
Lens Mount | Canon EF mount (full electronic control type) |
Image Sensor
Type | High-sensitivity 3.25-million pixel CMOS sensor |
Pixels | Effective pixels 2160 X 1440 |
Total Pixels | Total pixels 2226 X 1460 |
Recording System
Recording Format | Design Rule for Camera Format (DCF) |
Image Format | JPEG and Canon RAW |
File Size | 1.Large/Fine (2160 X 1440)2.Large/Normal (2160 X 1440)3.Small/Fine (1440 X 960)4.Small/Normal (1440 X 960)5.Lossless compression (2160 X 1440) |
Interface | USB |
White Balance
Settings | 7 types, including auto, preset and custom |
Viewfinder
Type | Full-frame reflex type, coverage approximately 95% horizontal and vertical, 0.88X magnification and 20mm eyepoint |
Autofocus
AF Points | Wide-area AF with 3 selectable focusing points |
AF Working Range | EV 2-18 (ISO 100, standard chart) |
Focusing Modes | One-shot AF, AI Servo AF with focus prediction, AI Focus AF, and manual focus |
Exposure Control
Metering Modes | TTL maximum aperture metering with a 35-zone silicon photocell.1) 35-zone Evaluative metering linked to all focusing points2) Center weighted average metering3) 9.5% central-area partial metering |
Metering Range | EV 2-20 (at normal temperatures, EF 50mm f/1.4 USM, ISO100) |
ISO Speed Range | Equivalent to ISO 100-1600 (adjustable in 1 EV increments) |
Shutter | 1/4000 sec. to 30 sec. plus Bulb, maximum X-sync at 1/200 sec. |
Shutter Speeds | 1/4000 sec. to 30 sec. plus Bulb, maximum X-sync at 1/200 sec. |
Built in Flash
Type | Retractable-type. Guide Number is 12/39 at ISO 100, m/ft. |
External Speedlite
EOS Dedicated Speedlite | Accessory shoe for EX-series Speedlites; PC socket also built-in on left side of camera body |
Drive System
Continuous Shooting Speed | Up to approximately 3 frames per second for up to approximately 8 frames, when camera is set for Large/Fine recording. |
Maximum Burst | Approximately 3 frames per second for up to approximately 8 frames in Large/Fine mode or 17 frames in Large/Normal mode |
LCD Monitor
Type | 1.8-inch low-temperature TFT type, ; displays captured images, menus, etc. |
Pixels | Approx. 114,000 pixels |
Power Source
Battery | BP-511 lithium-ion battery |
Back-up Battery | AC operation via DC Coupler DR-400 and Compact Power Adapter CA-PS400Up to two BP-511 batteries via optional Battery Grip BG-ED3 |
Dimensions and Weight
Dimensions (W x H x D) | 5.9 X 4.2 X 3.0 in / 149.5 X 106.5 X 75.0 mm |
Weight | 26.5oz/750g w/o battery or CF card |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
