Canon Support for EOS M50 Mark II EF-M 15-45mm IS STM Kit | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital single-lens non-reflex AF/AE camera with built-in flash |
Image Processor | DIGIC 8 |
Recording Media | SD/SDHC/SDXC memory cards
Compatible Lenses | Canon EF-M lens group
Lens Mount | Canon EF-M mount |
Type | CMOS sensor (supporting Dual Pixel CMOS AF) |
Effective pixels | Approx. 24.1 megapixels |
Total Pixels | Approx. 25.8 megapixels |
Aspect Ratio | 3:2 (Horizontal:Vertical) |
Screen Size | Approx. 22.3 x 14.9mm (APS-C) |
File Format | Design rule for Camera File system 2.0, Exif 2.31 compliant, Supports time difference information |
Data Type | RAW (Canon .CR3, 14-bit); C-RAW (Canon .CR3) and JPEG (8-bit) (12-bit A/D conversion for RAW images in continuous shooting mode) | ||||||||||||||||||||||||||||||||||||||||||||||||
Recording Pixels |
3:2 Aspect Ratio
4:3 Aspect Ratio
16:9 Aspect Ratio
1:1 Aspect Ratio
RAW + JPEG Simultaneous Recording | Simultaneous recording of any combination of RAW/C-RAW/ and JPEG image recording quality is supported |
Folder Setting | Creating new folders and selecting folders in the card is possible. |
File Numbering | Continuous, Auto Reset |
Still Photo File Size / Number of Possible Shots / Maximum Burst for Continuous Shooting |
* File size, number of possible shots, and maximum burst vary depending on shooting conditions (including subject, ISO speed, Picture Style, and Custom Function). |
Picture Style |
White Balance |
*2 Custom white balance is not available for monochrome images and images with Creative filters applied. |
Noise Reduction |
(Applies to all ISO speeds) |
Automatic Image Brightness Correction | Auto Lighting Optimizer (Disable, Low, Standard, or High) (Not available if Highlight Tone Priority is active) |
Highlight Tone Priority | Still photo shooting(Disable, Enable or Enhanced) Movie recording (Disable, Enable) |
Lens Aberration Correction |
Creative Assist | During shooting (in Scene Intelligent Auto): Vivid, Soft, Warm, Cool, Green, Shine, Lime, Peach, B&W, Blue, Purple Image Creation Effects Background blur, Brightness, Contrast, Saturation, Color Tone 1, Col-or-tone 2, Monochrome Creative Assist during playback (RAW or C-RAW images): Auto 1, Auto 2, Auto 3, Vivid, Soft, Warm, Cool, Green, Shine, Lime, Peach, B&W, Blue, Purple, Normal Image Creation Effects Brightness, Contrast, Saturation, Color tone 1, Color tone 2, Monochrome |
Type | Dual Pixel CMOS AF (1-point AF, Spot AF, Face+Tracking priority AF, Zone AF) |
AF Points | Still photo shooting: Up to 143 zones (Maximum) Video shooting: Up to 117 zones (Maximum) |
Focusing Brightness Range | Still photo shooting: EV -418 (at Center AF point, room temperature, ISO 100, f/1.4, in One-Shot AF) Video shooting: EV -218 ( When set to Face+Tracking. Except for Miniature effect movie). |
AF Operation | One-Shot AF, Servo AF, or Manual Focus |
Touch & Drag AF | Supported (When [Tap to select subject] is disabled) |
Tap to Select Subject |
AF Assist Beam | Built-in LED lamp |
Metering Modes | 384-zone (24x16) metering using the image sensor. |
Brightness Metering Range | Stills: EV -220 (at room temperature 73°F/23°C, ISO 100) Video: EV 020 (at room temperature 73°F/23°C, ISO 100) |
Exposure Control | Via SHOOTING MODE in menu: Program AE, Shutter-priority AE, Aperture-priority AE, or Manual (B is selected as shutter speed setting in Manual mode) |
ISO Speed Range (Recommended Exposure Index) | Stills: ISO 10025600 (in 1/3-stop increments) Video: ISO 100-12800; H: 25600 |
Exposure Compensation | Manual: ±3 stops in 1/3-stop increments |
AE Lock | Manual, Auto (exposure locked after focusing, in One-Shot AF with Evaluative metering) |
Type | Electronically controlled focal-plane shutter * Electronic 1st / mechanical 2nd curtain * Except when Silent Mode is set Rolling shutter, using the image sensor * Electronic shutter * When Silent Mode is set |
Shutter Speeds | Creative Zone: 1/4000 to 30 sec., bulb *X-sync at 1/200 sec. Basic Zone: 1/4000 to 1 sec. * Varies depending on shooting mode |
Built-in Flash | Manual pop-up flash (Max. Guide Number approx. 16.4 [ft] / 5.0 [m], at ISO 100) |
Flash Metering Mode | Evaluative (Face Priority) / Evaluative / Average |
Flash Exposure Compensation | ±2 stops in 1/3-stop increments |
FE Lock | Provided |
Continuous Shooting Priority (CSP) mode | Supported * EL-100 Mode dial set to ON * Flash mode set to CSP * ISO speed is automatically set to ISO Auto |
External Flash | EX and EL series Speedlites Speedlite Transmitter ST-E3-RT Speedlite Transmitter ST-E2 Off-Camera Shoe Cord OC-E3 |
Drive Mode and Continuous Shooting Speed (Approx.) |
* 2 BR-E1: Supported / RC-6: Not supported |
Self-timer Mode | Off, 2-second self-timer, 10-second self-timer, Continuous timer |
Aspect Ratio Settings | 3:2, 4:3, 16:9, 1:1 (Frame Grab images from 4K movies cannot be cropped) |
Focus Mode | AF, MF, AF+MF (Manual focus after One-Shot AF) MF peaking provided |
Continuous AF | Provided |
Touch Shutter | Provided |
Grid Display | Off / 3x3 / 6x4 / 3x3+diag |
Depth of Field Preview | Provided |
Recording System | MP4 |
File Format | Video: MPEG-4 AVC / H.264 Variable (averaged) bit rate Audio: AAC |
Live Streaming | Supported |
Recording Size and Frame Rate |
* ² Sound recording, Movie Servo AF, Movie Digital IS, and Movie Auto Level are disabled. * ³ AF disabled during shooting. |
Movie Exposure Modes | Movie Auto Exposure; Movie Manual Exposure |
Metering Mode | Evaluative metering / Center-weighted metering (when no faces are detected) |
Exposure Compensation | ±3 stops in 1/3-stop increments |
ISO Speed (Recommended Exposure Index) | ISO 100- Maximum 6400/12800 H:25600 |
Miniature Effect Movie | Provided (Full HD 1920 x 1080, 29.97 fps) |
Still Image Shooting | Provided (Possible with Hybrid Auto setting; HD 1280 x 720 at 29.97 fps) |
Continuous Shooting Time |
* Recording bit rate of movie images only, sound data not included. |
Sound Recording | Built-in stereo microphones, recording level adjustable, wind filter provided, attenuator provided |
Card Performance Requirements |
Type | TFT color, liquid-crystal monitor |
Menu Magnification | Double-tap-based supported * You can double-tap with two fingers to zoom in on the area centered between the two double-tapped points. |
Screen Size | 3.0-inch type |
Dots | Approx. 1.04 million dots |
Brightness Adjust-ment | Manually adjustable to one of seven brightness levels |
Angle of View | Approx. 170° vertically and horizontally |
Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean, Malay, Vietnamese, Indonesian, Hindi, Japanese) |
Hints & Tips | Displayable |
Playback Methods | Playback on camera's LCD screen HDMI playback to compatible TVs - (AV cables not supported) Playback on computer screen - (requires compatible software) |
Playback Display Options | Single image, or 4, 9, 36, or 100-image index Viewing options via INFO button: full image, full image with basic info, thumbnail image with histogram and detailed shooting info, RGB and Brightness histograms with lens info |
Zoom Magnification | Approx. 1.5x to 10.0x (Can be activated by double-tapping) |
Image Browsing Methods | Single image 10 images Specified number (1-100 images) Date Folder Movies Still images Protected images Ratings |
Image Rotate | Provided |
Rating | Provided (Off, 1,5 stars) |
Video Playback | Provided (with built-in speaker) |
Playback Time | Approx. 4 hr. 55 min. * With a fully charged LP-E12 * Time when playing back a slideshow of still photos |
Slideshow | All images Repeat: Enable / Disable Slideshow of images after selection from the search list Background music: Off / On |
Creative Filters | Grainy B/W Soft focus Fish-eye effect Art bold effect Water painting effect Toy camera effect Miniature effect |
Cropping | Cropping frame movement: Vertical / Horizontal Cropping range: Up to 42 sizes Tilt correction Aspect ratio (3:2, 16:9, 4:3, 1:1, 2:3, 9:16, 3:4) * Frame grab images from 4K movies cannot be cropped. |
Resize | M, S1, S2 * Frame grab images from 4K movies cannot be resized. |
Red-eye Reduction | Provided |
Compatible Printers | PictBridge |
Printable Images | JPEG RAW / C-RAW |
Custom Functions | 5 Available |
Customizable Buttons | Stills :Shutter button, AE lock button, Multi-function button, Movie button, Exposure comp. button, AF/MF button, Flash button, Erase button. Movie:AE lock button, Multi-function button, Exposure comp. button, AF/MF button, Flash button, Erase button |
Copyright Info | Provided |
Digital Terminal | USB Micro-B (Hi-Speed USB 2.0 compliant) |
HDMI OUT Terminal | Type D (resolution switches automatically) HDMI output while recording (shooting screen without sound) provided CEC not supported |
Wireless Remote Control | Compatible with Wireless Remote Control BR-E1 Not compatible with accessories using the infrared transmission system of Remote Controller RC-6 |
Standards Compliance | IEEE 802.11b/g/n |
Transmission Method | DS-SS modulation (IEEE 802.11b), OFDM modulation (IEEE 802.11g/n) |
Transmission Frequency (Central Frequency) | Frequency: 24122462 MHz Channels: 111 ch |
Connection Method and Security | (1) Infrastructure mode a. WPA2-PSK i. AES ii. TKIP b. WPA-PSK i. AES ii. TKIP c. Open i. WEP ii. None d. Wi-Fi® Protected Setup compliant (2) Camera access point mode a. WPA2-PSK i. AES b. Open i. None |
Supported Wireless Functions | Connect to compatible smart phone or tablet Remote-control camera from compatible mobile device Remote-control camera with optional Canon BR-E1 Remote Controller Send still images or video files to mobile device Upload images to Web service Send images to compatible computer Print to compatible Wi-Fi enabled printer Geo-tag in-camera images with GPS data from compatible smart phone (Bluetooth required) |
Transfer Images Between Cameras | Not Possible |
Connection to Smart phones | Connect with free Canon Camera Connect app (Android and iOS versions available for compatible mobile devices) |
Wireless Connection Types | Wi-Fi® and Bluetooth v. 4.2 (low-energy) |
Battery | Battery Pack LP-E12 |
Number of Photos Taken |
* With a fully charged LP-E12 battery.
Dimensions (W x H x D) | Approx. 4.58 x 3.47 x 2.31 in. (116.3 x 88.1 x 58.7mm) CIPA compliant. |
Weight | Black: Approx. 13.65 oz. / 387g (Including battery pack and memory card) Approx. 12.35 oz. / 350g (Body only) White: Approx. 13.69 oz. / 388g (Including battery pack and memory card) Approx. 12.38 oz. / 351g (Body only) * Without body cap * 1: Based on CIPA guidelines |
Working Temperature Range | 32-104° F / 0-+40°C |
Working Humidity Range | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
