Canon Support for EOS RP | Canon U.S.A., Inc.
EOS RP
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
Software Development Kit
Using Wi-Fi
- I Want to Save Images to My Computer
- How to Transfer Images to the Computer Using Image Transfer Utility 2 via Wi-Fi on Windows 7
- How to Transfer Images to the Computer Using Image Transfer Utility 2 via Wi-Fi on Windows 10
- How to Transfer Images to the Computer Using Image Transfer Utility 2 via Wi-Fi on macOS
- How to Transfer Images to the Computer Using Image Transfer Utility 2 via Wi-Fi on Windows 8.1
- What Can I Do Using the Wireless LAN Functions?
- Sending Images to a Smartphone using a Wireless Connection
- How to import images to Digital Photo Professional Express using a Wi-Fi Connection
- Using EOS Utility 3.x to Send Images to a Computer via the Wi-Fi Function
Wireless Setup
- Computer Environment Required for Connecting the Camera via Wi-Fi using EOS Utility 3.x
- Troubleshooting the EOS RP
- Computer Environment Required for Connecting the Camera via Wi-Fi using Image Transfer Utility 2
Printing Images Wirelessly
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital single-lens non-reflex AF/AE camera |
Recording Media | SD/SDHC/SDXC memory cards
Image Format | Approx. 35.9 x 24.0mm |
Compatible Lenses | Canon RF lens group (excluding EF, EF-S and EF-M lenses) When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses) |
Lens Mount | Canon RF mount |
Type | CMOS sensor (compatible with Dual Pixel CMOS AF) |
Pixels | Approx. 26.2 megapixels |
Pixel Unit | Approx. 5.76 µm square |
Total Pixels | Approx. 27.1 megapixels |
Aspect Ratio | 3:2 (Horizontal:Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Installed in front of the image sensor, non-detachable |
Dust Deletion Feature |
Recording Format | Compliant to Design rule for Camera File system 2.0 and Exif 2.3. Supports time difference information in Exif 2.31. |
File Size | 3:2 Aspect Ratio Large/RAW/C-RAW: 6240 x 4160 Medium: 4160 x 2768 Small 1: 3120 x 2080 Small 2: 2400 x 1600 1.6x (Crop) Large/RAW/C-RAW: 3888 x 2592 Small 2: 2400 x 1600 4:3 Aspect Ratio Large/RAW/C-RAW: 5536 4160 Medium: 3680 x 2768 Small 1: 2768 x 2080* Small 2: 2112 x 1600* 16:9 Aspect Ratio* Large/RAW/C-RAW: 6240 x 3504 Medium: 4160 x 2336 Small 1: 3120 x 1752 Small 2: 2400 x 1344 1:1 Aspect Ratio Large/RAW/C-RAW: 4160 x 4160 Medium: 2768 x 2768 Small 1: 2080 x 2080 Small 2: 1600 x 1600
File Numbering |
RAW + JPEG Simultaneous Recording | Possible |
Color Space | Selectable between sRGB and Adobe RGB |
Picture Style |
Settings |
Auto White Balance | Option between ambience priority and white priority settings. |
Color Temperature Compensation | Blue/amber bias: ±9 levels Magenta/green bias: ±9 levels Corrected in reference to the current WB mode's color temperature. |
Type | OLED color electronic viewfinder |
Coverage | Approx. 100% vertically and horizontally relative to the shooting image area (with image quality L, at approx. 23mm eyepoint). |
Magnification | Approx. 0.70 (with 50mm lens at infinity, -1 m-1) |
Eye Point | Approx. 22mm (at -1 m-1 from the eyepiece lens end) |
Viewfinder Information |
Type | Phase-difference detection system with image sensor (Dual Pixel CMOS AF) |
AF Points | Max. 4,779 When selected with cross keys. |
AF Working Range | EV -5 to 18 (f/1.2, at 73°F/23°C, ISO 100, One-Shot AF) |
Focusing Modes | One-Shot AFServo AFManual (Manual focus) |
AF Point Selection |
* Not available in 4K movie recording |
AF Assist Beam |
Metering Modes | Real-time metering with image sensor (384 [24x16])
Metering Range | EV -3 - 20 (at 73°F/23°C, ISO 100) |
Exposure Control Systems |
ISO Speed Range | Manual Setting
Auto
*1 Depending on [Minimum] and [Maximum] of [ISO speed settings] or [Range for stills]. |
Exposure Compensation |
AE Lock |
Type | Electronically controlled focal-plane shutter
Shutter Speeds | 1/4000 to 30 sec., bulb (total range of all shooting modes) X-sync at 1/180 sec. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. delay, 2-sec. delay, Continuous shooting |
Shutter Lag Time | Shutter Lag Time |
Flash Metering System | E-TTL II autoflash |
Flash Exposure Compensation | ±3 stops in 1/3- or 1/2-stop increments |
FE Lock | Provided |
External Flash Settings | The camera can set the following with EL and EX series Speedlites:
Drive Modes |
Maximum Burst |
Shooting Modes | Still photo shooting and video shooting |
Focusing |
Metering Modes |
Metering Range | EV -2.5 - 18 (at 73°F/23°C, ISO 100, One-Shot AF, with 29.97 fps) |
Grid Display |
File Format | MP4 Video: MPEG-4 AVC / H.264 Variable (averaged) bit rate Audio: ALL-I: Linear PCM IPB: AAC |
Video Recording Size and Frame Rates |
Continuous Shooting Time |
Focusing |
Range | Full range (0 to 255) |
Exposure Control |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.0-inch (screen aspect ratio of 3:2) 2.95 in./7.50cm diagonal (2.46 in./6.24cm width, 1.64 in./4.16cm height) |
Pixels | Approx. 1.04 million dots |
Coverage | Approx. 100% vertically/horizontally |
Brightness Control | Manually adjustable to one of seven brightness levels |
Coating | Clear View LCD II
Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese) |
Display Format |
Highlight Alert | The white areas with no image data will blink. |
Protection |
Erase |
Compatible Printers | Images can be sent via Wi-Fi® to a PictBridge-compatible (Wireless LAN) printer and printed. |
DPOF | Compliant to DPOF Version 1.1 |
Custom Controls | Customizable Buttons
Customizable Dials
My Menu Registration | My Menu Registration
USB Terminal | Equivalent to Hi-Speed USB (USB 2.0)
Video Out Terminal | Type C (Resolution switches automatically) / CEC not compatible
Extension System Terminal | 3.5mm diameter stereo mini jack |
Battery | Battery Pack LP-E17 x 1With the AC Adapter + DC Coupler, AC power is possible. With the USB Power Adapter PD-E1, in-camera charging of LP-E6N is possible but LP-E6 cannot be charged. The USB Power Adapter PD-E1 is not compatible with powering the camera. |
Battery Check | Automatic battery check when the power switch is turned ON. Displayed in 4 levels.
Power Saving | Power turns off after the set time of non-operation elapses. Display off Available time options: 15 sec. / 30 sec. / 1 min. / 3 min. / 5 min. / 10 min. / 30 min. Auto power off Available time options: 30 sec. / 1 min. / 3 min. / 5 min. / 10 min. Disable Viewfinder off Available time options: 1 min. / 3 min. / Disable
Date/Time Battery | Built-in secondary battery When fully-charged, the date/time can be maintained for approx. 3 months. Recharge time: approx. 8 hrs. The recharge time required to provide the above number of months with no battery pack installed. |
Start-up Time | Approx. 0.82 sec.
Dimensions (W x H x D) | Approx. 5.22 x 3.35 x 2.76 in. / 132.5 x 85.0 x 70.0 mm (Depth from tip of grip to LCD screen surface: Approx. 2.34 in / 59.4mm) |
Weight | Approx. 1.07 lbs. / 485g (including battery, SD memory card; without body cap) Approx. 1.0 lbs. / 440g (body only; without battery, card or body cap) |
Working Humidity Range |
Working Temperature Range | 32-104° F / 0-40° C |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
What is the Stop Motion Animation Service?
We have released a new upgrade service for various EOS R series cameras.
This upgrade enables you to capture Stop Motion Animation.
For more details of the service and compatible camera’s click Learn More.
Pricing
Model | Price* |
Various EOS R cameras | $100 |
*Tax and shipping fees are NOT included
*All pricing is subject to change Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Canon Customer Support Center
Phone: 1-800-OK-CANON (toll free), 1-800-652-2666
For additional support options: https://www.usa.canon.com/support
