Canon Support for imageCLASS D1520 | Canon U.S.A., Inc.
imageCLASS D1520
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
WINDOWS
macOS X
imageCLASS D1520 |
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
imageCLASS D1520 |
Printer Specifications
Printer Type | Monochrome Laser Copier |
Print Speed | Up to 35ppm (1-sided plain paper letter) Up to 17ppm (2-sided plain paper letter)1 |
First Print Time | 6.3 seconds or less (letter)2 |
Printer Language | UFR II |
Print Resolution | Up to 600 x 600 dpi, 1200 x 1200 dpi equivalent |
Maximum Print Size | Up to Legal |
Duplex Print | Yes |
Print Modes | Poster, Booklet, Watermark, Toner Saver, Page Composer |
Print Memory | 1 GB (Shared) |
Direct Print from USB | JPEG, TIFF, PDF |
Copier Specifications
Copy Type | Monochrome Laser |
Copy Speed | Up to 35ppm (letter) |
Duplex Copy Speed | Up to 17cpm (letter) |
Copy Resolution | Up to 600 x 600 dpi |
Original Type | Text/Photo, Text, Photo |
Halftones | 256 Levels |
Warm-up Time | 16 seconds or less from power on |
First Copy Time | 10 seconds or less3 |
Recovery Time | 5 seconds or less |
Maximum Number of Copies | Up to 999 copies |
Reduction/Enlargement | 25 - 400% in 1% increments |
Copy Size | Platen: Up to Legal / ADF: 5.1" x 5.5" to Legal |
Copy Features | Frame Erase, Memory Sort, 2 on 1, 4 on 1, ID Card Copy |
Scanner Specifications
Scan Type | Color Contact Image Sensor (CIS) |
Color Depth | 24-bit |
Scan Resolution | Up to 600 x 600 dpi (optical), 9600 x 9600 dpi (software interpolated resolution) |
Scan Size | Platen: Up to Legal ADF: 5.1" x 5.5" to Legal |
Duplex Scan | Yes |
Compatibility | TWAIN, WIA 2.0, ICA |
Output File Formats | JPEG, TIFF, PDF, Compact PDF, PDF (OCR) |
Scan Features | Push Scan, Pull Scan, Scan to USB |
Pull Scan | USB and Network |
Push Scan (Scan to pC) | USB and Network |
Paper Handling Specifications
Standard Paper Source(s) | 500-sheet cassette plus 50-sheet multipurpose tray4 |
Optional Paper Source(s) | 500-sheet cassette4 (U1) |
Document Feeder | 50-sheet duplex4 |
Paper Output | 150 sheets (face down) |
Paper Weight | 16-34 lb. bond (cassette/optional cassette), 16-43 lb. bond (multipurpose tray) |
Media Sizes | Letter, Legal, A4, A5, B5, Statement, Executive, Postcard, Index Card |
Media Types | Plain / Heavy / Recycled / Color Paper, Label, Postcard, Envelope |
Envelope Capacity | 5 envelopes (multipurpose tray) |
Envelope Types | Com 10, Monarch, DL, C5 |
Connectivity and Software Specifications
Standard Interface(s) | USB Device 2.0 Hi-Speed, 10/100/1000 Base-T Ethernet (Network) |
Mobile Functions | Canon PRINT Business5, Apple® AirPrint®6, Mopria™ Print Service7, Google Cloud Print™8 |
Network Functions | Print, Scan (SMB, E-mail, FTP), PC Fax |
Embedded Web Server (Remote UI) | IE 7.0 or higher, Safari 3.2.1 or higher |
Print Protocols | LPD, RAW, WSD-Print (IPv4, IPv6) |
TCP/IP Set of Application Services | Bonjour (mDNS), HTTP, HTTPS, POP before SMTP (IPv4, IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 |
Network Management Protocols | SNMPv1, SNMPv3 (IPv4, IPv6) |
OS Compatibility | Windows® 10, Windows® 8.1, Windows 8, Windows 7, Windows Vista®, Windows Server® 2012 R2, Windows Server 2012, Windows Server 2008 R2, Windows Server 2008, Windows Server 2003 R2, Windows Server 2003, Mac OS X® 10.6 & up |
Cable Included | Power Cord (USB not included) |
Bundled Software | Printer Driver, Scanner Driver, Network Scan Utility, MF Scan Utility, Presto! PageManager |
Environmental Specifications
Power Consumption | Approx: 600 W (during operation), 9 W (standby), Energy Saver Mode: 1.2 W (USB), 1.4 W (wired) |
Typical Energy Consumption | 1.2kWh |
General Specifications
Dimensions | 17.7" (W) x 18.6" (D) x 18.3" (H) |
Unit Weight (without/with cartridge) | 45 lbs. (w/o cartridge), 46.7 lbs. (w/cartridge) |
Package Weight | Approx. 60 lbs. |
Cartridge Type | Cartridge 120 (Yields approx. 5,000 pages), Single Cartridge System *Yields based on ISO/IEC Standard |
LCD Display | 3.5 Inch, Color Touch LCD |
Duty Cycle | Up to 50,000 pages per month |
Department ID Management | Up to 300 IDs |
Security | IP Filtering, MAC Address Filtering, HTTPS, SNMPv3, IEEE802.1x, Secured Print |
Languages | English, Japanese, French, Spanish, German, Italian, Portuguese, Chinese, Korean |
Warranty | 1 year limited exchange/carry-in warranty (Extended warranty available)9 |
Other Features: Sending Method: SMB, E-mail, FTP, iFAX Simple Color Mode: Full Color, Grayscale, Monochrome Scan Resolution: 300 x 300 dpi, 200 x 200 dpi Operating Temperature: 50-86°F Operating Humidity: 20-80% RH (no condensation) |
PRODUCT LIMITED WARRANTY
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
