Canon Support for imageCLASS MF4450 | Canon U.S.A., Inc.
imageCLASS MF4450
Technical support for this product is provided exclusively through our FAQs and Knowledge Base.
Please click FAQs or Knowledge Base and enter your search term to find a resolution to your inquiry.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
WINDOWS
macOS X
imageCLASS MF4450 |
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
imageCLASS MF4450 |
Printer
Printing Method | Monochrome Laser |
Print Speed (up to) | Black:Up to 24 ppm (letter) |
Print Resolution (Up to) | Black:Up to 600 x 600 dpi 1200 x 600 dpi quality |
Toner Compatibility (for Laser MFP) | Canon Cartridge 128 CRG Yield* 2,100 *Yield based on ISO/IEC Standard |
Paper Sizes | Letter, Legal, A4, A5, B5, Statement, Executive |
Automatic Sheet Feeder | 35-sheet Simplex3 |
Paper Weights | 16 to 43 lb. bond (cassette), 16 to 43 lb. bond (multipurpose tray) |
Output Tray Capacity | Approx. 100 sheets (facedown) 2 |
Copier
Copy Resolution (up to) | Up to 600 x 600 dpi |
Copy Speed (up to) | Up to 24 cpm (letter) |
Zoom | 25-400% in 1% increments |
Halftones | 256 levels |
First Copy Time | Approximately 9 seconds |
Reduction / Enlargement | 25%, 50%, 64%, 78%/ 129%, 200%, 400% |
Scanner
Scanner Type | Color Contact Image Sensor (CIS) |
Max. Resolutions | Optical:Up to 600 x 600 dpi Interpolated:9600 x 9600 |
Scanner Features | Rotate, Push Scan (Scan to PC), Pull Scan |
Color Depth | 24-bit |
File Format | Hi-Compression PDF, Searchable PDF, PDF, JPEG, TIFF, BMP2 |
Fax
Modem Speed | Up to 33.6 Kbps (Super G3) |
Fax Resolution | Up to 203 x 391 dpi (super fine) |
Memory Capacity | Up to 256 sheets1 |
Speed Dialing | 4 one-touch speed dials; 100 coded dials |
Fax Features | Distinctive Ring Pattern Detection, Remote RX, Dual Access Fax, Auto Redial, Auto Fax Reduction, Fax Activity Reports, Manual Fax Forwarding |
General
Other Features | Compatibility TWAIN, WIA |
OS Compatibility | Windows® 7, Windows Vista®, Windows XP/2000, Mac® OS X 10.4.9 & up, Linux (print only) |
Standard Interface | USB Device 2.0 Hi-Speed |
Software Included | Canon Drivers, Document Management & OCR Software |
Power Consumption (approx.) | 1090W (Max) 10W (Standby) 3W (Energy Saver) |
Dimension (W x D x H) | 15.4" (W) x 16.6" (D) x 14.6" (H) |
Weight | 24.5 lbs. (w/o cartridge) 25.8 lbs. (w/cartridge) |
Warranty | 1 year limited carry-in/exchange warranty (Extended warranty available) |
Canon imageCLASS MF4450/D550 LIMITED WARRANTY
CARTRIDGES FOR THE PRODUCT (EXCEPT THE CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Click Here to download the imageCLASS MF4450/D550 Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
ADDITIONAL SUPPORT
CONTACT US
