Canon Support for imagePRESS 1125+ | Canon U.S.A., Inc.
imagePRESS 1125+
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Main Unit Specs
Model Name | imagePRESS 1125+ |
Imaging System | Laser Electrostatic Transfer System |
Printing Resolution | Up to 1200 x 1200 dpi |
Halftone | 256-Level Grayscale |
Letter |
Simplex: 125 Duplex/Perfect: 62 |
Ledger |
Simplex: 74 Duplex/Perfect: 37 |
Maximum Original Size | 13 x 19.2 |
Standard Paper Capacity | 2,000 Sheets (20 lb. Bond) |
Acceptable Paper Weights
Cassette |
Uncoated: 14 lb. Bond to 110 lb. Bond Cover Coated: 24 lb. Bond to 90 lb. Cover |
Duplexing |
Automatic Duplex/Perfect Any Supported Stock |
Power Requirements | 208V/30A+208V/15A |
Dimension | (H x W x D): 54.12 x 54.62 x 31.87 |
Weight | 1,103 lb. |
Supplies
Estimated Toner Yield | 69,000 impressions at 6% coverage (LTR pgs) |
Accessories
Feeders
Description | Color Image Reader-L1 (Opt.) (Includes DADF (Duplex Automatic Document Feeder) |
Acceptable Originals |
Statement to 11 x 17 Resolution: Up to 600 x 600 dpi, 256 Gradations |
Scanning Speed |
B/W: Up to 200 ipm (300 dpi) Up to 120 ipm (600 dpi) Color: Up to 80 ipm (300 dpi) Up to 40 ipm (600 dpi)* |
Capacity | 300 sheets (20 lb. Bond) |
Paper Weights | 14 lb. Bond to 120 lb. Index |
Power Source | From Main Unit |
Dimensions | (H x W x D): 7.12 x 23.25 x 25 |
Weight | 81.6 lb. |
Paper Supply Options
Description | POD Deck-C1 (Std.) |
Paper Capacity | 4,000 Sheets (1,000 x 2 + 2,000) (20 lb. Bond) |
Paper Sizes | 13 x 19.2 |
Paper Weights |
Uncoated: 14 lb. Bond to 110 lb. Bond Cover (All Trays) Coated: 24 lb. Bond to 90 lb. Cover (All Trays) |
Power Source | 120-127VAC, 60Hz, 15A |
Dimensions | 43.12 x 29.37 x 31.25 |
Weight | 499 lb. |
Description | POD Deck-C1 and Secondary POD Deck-C1 (Opt.)*** |
Paper Weights |
Power Source | 120-127VAC, 60Hz, 15A x (2) |
Dimensions | 43.12 x 61.5 x 31.25 |
Weight | 997 lb. |
Description | POD Deck-C1 & Sec. POD Deck-C1 (2) (Opt) *** |
Paper Weights |
Dimensions | 43.12 x 93.62 x 31.25 |
Weight | 1,495 lb. |
Output Options
Finishers Output Trays
Description | Finisher-AF1/Saddle Finisher-AF2 (Opt.) |
Paper Weights |
Finisher: 14 lb. Bond to 110 lb. Cover Saddle Finisher: 14 lb. Bond to 110 lb. Cover |
Paper Size |
Stapling: Executive, Letter-R, Letter, Legal, 11 x 17 Sheet Stacking: Up to 13 x 19.2 Saddle Finisher: Letter-R, Legal, 11 x 17, 12 x 18, 13 x 19 |
Number Of Trays | 2/3 |
Top Tray | Up to 3,000 Sheets (20 lb. Bond) |
Lower Tray | 2,000 (20 lb. Bond) |
Saddle Stitch Tray | 30 Booklets or Limitless |
Staple Positions | Corner-Stapling, Double-Stapling |
Stapling Capacity |
Up to 100 Sheets (LTR) Max. Booklet Stapling Capacity: Up to 25 Sheets Saddle-Stitched (20 lb. only) |
Power Source | 120V/15A |
Dimensions | 46.5 x 31.25 x 35.37 |
Weight |
Finisher: 287 lb. Saddle Finisher: 396 lb. Puncher Unit-BB1 (Option for Finisher-AF1/Saddle Finisher-AF2) Acceptable Paper Weight: 14 lb. Bond to 73 lb. Cover Paper Sizes 2-Hole: Legal, Letter-R 3-Hole: 11 x 17, Letter, EXE Punch Speed: Up to 135 ppm (Depends on Speed of Marking Engine) Weight: 6.7 lb. Power Source: From Finisher High-Capacity Stacker-E1 (Opt.) Offset Stack Capacity: 10,000 Sheets (Letter) (20 lb. Bond) Top Tray Capacity: 1,000 Sheets (20 lb. Bond) Maximum Paper Size: 13 x 19.2 Acceptable Paper Weight: 14 lb. Bond to 110 lb. Cover Number of Units Connected at Once: Up to 2 Dimensions (H x W x D): 53.62 x 39.25 x 31.25 Weight: 463 lb. Power Source: 120V/15ATwo-Knife Trimmer-A1 (Opt.) Margin Trimming: Top and Bottom Trim Trim Amount: 0.08 to 0.59 Trim Thickness: 100 Sheets Waste Tray Capacity: 750 Sheets (Two-Sided Trimmed) Acceptable Paper Weight: 14 lb. Bond to 110 lb. Cover Output Tray Capacity: 30 Booklets Dimensions (H x W x D): 21.12 x 30.37 x 41 Weight: 319 lb. Power Source: 120V/15A |
Booklet Trimmers
Description | Booklet Trimmer-D1 (Opt.) |
Sheet Capacity |
Waste Tray Capacity: 1,500 Sheets (With 0.78 Trim, 20 lb. Bond) Margin Trimming: Fore-Edge Trim Trim Amount: 0.08 to 0.78 Trim Thickness: 100 Sheets Acceptable Paper Weight: 14 lb. Bond to 110 lb. Cover Output Tray Capacity: 30 Booklets Dimensions (H x W x D): 41 x 62 x 30.37 Weight: 335 lb. Power Source: From Saddle Finisher Perfect Binder-C1 (Opt.) Cutting Method: Stack Rotation 3-Direction or 1-Direction Cut Finished Book Size Width: 8 to 11.62 Length: 5.37 to 8.5 Body Paper Weight: 14 lb. Bond to 90 lb. Index Cover Weight: 24 lb. Bond to 110 lb. Cover Book Thickness: 10 to 200 Sheets Glue Warm-Up Time: 440 Seconds Trim Range: Adjustable in .0197 (0.5mm) Increments Side: 0.26 to 1.94 Top and Bottom: 0.52 to 3.11 Dimensions (H x W x D): 51.25 x 36.97 x 31.12 Weight: 674.6 lb. Power Source: 208V/15A |
Document Inserters
Description | Multi-Drawer Document Insertion Unit-A1 (Opt.) |
Paper Weight | 14 lb. Bond to 110 lb. Cover |
Feeder Capacity |
4,000 Sheets (1,000 x 2 + 2,000) (20 lb. Bond) Dimensions (H x W x D): 43.12 x 42.5 x 31.25 Weight: 554 lb. Power Source: 120V/15AProfessional Puncher and Integration Unit-B1 (Opt.) Paper Size: Letter, Tab Supported Media Weights: 20 lb. Bond to 80 lb. Cover Productivity: Up to 135 ppm (Depends on Speed of Marking Engine) Chip Tray Capacity: 25,000 Sheets Punch Patterns: 3H, 5H, Velo Bind 11H, Plastic Comb, 19H, Twin Loop 21H/32H, ProClick 32H, Color Coil 44H Power Source: 120V/15A Dimensions (H x W x D): 41 x 22.5 x 31.25 Weight: 258.5 lb. |
Paper Folding
Description | Paper Folding Unit-F1 (Opt.) |
Fold Type |
Z-fold: 11 x 17, Legal, Letter-R C/V/Accordian Fold: Letter-R Double Parallel Fold: Letter-R, Legal Supported Media Weights: 14 lb. Bond to 28 lb. Bond Power Source: From Finisher Dimensions (H x W x D): 46.87 x 13.25 x 31.25 Weight: 157 lb.* System Upgrade RAM-B1 required for 600 dpi color scanning ** Combined weight of the POD Deck-C1 and Secondary POD Deck-C1 *** Requires either the imagePRESS 1135+ or the imagePRESS 1125+ to connect three (3) POD Decks. Combined weight of the POD Deck-C1 and Secondary POD. Deck-C1 (2) 890mm when the extension tray is pulled out for Saddle Finisher-AF1. 1060mm when the extension tray is pulled out for Saddle Finisher-AF2. Only one additional High Capacity Stacker-E1 attaches to the imagePRESS 1110P. Requires either the Finisher-AF1 or the Saddle Finisher-AF2. |
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
