Canon Support for imagePRESS C10000VP / C8000VP | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
High Capacity Stacker-H1 Operation guide
File Name
MFPP A1 User manual
File Name
PRISMAsync iPR C10000VP-A1 Safety guide
File Name
imagePRESS Server B5000-B4000 manual
File Name
imagePRESS C10000VP/C8000VP eManual
SELECT ERROR CODE
Model Name | imagePRESS C10000VP/C8000VP |
Type | Electrophotography |
Printing Resolution | Up to 2400 x 2400 dpi |
Maximum Original Size | 13" x 19.2" Minimum Paper Size 7.2" x 7.2" |
Standard Paper Capacity | Up to 2,000 sheets |
Maximum Paper Capacity | Up to 10,000 sheets |
Power Requirements | 3-Phase 208V/30A + Single Phase 208V/20A |
Dimension | 57.3" x 101.8" x 45.4" |
Duplexing
Paper Weight | 16 lb bond to 130 lb Cover (60-350 gsm) Auto Duplex Max Paper Weight Up to 130lb Cover (350 gsm) Print Speed (Color & B&W) | imagePRESS C10000VP/C8000VP LTR Up to 100ipm / Up to 80ipm 11"x17" Up to 56.2ipm / Up to 43.1ipm 12"x18" Up to 53.5ipm / Up to 40.9ipm 13"x19" Up to 51ipm / Up to 38.9ipm |
Feeders
Description | Single-pass duplex document feeder and black & white/color scanner (DADF) |
Scan Method | Automatic Paper Size Detection: Statement, Letter, Legal , 11" x 17" Resolution: up to 600 x 600 dpi |
Scanning Speed | Simplex: 600dpi BW: 120ipm CL: 70ipm 300dpi BW: 120ipm CL: 120ipm Duplex: 600dpi BW: 120ipm CL: 70ipm 300dpi BW: 200ipm CL: 140ipm |
Capacity | 300 sheets (20 lb bond) |
Paper Weight | 16lb bond to 80lb cover (60-216gsm) |
Power Source | From main unit |
Paper Supply Options
Description | POD Deck-D1 (Optional) Air Assist, Air Suction |
Paper Capacity | up to 4,000 sheets |
Paper Size | 7.2" x 7.2" - 13" x 19.2" |
Paper Weight | 16 lb bond to 130 lb Cover (60-350 gsm) |
Power Source | 208V/15A |
Dimensions | 43.1"x38.7"x31.2" |
Description | Secondary POD Deck-D1* (Optional) Air Assist, Air Suction |
Power Source | From POD Deck D1 |
Dimensions | 43.1"x31.9"x31.2" |
Description | POD Deck Lite-C1 Air Assist |
Paper Capacity | up to 3,500 sheets |
Power Source | 120V/15A |
Dimensions | 22.4"x25.8"x27.0" |
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
