Canon Support for imageRUNNER 1643P | Canon U.S.A., Inc.
imageRUNNER 1643P
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
imageRUNNER 1643 Series Brochure
imageRUNNER 1643P | |
MAIN UNIT | |
TYPE | Monochrome Laser Printer |
CORE FUNCTIONS | Print |
PROCESSOR | Canon Dual Custom Processor2 (Shared) |
OPERATION PANEL | 5-Line LCD Panel |
MEMORY | 1.0 GB RAM |
INTERFACE CONNECTION2 | 1000Base-T/100Base-TX/10-Base-T Others (Standard): USB 2.0 (Host) x3, USB 2.0 (Device) x1 |
PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: 550-sheet Paper Cassette, 100-sheet Stack Bypass Optional: 550-sheet PAPER FEEDER PF-C1 (up to 3) Maximum: 2,300 Sheets |
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) | Maximum: 150 Sheets |
SUPPORTED MEDIA SIZES | Cassette: Letter, Legal, Statement, Executive Bypass: Letter, Legal, Statement, Executive, Custom size (3" x 5" to 8-1/2" x 14"), Envelope (C5/DL/ COM-10/Monarch) |
SUPPORTED MEDIA WEIGHTS | Cassette: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2) Bypass: 16 lb. Bond to 73 lb. Cover (60 to 199 g/m2) |
PRINT SPEED (BW AND COLOR) | Up to 45 ppm (Letter); Up to 36 ppm (Legal) |
WARM-UP TIME | From Power On: 30 Seconds or Less3 From Sleep Mode: 3 Seconds or Less |
DIMENSIONS (W x D x H) | 16-1/8” x 14-13/16” x 10-13/16” (409 mm x 376 mm x 275 mm) |
INSTALLATION SPACE (W x D x H) | 24-5/16” x 43-7/16” (617 mm x 1104 mm) |
WEIGHT4 | Approx. 25.3 lb. (11.5 kg) |
PRINT SPECIFICATIONS | |
FIRST-PRINT-OUT TIME (LTR) | Approx. 5.7 Seconds |
PRINT RESOLUTION (dpi) | 600 × 600 |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II LT, PCL®5e/6, Adobe® PS® 3 (Standard on 1643iF/1643P, optional on 1643i) Optional: Barcode Printing Kit |
DIRECT PRINT | Supported File Types: TIFF, JPEG, PDF and XPS (only LPR) Available from USB memory, LPR |
OPERATING SYSTEM | Windows 10/8.1/7 (32/64 bit), Windows Server (2019/2016/2012 R2 (64 bit)/2012 (64 bit)/ 2008 R2 (64 bit) /2008 (32/64 bit), Mac® (OS X 10.6 and later => 10.9 , 10/14) Linux (Web Distribution) |
PRINT FEATURES | Suspend Job Timeout, Profile Settings, Secure Print, Header/ Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Front/ Back Covers, Toner Reduction, Poster Printing |
STORE SPECIFICATIONS | |
MEMORY MEDIA | Standard: USB |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard: Department ID Optional: uniFLOW and uniFLOW Online |
NETWORK | Standard: IP/Mac Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6 |
DOCUMENT | Standard: Secure Print |
ENVIRONMENTAL SPECIFICATIONS | |
POWER REQUIREMENTS | 120-127 V, 60 Hz, 7.1 A |
PLUG (MAIN UNIT) | NEMA 5-15P |
POWER CONSUMPTION | Maximum: Approx. 1370W Sleep Mode: 1.9 W5 Typical Electricity Consumption (TEC) Rating6 0.50 kWh |
STANDARDS | ENERGY STAR® Certified Rated EPEAT® Silver1 |
CONSUMABLES | |
TONER | Toner T06 Black |
TONER YIELD (ESTIMATED @ 5% COVERAGE) | 20,500 Images (Estimated Yield @ ISO 19752 Coverage) |
FOOTNOTES | |
ADDITIONAL SUPPORT
CONTACT US
