Canon Support for imageRUNNER 1670F | Canon U.S.A., Inc.
imageRUNNER 1670F
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Model Name | imageRUNNER 1670F |
Type | Digital, Multifunction Imaging System |
Imaging System | Indirect Electrostatic Transfer |
Developing System | Dry Monocomponent Toner Projection |
Fixing System | Canon RAPID Fusing System |
Duty Cycle | Up to 20,000 impressions/month |
Image Server Memory | 16MB Standard/Max |
Max Copy Reservation | Up to memory capacity |
Scanning Resolution | 600 dpi x 600 dpi |
Printing Resolution | 600 dpi x 600 dpi |
Interpolated Resolution | 1200 dpi x 600 dpi (Copy) 2400 dpi x 600 dpi (Print) |
Halftone | 256 Gradations of Gray |
Letter | 16 cpm/ppm |
First Copy Time | 13 Seconds |
Multiple Copies | 1-99 |
Magnification | 50%-200%, in 1% increments |
Preset Reductions | 50%, 64%, 78% |
Preset Enlargements | 129%, 200% |
Acceptable Originals | Sheets, Books, 3 Dimensional Items (up to 4.4 lbs.) |
Maximum Original Size | 8-1/2"x14" |
Standard Paper Capacity | 1 x 500 Sheets |
Manual Bypass | 100 Sheets |
Maximum Paper Capacity | 600 Sheets |
Acceptable Paper Weights
Cassette | 17-20 lb. Bond |
Bypass | 15-32 lb. Bond |
Warm Up Time | 4.5 Seconds (From Power Plug-in) 1 Second (From Energy Saver Mode) |
Power Requirements | 120V/60Hz, 3.8A |
Dimension | 15-1/8" x 18-3/4" x 17-3/8" (384mm x 475mm x 442mm) |
Weight | 52.9 lb. |
Toner | GPR-10 Black Toner |
Estimated Toner Yield | 5,300 Images |
Drum | GPR-10 Drum Unit |
Estimated Drum Yield | 24,000 Impressions |
Feeders
Description | Automatic Document Feeder (Standard) |
Acceptable Originals | Statement to Legal |
Capacity | 30 Sheets |
Paper Weights | 14-32 lb. Bond |
Power Source | Directly from Main Unit |
ADDITIONAL SUPPORT
CONTACT US
