Canon Support for imageRUNNER 1750 | Canon U.S.A., Inc.
imageRUNNER 1750
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Model Name | imageRUNNER 1750 |
Type | Digital Multifunction Imaging System Functions: Standard: Copy, Print (UFR II LT), Scan, Send Optional: Print (PCL, PostScript 3 Emulation), Fax Operation Panel: 5.7" QVGA Black-and-White LCD Touch-Screen |
Image Server Memory | Standard/ Maximum: 512MB RAM Network Interface Connection: Ethernet 10/100Base-TX Other Interface: Standard: USB 2.0 (Host)x1, USB 2.0 (Device)x1 |
Letter | Up to 52 ppm |
First Copy Time | 5.0 Seconds |
Multiple Copies | 1 to 999 |
Magnification | 25% - 400% (1% Increments) |
Preset Reductions | 25%, 50%, 64%, 78% |
Preset Enlargements | 129%, 200%, 400% |
Standard Paper Capacity | (20 lb. Bond): 550-sheet Paper Cassette 100-sheet Stack Bypass Optional: 550-sheet Paper Cassette (up to three) |
Maximum Paper Capacity | 2,300 Sheets |
Output Sizes
Cassette | Cassette 1/3/4: Legal, Letter, Statement, Executive Cassette 2: Legal, Letter, Statement, Executive, Envelopes (COM10 No.10/Monarch/ DL/ISO-B5/ISO-C5)Δ* |
Bypass | Legal, Letter, Statement, Executive, Envelopes (COM10 No.10/Monarch/DL/ ISO-B5/ISO-C5), Custom Size [3-15/16" to 8-1/2" x 5-9/16" to 14-1/8" (99mm to 216mm x 140mm to 356mm)] |
Acceptable Paper Weights
Cassette | 17 lb. Bond to 28 lb. Bond |
Bypass | 17 lb. Bond to 34 lb. Bond |
Duplexing | Paper Size: Standard Automatic Trayless Duplexing (Statement to Legal) Paper Weight: 17 lb. Bond to 28 lb. Bond |
Warm Up Time | From Power On: 30 Seconds or Less From Sleep Mode: 10 Seconds or Less |
Exposure Control | Automatic or Manual (9 Levels) |
Power Requirements | 120V AC, 60Hz, 9.3A Plug: NEMA 5-15P Power Consumption: Maximum: 1.5kW or Less; Sleep Mode: 1W |
Dimension | 24-7/8" x 22-1/8" x 19-3/4" Installation Space (W x D): 37-1/8" x 37-3/4" (with no optional equipment attached) 50-1/4" x 37-3/4" (with the optional Staple Finisher-H1 attached) |
Weight | Approximately 97.7 lb.** |
Estimated Toner Yield | 15,100 Images @ 6% Coverage Basic Copy Features Preset R/E Ratios by Area, Finishing, Two-sided, Exposure Adjustment, Original Type Selection Special Copy Features Image Combination, Frame Erase, Different Size Original, Sharpness, Mode Memory, ID Card Copy Scan Specifications Network TWAIN Scan Standard Network Scan Utility Color Network Scan Gear Security Specifications Department ID Management, User ID Management, IPv6, Restricting Features (Restricting New Addresses on Address Book, Address Book Password, Allow Fax Driver TX, Restrict Recall, Confirm Entered Fax Numbers, Restrict Sequential Broadcast, Restrict USB Interface), Memory Lock, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, IEEE802.1x, Authentication Feature for Send Operation (ASend), uniFLOW Serverless Secure Printing•, Secured Print••Environmental Information RoHS Compliant Blue Angel Mercury-free |
Feeders
Description | Duplexing Automatic Document Feeder |
Acceptable Originals | Letter, Statement-R, Legal |
Scanning Speed | 52/52 ipm (300 dpi) |
Paper Weights | BW Originals: 13 lb. Bond to 34 lb. Bond Color Originals: 17 lb. Bond to 34 lb. Bond |
Description | Cassette Module-Y1* |
Acceptable Originals | Legal, Letter, Statement, Executive Acceptable Paper Type: Plain, Recycled, Color, 3-hole Punch, Heavy Paper (24 lb. Bond to 28 lb. Bond) |
Capacity | 550 Sheets x 1 Cassette (20 lb. Bond) |
Paper Weights | 17 lb. Bond to 28 lb. Bond |
Dimensions | 4-3/4" x 21-1/4" x 19-3/4"◊◊ |
Weight | Approximately 17 lb |
ADDITIONAL SUPPORT
CONTACT US
