Canon Support for imageRUNNER ADVANCE 4535i II | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
imageRUNNER ADVANCE 4500i II Series Spec Sheet
MAIN UNIT
TYPEMonochrome Laser Multifunctional
CORE FUNCTIONSStandard:Print, Copy, Scan, Send, Store
Optional:Fax
PROCESSORCanon Dual Custom Processor (Shared)
CONTROL PANEL 10.1" TFT LCD WSVGA Color Touch-panel
MEMORY 3.0 GB RAM
HARD DISK DRIVE Standard:250 GB
Maximum:1 TB
MIRRORING HARD DISK DRIVEOptional (250 GB, 1 TB)
Method:Raid1
PRINT RESOLUTION1200 dpi x 1200 dpi
INTERFACE CONNECTION NetworkStandard:1000Base-T/100Base-TX/10Base-T,Wireless LAN (IEEE 802.11 b/g/n)
Optional:NFC, BluetoothOthersStandard:USB 2.0 x2 (Host), USB 3.0 x1 (Host),USB 2.0 x1 (Device)
Optional:Serial Interface, Copy Control Interface
PAPER CAPACITY (LTR, 20LB BOND) Standard:1,185 Sheets
Maximum:6,335 Sheets
PAPER SOURCES (LTR, 20LB BOND) Standard:Two 550-sheet Paper Cassettes,85-sheet Stack Bypass
Optional:Two 550-sheet Paper Cassettes (Cassette Feeding Unit-AN1), 2,450-sheet Paper Deck (High Capacity Cassette Feeding Unit-B1), 2,700-sheet Paper Deck (Paper Deck Unit-F1)
PAPER OUTPUT CAPACITY (LTR, 20LB BOND) Standard:250 Sheets
Maximum:3,350 Sheets (with External Finishers)
FINISHING CAPABILITIES Standard:Collate, GroupWith Inner Finisher:Collate, Group, Offset, Staple,Hole Punch,1 Staple-Free Staple,Staple On DemandWith External Finisher:Collate, Group, Offset, Staple, Booklet,2 Staple-Free Staple, Staple On Demand, Hole Punch3
SUPPORTED MEDIA TYPES Paper Cassettes:Thin, Plain, Recycled, Color, Heavy,Pre-punched
Stack Bypass:Thin, Plain, Recycled, Color, Heavy,Pre-punched, Bond, Transparency,Label, Envelope
SUPPORTED MEDIA SIZES Paper Cassettes:Thin, Plain, Recycled, Color, Heavy,Pre-punched
SUPPORTED MEDIA WEIGHTS Paper Cassettes:16 lb. Bond to 34 lb. Bond (60 to 128 g/m2)
Stack Bypass:14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
Duplexing:16 lb. Bond to 28 lb. Bond (60 to 105 g/m2)
WARM-UP TIME From Power On:24 Seconds or Less
From Deep Sleep Mode:10 Seconds or Less
Quick Startup Mode:4 Seconds4
DIMENSIONS (W X D X H) 23-1/8" x 29-1/8" x 47" (587 mm x 740 mm x 1,193 mm)5
INSTALLATION SPACE (WXD) Basic [With ADF (Stack Bypass and Cassette Drawers Open)]: 35" x 46-1/2" (889 mm x 1,182 mm)
Fully Configured [With ADF+Paper Deck Unit-F1+Booklet Finisher-Y1 (Cassette Drawers Open)]:
71-3/8" x 50-3/8" (1,811 mm x 1,280 mm)
WEIGHT Approx. 240.7 lb. (109.2 kg)6
PRINT SPECIFICATIONS
PRINT SPEED Up to 35 ppm (Letter)
Up to 32 ppm (Letter-R)
Up to 25 ppm (Legal)
Up to22 ppm (11" x 17")
STANDARD PAGE DESCRIPTION LANGUAGES UFR II, PCL®6, Adobe® PS® 3
DIRECT PRINT Available from USB, Advanced Box, Remote UI,and Web Access (Opt.)7
SUPPORTED FILE TYPES PDF, TIFF, JPEG, EPS, XPS
PRINTING FROM MOBILE DEVICES AND CLOUD-BASED SERVICES A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet-connected devices and cloud-based services depending on your requirements.
FONTS PCL fonts:93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),8 Barcode Fonts9
PS fonts:136 Roman
OPERATING SYSTEM10 UFRII:Windows Vista®/Server 2008/Windows® 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7 or later)
PCL:Windows Vista/Server 2008/Windows 7/Server 2008 R2/Server 2012/Server 2012 R2/Windows 10/Server 2016
PS:Windows Vista/Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7 or later)
PPD:MAC OS X (10.3.9 or later), Windows Vista/Windows 7/Windows 8/Windows 8.1/Windows 10
PRINT FEATURES Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing
COPY SPECIFICATIONS
COPY SPEED Up to 35 ppm (Letter)
FIRST-COPY-OUT-TIME As fast as 3.8 seconds
COPY RESOLUTION Reading:Up to 600 x 600
Printing:1200 x 1200
MULTIPLE COPIES Up to 999 Copies
COPY EXPOSURE Automatic or Manual (9 Levels)
MAGNIFICATION 25%-400% (1% Increments)
PRESET REDUCTIONS 25%, 50%, 64%, 73%, 78%
PRESET ENLARGEMENTS 121%, 129%, 200%, 400%
BASIC COPY FEATURES Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel
SPECIAL COPY FEATURES Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing
SCAN SPECIFICATIONS
TYPE Optional Single Pass DuplexingAutomatic Document Feeder orDuplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY Single Pass DADF-A1: 150 Sheets (20 lb. Bond)
DADF-AV1: 100 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS Single Pass DADF-A1BW Original:13 lb. Bond to 58 lb. Cover(50 to 157 g/m2)
CL Original:17 lb. Bond to 58 lb. Cover(64 to 157 g/m2)
DADF-AV1BW Original:13 lb. Bond to 34 lb. Bond(50 to 128 g/m2)
CL Original:17 lb. Bond to 34 lb. Bond(64 to 128 g/m2)
PLATEN ACCEPTABLE ORIGINALS Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)]
PULL SCAN Color Network ScanGear2 for both Twain and WIA
Supported OS:Windows Vista/7/8.1/10Windows Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/Server 2016
SCAN RESOLUTION 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200,200 x 100, 150 x 150, 100 x 100
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES A range of solutions is available to provide scanning tomobile devices and cloud-based services depending onyour requirements.
SCAN SPEED (LETTER) Single Pass DADF-A1Single-sided ScanningBW: 80 ipm (300 dpi)/80 ipm (600 dpi)
Color: 80 ipm (300 dpi)/60 ipm (600 dpi)
Double-sided ScanningBW: 160 ipm (300 dpi)/150 ipm (600 dpi)
Color: 160 ipm (300 dpi)/80 ipm (600 dpi)
DADF-AV1Single-sided ScanningBW: 70 ipm (300 dpi)/51 ipm (600 dpi)
Color: 70 ipm (300 dpi)/51 ipm (600 dpi)
Double-sided ScanningBW: 35 ipm (300 dpi)/25.5 ipm (600 dpi)
Color: 35 ipm (300 dpi)/25.5 ipm (600 dpi)
SEND SPECIFICATIONS
DESTINATION E-mail/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional)
COLOR MODE Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White),Full color, Grayscale, and Black-and-White
ADDRESS BOOK LDAP (2,000)/Local (1,600)/Speed dial (200)
SEND RESOLUTION 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200,200 x 100, 150 x 150, 100 x 100
COMMUICATION PROTOCOL File:FTP, SMB v3.0, WebDAVE-mail/I-Fax:SMTP, POP3, I-Fax (Simple, Full)
FILE FORMAT Standard:TIFF, JPEG, PDF (Encrypted, Compact, Searchable, Apply Policy, Optimize for Web, PDF A/1-b), XPS (Compact, Searchable),Office Open XML (PowerPoint®, Word), Digital Signature (PDF/XPS)
Optional:PDF (Trace & Smooth)
UNIVERSAL SEND FEATURES Original Type Selection,Two-sided Original, Book to Two Pages, Different-size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, E-mail Priority, TX Report, Original Content Orientation, Skip Blank Originals, Detect Feeder Multi Sheet Feed
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES 4
MODEM SPEED Super G3:33.6 Kbps
G3:14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE Statement-R to 11" x 17"
FAX MEMORY Up to 30,000 Pages
SPEED DIALS Max. 200
GROUP DIALS / DESTINATIONS Max. 199 Dials
SEQUENTIAL BROADCAST Max. 256 Addresses
MEMORY BACKUP Yes
FAX FEATURES Original Type Selection, Two-sided Original, Book to Two Pages, Different-size Originals, Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Sender's Name (TTI), Select Line, Selecting the Telephone Line (when sending fax), Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, TX Report, Detect Feeder Multi Sheet Feed
STORE SPECIFICATIONS
MAIL BOX SIMPLE(NUMBER SUPPORTED) 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored
ADVANCED BOX Communication Protocol: SMB or WebDAV
SupportedClient PC:Windows (Windows Vista/7/8/8.1/10)
Concurrent Connections (Max.) SMB:64WebDAV:3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACE Approx. 16 GB (Standard HDD)
Approx. 480 GB (1 TB HDD)
ADVANCED BOX FEATURES Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
MEMORY MEDIA Standard: USB
SECURITY SPECIFICATIONS
AUTHENTICATION Standard:Universal Login Manager, uniFLOWOnline Express,11,12 User Authentication,Department ID Authentication,Access Management System,Device and Function Level Log-in
Optional:uniFLOW
DATA Standard:Trusted Platform Module (TPM),Hard Disk Password Lock, Hard DiskDrive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated)
Optional:Hard Disk Drive Mirroring, Hard Disk Drive removal, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW)
NETWORK Standard:Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP
DOCUMENT Standard:Secure Watermark, Secure Print, Forced Hold Printing, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signatures
Optional:User Signatures, Document Scan Locking
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT Temperature:50 to 86ºF
Humidity:20 to 80% RH (no condensation)
POWER REQUIREMENTS 120-127 V AC, 60 Hz, 9.3A
PLUG (MAIN UNIT) NEMA 5-15P
POWER CONSUMPTION Maximum:Approx. 1.5 kWh
Standby:Approx. 38 W
Sleep Mode:Approx. 0.9 W13
Typical Electricity Consumption (TEC) Rating: 1.8 kWh
STANDARDS ENERGY STAR® Certified
Rated EPEAT® Gold14
RoHS Compliant
CONSUMABLES
TONER GPR-57 Toner
TONER YIELD (ESTIMATED @ 6% COVERAGE) Black:42,100 Images
FOOTNOTES
1 Requires the optional Inner 2/3 Hole Puncher-C1.
2 Booklet Finisher-Y1 only.
3 Requires the optional 2/3 Hole Puncher Unit-A1.
4 Time from device power-on to when copy jobs can be programmed.
5 Includes Main Unit, Single Pass DADF-A1, and Cassette Feeding Unit-AN1.
6 Includes Main Unit, Single Pass DADF-A1, Cassette Feeding Unit-AN1, and consumables.
7 PDF print from Web sites is supported.
8 Requires the optional PCL International Font Set-A1.
9 Requires the optional Barcode Printer Kit-D1.
10 Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
11 No charge for this solution; however activation is required.
12 Check for availability.
13 0.9 W Sleep mode is not available in all circumstances due to certain settings.
14 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
SUPPLIES & ACCESSORIES
