Canon Support for imageRUNNER ADVANCE 6565i III | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
imageRUNNER ADVANCE 6500 III Series Spec Sheet
imageRUNNER ADVANCE 6565i III | |
MAIN UNIT | |
TYPE | Monochrome Laser Multifunctional |
CORE FUNCTIONS | Standard: Print, Copy, Scan, Send, Store |
PROCESSOR | Canon Dual Custom Processor (Shared) |
CONTROL PANEL | Standard: 10.1" TFT LCD WSVGA Color Flat- panel |
MEMORY | 3.0 GB RAM |
HARD DISK DRIVE | Standard: 250 GB |
MIRRORING HARD DISK DRIVE | Optional (250 GB, 1 TB), Method: Raid1 |
INTERFACE CONNECTION | Network Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n) Optional: NFC, Bluetooth Low Energy Others Standard: USB 2.0 x2 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device) Optional: Serial Interface, Copy Control Interface |
PAPER CAPACITY (LETTER, 20 LB. BOND) | Standard: 4,200 Sheets |
PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: Dual 1,500-sheet Paper Drawers, Dual 550-sheet Paper Cassettes, 100-sheet Stack Bypass |
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) | With Copy Tray: 250 Sheets |
FINISHING CAPABILITIES | With External Finishers: Collate, Group, Offset, Staple, Staple On Demand, Staple-free Staple, Booklet, Hole Punch, Document Insertion, C and Z Folding |
SUPPORTED MEDIA TYPES | Paper Drawers (1/2): Thin, Plain, Recycled, Color, Heavy, Pre-punched, Letterhead, Bond |
SUPPORTED MEDIA SIZES | Paper Drawers (1/2): Letter |
SUPPORTED MEDIA WEIGHTS | Paper Decks/Cassettes: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) |
WARM-UP TIME | From Power On: Approx. 30 Seconds2 |
DIMENSIONS (W x D x H) | 26-3/8" x 30-5/8" x 48" (670 mm x 779 mm x 1220 mm) |
INSTALLATION SPACE (W x D x H) | Basic: Stack Bypass Extended+ Cassette Drawers open + Copy Tray: 60-3/8" x 53-1/4" (1533 mm x 1353 mm) |
WEIGHT | Approx. 515.9 lb. (234 kg)5 |
PRINT SPECIFICATIONS | |
PRINT / COPY SPEED (BW AND COLOR) | Up to 65 ppm (Letter) |
PRINT RESOLUTION (dpi) | 1200 x 1200, 600 x 600 |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR III, PCL¿6, Adobe¿ PS¿ 3 |
DIRECT PRINT | Available from USB, Advanced Box, Remote UI, and Web Access6 |
SUPPORTED FILES | PDF, TIFF, JPEG, EPS,7 XPS |
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES | A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet-connected devices and cloud-based services depending on your requirements. |
FONTS | PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese)8, Barcode Fonts9 |
OPERATING SYSTEM 10 | UFRIII: Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.9 or later) |
PRINT FEATURES | Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Watermark, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Front/Back Covers, Toner Reduction, Poster Printing |
COPY SPECIFICATIONS | |
FIRST-COPY-OUT-TIME | As fast as 3.3 seconds |
COPY RESOLUTION | Reading: 600 x 600 |
MULTIPLE COPIES | Up to 9,999 Copies |
COPY EXPOSURE | Automatic or Manual (9 Levels) |
MAGNIFICATION | 25%-400% (1% Increments) |
PRESET REDUCTIONS | 25%, 50%, 64%, 73%, 78% |
PRESET ENLARGEMENTS | 121%, 129%, 200%, 400% |
BASIC COPY FEATURES | Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, |
SPECIAL COPY FEATURES | Book to Two Pages, Two-sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Print on Tab, Store in Mail Box, Superimpose Image, Cascade Copy, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original, Skip Blank Originals |
SCAN SPECIFICATIONS | |
TYPE | Color Platen and Single-pass Duplexing Automatic |
DOCUMENT FEEDER PAPER CAPACITY | 300 Sheets (20 lb. Bond) |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES | 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R |
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | BW Original: 13 lb. Bond to 80 lb. Cover (50 to 220 g/m2) |
PLATEN ACCEPTABLE ORIGINALS | Sheet, Book, 3-Dimensional Objects [Height: up to 2" (50 mm), Weight: up to 4.4 lb. (2 kg)] Max. Platen |
PULL SCAN | Color Network ScanGear2 for both Twain and WIA Supported OS: Windows 7/8.1/10 Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/Server 2016 |
SCAN RESOLUTION | 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, |
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements. |
SCAN SPEED (LETTER) | Single-sided Scanning |
SEND SPECIFICATIONS | |
DESTINATION | Email/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional) |
COLOR MODE | Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White), Full color, Grayscale, and Black-and-White |
ADDRESS BOOK | LDAP (2,000)/Local (1,600)/Speed dial (200) |
SEND RESOLUTION | 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100 |
COMMUICATION PROTOCOL | File: FTP, SMB v3.0, WebDAV |
FILE FORMAT | Standard: TIFF, JPEG, PDF (Compact, Searchable, Apply policy, Optimize for Web, PDF A/1-b, Encrypted, Device Signature), XPS (Compact, Searchable, Device Signature), Office Open XML (PowerPoint, Word) |
UNIVERSAL SEND FEATURES | Original Type Selection,Two-sided Original, Book to Two Pages, Different-size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Job Done Notice, File Name, Subject/Message, Reply-to, Email Priority, TX Report, Original Content Orientation, Skip Blank Originals, Multi Sheet Feed Detection |
FAX SPECIFICATIONS | |
MAXIMUM NUMBER OF LINES | 4 |
MODEM SPEED | Super G3: 33.6 Kbps |
COMPRESSION METHOD | MH, MR, MMR, JBIG |
RESOLUTION | 400 x 400, 200 x 400, 200 x 200, 200 x 100 |
SENDING / RECORDING SIZE | Statement-R to 11" x 17" |
FAX MEMORY | Up to 30,000 Pages |
SPEED DIALS | Max. 200 |
GROUP DIALS / DESTINATIONS | Max. 199 Dials |
SEQUENTIAL BROADCAST | Max. 256 Addresses |
MEMORY BACKUP | Yes |
FAX FEATURES | Original Type Selection, Two-sided Original, Book to Two Pages, Different-size Originals, Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Sender's Name (TTI), Selecting the Telephone Line, Direct Send, Delayed Send, Preview, Job Done Notice, TX Report, Multi Sheet Feed Detection |
STORE SPECIFICATIONS | |
MAIL BOX SIMPLE (NUMBER SUPPORTED) | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored |
ADVANCED BOX | Communication Protocol: SMB or WebDAV |
ADVANCED BOX AVAILABLE DISC SPACE | Approx. 16 GB (Standard HDD) |
ADVANCED BOX FEATURES | Authentication for Advanced Box Log-in, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
MEMORY MEDIA | Standard: USB |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard: Universal Login Manager, uniFLOW Online Express,11 User Authentication, Department ID Authentication, (Device and Function Level Log-in), Access Management System |
DATA | Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated), Verify System at Startup, McAfee Embedded Control12 |
NETWORK | Standard: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration |
DOCUMENT | Standard: Secure Watermark, Secure Print, Adobe LiveCycle¿ Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signature |
ENVIRONMENTAL SPECIFICATIONS | |
OPERATING ENVIRONMENT | Temperature: 50 to 86 ºF |
POWER REQUIREMENTS | 120-127 V AC, 60 Hz, 16 A |
PLUG (MAIN UNIT) | NEMA 5-20P |
POWER CONSUMPTION | Maximum: Approx. 2,032 W |
CONSUMABLES | |
TONER | GPR-38 Black Toner |
TONER YIELD (ESTIMATED @ 6% COVERAGE) | 56,000 Images |
FOOTNOTES | |
