Canon Support for imageRUNNER ADVANCE C350P | Canon U.S.A., Inc.
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Model Name | imageRUNNER ADVANCE C350P |
Type | Digital Laser Printer |
Functions | Print (UFR II, PCL 5c/6, Adobe® PostScript® 3™) |
Operation Panel | 7" WVGA Full-Color TFT Screen |
Image Server Memory | Standard: 2 GB RAM Maximum: 2 GB RAM |
Hard Disk Drive | Standard: 80 GB Maximum: 80 GB |
Network Interface Connection | Ethernet 10/100/1000Base-TX |
Other Interface | USB 2.0 x3 (Host), USB 2.0 (Device) Print Speed (BW/Color) Letter: Up to 36/36 ppm Legal: Up to 29/29 ppm |
Special Media Support | Thin [16 lb. Bond (60 to 63 g/m2)], Plain 1 [17 lb. Bond to 20 lb. Bond (64 to 75 g/m2)], Plain 2 [21 lb. Bond to 24 lb. Bond (76 to 90 g/m2)], Plain 3 [25 lb. Bond to 28 lb. Bond (91 to 105 g/m2)], Recycled 1 [17 lb. Bond to 20 lb. Bond (64 to 75 g/m2)], Recycled 2 [21 lb. Bond to 24 lb. Bond (76 to 90 g/m2)], Recycled 3[(25 lb. Bond to 28 lb. Bond (91 to 105 g/m2)], Color [17 lb. Bond to 20 lb. Bond (64 to 75 g/m2)], Heavy 1 [29 lb. Bond to 34 lb. Bond (106 to 128 g/m2)], Heavy 2 [35 lb. Bond to 60 lb. Cover (129 to 163 g/m2)], Heavy 3 [61 lb. Cover to 80 lb. Cover [164 to 220 g/m2)], Transparency [32 lb. Bond to 80 lb. Cover (121 to 220 g/m2)], Pre-punched [17 lb. Bond to 20 lb. Bond (64 to 75 g/m2)], Bond [24 lb. Bond (90 g/m2)], Labels [31 lb. Bond to 59 lb. Cover (118 to 160 g/m2)], Envelopes |
Warm Up Time | Quick Startup Mode: 10 Seconds** From Sleep Mode: 10 Seconds From Power On: 70 Seconds |
Power Requirements | 120 V, 60 Hz, 6.9 A |
Power Consumption | Maximum: 1.5 kW Sleep Mode: 1 W |
Plug | NEMA 5-15 |
Dimension | 20-2/3" x 20-1/8" x 24-1/2" (525 mm x 511 mm x 621 mm) |
Installation Space | 33-1/2" x 24-1/2" ( 852 mm x 621 mm) (When the Multipurpose Tray is extended) |
Weight | Approx. 90.3 lb. (45 kg)*** |
Environmental Features | ENERGY STAR® Qualified RoHS Compliant Blue Angel EPEAT® Rated WEEE Directive |
Advanced Box
Advanced Box Features | Print/View from Remote Advanced Box: Supported |
Memory Media
Standard | Print from USB Memory |
Output Sizes
Cassette | Legal, Letter, Statement, Executive, Custom Size [(3-7/8" x 7-1/2" to 8-1/2" x 14") (98.4 mm x 190.5 mm to 216 mm x 355.6 mm)], and Envelopes (COM10, Monarch, DL, ISO-C5)* |
Bypass | Legal, Letter, Statement, Executive, Custom Size [(3-7/8" x 5-7/8" to 8-1/2" x 14") (98.4 mm x 148 mm to 216 mm x 355.6 mm)], and Envelopes (COM10, Monarch, DL, ISO-C5) |
Acceptable Paper Weights
Cassette | 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2) |
Bypass | 16 lb. Bond to 80 lb. Cover (60 to 220 g/m2) |
Duplexing
Paper Size | Standard Automatic Trayless Duplexing (Statement to Legal) |
Paper Weight | Up to 60 lb. Cover (163 g/m2) |
Security Features
Standard | Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, IPv6, Restricting Features, SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, IEEE 802.1x (wired/wireless), HDD Initialize (Up to 9x) HDD Erase (Up to 3x), HDD Lock, IPsec, Adobe® LiveCycle® Rights Management ES2.5 Integration |
Optional | HDD Encryption, HDD Erase Scheduler, Encrypted Secured Print, Encrypted PDF, Secure Watermark, IEEE 2600.1 Common Criteria Certification,♦ imageWARE Secure Audit Manager Express, uniFLOW, AA-Print, Universal Login Manager |
Estimated Toner Yield | BW: 19,000 Copies/Bottle Color (C,M,Y): 21,500 Copies/Bottle (Estimated @ 5% Coverage) |
Paper Supply Options
Description | Cassette Feeding Unit-AG1 |
Paper Capacity | 550 Sheets [21 lb. Bond (80 g/m2)] |
Paper Size | Legal, Letter, Statement, Executive, Custom Size [3-7/8" x 7-1/2" to 8-1/2" x 14" (98.4 mm x 190.5 mm to 216 mm x 355.6 mm)] |
Paper Weight | 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2) |
Power Source | From the Main Unit |
Power Consumption | Approx. 25 W |
Dimensions | 16-3/4" x 20-1/8" x 20" (425 mm x 511 mm x 508 mm) |
Weight | Approx. 33.1 lb. (15 kg) |
Description | Cassette Feeding Unit-AH1 |
Paper Capacity | 550 Sheets x 3 Cassettes [21 lb. Bond (80 g/m2) |
Paper Size | Legal, Letter, Statement, Executive, and Custom Size [3-7/8" x 7-1/2" to 8-1/2" x 14" (98.4mm x 190.5mm to 216mm x 355.6mm)] |
Power Consumption | Approx. 35W |
Dimensions | 16-3/4" x 20-1/8" x 20" (425mm x 511mm x 508mm) |
Weight | Approx. 41.9 lb (19kg) |
