Canon Support for imageRUNNER ADVANCE C475iF III | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
imageRUNNER ADVANCE C475iF / C475iFZ III Spec Sheet
MAIN UNIT
TYPE
Color Laser Multifunctional
CORE FUNCTIONS
Print, Copy, Scan, Send, Store, Fax
PROCESSOR
Canon Dual Custom Processor (Shared)
CONTROL PANEL
10.1" TFT LCD WSVGA Color Flat-panel
MEMORY
4.0 GB RAM
HARD DISK DRIVE
250 GB
INTERFACE CONNECTION
Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n),
Optional: NFC, Bluetooth Low Energy
Others
Standard: USB 2.0 x1 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device)
Optional: Copy Control Interface
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 650 Sheets
Maximum: 2,300 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 550-sheet Paper Cassette, 100-sheet Stack Bypass
Optional: 1,650-sheet Paper Cassette (Cassette Feeding Unit-AT1) 550-sheet Paper Cassette (Cassette Feeding Unit-AS1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
Standard Model: 400 Sheets
Finisher Model: 900 Sheets (400 sheets: base tray, 400 sheets: upper tray, 100 sheets: lower tray)
FINISHING CAPABILITIES
Standard Model: Collate, Group
Finisher Model: Collate, Group, Offset, Staple
SUPPORTED MEDIA TYPES
Stack Bypass: Thin, Plain, Recycled, Heavy, Color, Bond, Envelope
Cassette: Thin, Plain, Recycled, Heavy, Color, Label, Bond
SUPPORTED MEDIA SIZES
Stack Bypass: Legal, Letter, Executive, Statement, Envelopes [No.10 (COM10), Monarch, DL, ISO-C5] Custom size: 3" x 5" to 8-1/2" x 14" (76 mm x 127 mm to 215.9 mm x 355.6 mm)
Cassette: Legal, Letter, Executive, Statement, Custom Size: 4" x 5-7/8" to 8-1/2" x 14" (101.6 mm x 148 mm to 215.9 mm x 355.6 mm)
SUPPORTED MEDIA WEIGHTS
Cassette: 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2)
Stack Bypass: 16 lb. Bond to 80 lb. Cover (60 to 216 g/m2)
Duplex: 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2)
WARM-UP TIME
From Power On: Approx. 10 Seconds1
From Sleep Mode: Approx. 10 Seconds2
Quick Startup Mode: Approx. 4 Seconds3
DIMENSIONS (W x D x H)
Standard Model: 20-1/2" x 25-3/8" x 26-3/8" (521 mm x 645 mm x 668 mm)
Finisher Model: 20-1/2" x 25-3/8" x 34" (521 mm x 645 mm x 864 mm)
DIMENSIONS (W x D x H) with Paper Feeding Unit
Standard Model: 25-1/4" x 26-3/8" x 44-1/4" (642 mm x 668 mm x 1,124 mm)
Finisher Model: 25-1/4" x 26-3/8" x 52" (642 mm x 668 mm x 1320 mm)
INSTALLATION SPACE (W x D x H)
37-3/8" x 33-1/8" (950 mm x 840 mm)
WEIGHT4
Standard Model: Approx. 101.4 lb. (46 kg)
Finisher Model: Approx. 121.3 lb. (55 kg)
PRINT SPECIFICATIONS
PRINT / COPY SPEED (BW AND COLOR)
Up to 50 (Letter), Up to 39 (Legal)
PRINT RESOLUTION (dpi)
1200 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II, PCL®6, Adobe® PS® 3
DIRECT PRINT
Available from USB, Advanced Box, Remote UI, and Web Access5
SUPPORTED FILES
PDF, TIFF, JPEG, EPS, XPS
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES
A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet connected devices and cloud-based services depending on your requirements.
FONTS
PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),6 Barcode Fonts7
PS fonts: 136 Roman
OPERATING SYSTEM 8
UFRII: Windows® 7/8.1/10, Windows Server 2008/ 2008 R2/2012/2012 R2/2016, MAC OS X (10.9 or later)
PCL: Windows 7/8.1/10, Windows Server 2008/ 2008 R2/2012/2012 R2/2016
PS: Windows 7/ 8.1/10, Windows Server 2008/ 2008 R2/2012/2012 R2/2016, MAC OS X (10.9 or later)
PPD: Windows 7/ 8.1/10, MAC OS X (10.3.9 or later)
PRINT FEATURES
Suspend Job Timeout, Profile Settings, Secured Print, Encrypted Secure Print, Watermark, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations,9 Offsetting, Toner Reduction, Poster Printing, Forced Hold Printing 9
COPY SPECIFICATIONS
FIRST-COPY-OUT-TIME
As Fast as 5.1 Seconds/5.8 Seconds
COPY RESOLUTION
600 x 600
MULTIPLE COPIES
Up to 999 Copies
COPY EXPOSURE
Automatic or Manual (9 Levels)
MAGNIFICATION
25%-400% (1% Increments)
PRESET REDUCTIONS
25%, 50%, 64%, 78%
PRESET ENLARGEMENTS
129%, 200%, 400%
BASIC COPY FEATURES
Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two- Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel
SPECIAL COPY FEATURES
Two-sided Original, Finishing, Job Build, N on 1, Different Size Originals,9 Density Adjustment, Original Type Selection, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Job Done Notice, Copy ID Card, Skip Blank Pages, Multi-Sheet Feed Detection, Adjust One-Touch Color, Color Balance
SCAN SPECIFICATIONS
TYPE
Single-pass Duplexing Automatic Document Feeder10
DOCUMENT FEEDER PAPER CAPACITY
100 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES
Legal, Letter, Statement, Custom Size: 4-1/8" x 5-7/8" to 8-1/2" x 14" (105 mm x 148 mm to 216 mm x 355.6 mm)
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
BW Original: 1-sided scanning: 12 to 33 lb. Bond (42 to 128 g/m2)
2-sided scanning: 13 to 33 lb. Bond (50 to 128 g/m2)
CL Original: 1-sided scanning: 17 to 33 lb. Bond (64 to 128 g/m2)
2-sided scanning: 17 to 33 lb. Bond (64 to 128 g/m2)
PLATEN ACCEPTABLE ORIGINALS
Sheet, Book, 3-Dimensional Objects [Height: Up to 1-1/4" (30 mm), Weight: up to 4.4 lb. (2kg)]
PULL SCAN
Color Network ScanGear2 for both Twain and WIA
Supported OS: Windows 7/8.1/10/ Server 2008/Server 2008 R2/ Server 2012/Server 2012 R2/Server 2016
SCAN RESOLUTION
600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES
A range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements.
SCAN SPEED (LETTER)
Single-sided Scanning (BW and Color): 50 ipm (300 dpi )/30 ipm (600 dpi)
Double-sided Scanning (BW and Color): 100 ipm (300 dpi)/50 ipm (600 dpi)
SEND SPECIFICATIONS
DESTINATION
Standard: E-mail/Internet Fax (SMTP), SMB v3.0, FTP, WebDAV, Mail Box, Super G3 Fax Optional: IP Fax
COLOR MODE
Automatic-Color Select (Full Color/Grayscale), Automatic- Color Select (Full Color/Black-and-White), Full color, Grayscale, and Black-and-White
ADDRESS BOOK
LDAP (2,000)/Local (1,600)/Speed Dial (200)
SEND RESOLUTION
COMMUICATION PROTOCOL
File: FTP (TCP/IP), SMB v3.0, WebDAV
Email: SMTP, POP3
FILE FORMAT
Standard: TIFF, JPEG, PDF (Compact, Searchable, Apply policy, Optimize for Web, PDF A/1-b, Encrypted, Device Signature), XPS (Compact, Searchable, Device Signature), Office Open XML (PowerPoint, Word)
Optional: PDF (Trace & Smooth, User Signature), XPS (User Signature)
UNIVERSAL SEND FEATURES
Original Type Selection, Two-sided Original, Different-size Originals,9 Density Adjustment, Sharpness, Erase Frame, Job Build, Sender's Name (TTI), Delayed Send, Preview, Job Done Notice, File Name, Subject/Message, Reply-to, E-mail Priority, TX Report, Original Content Orientation, Skip Blank Pages, Multi-Sheet Feed Detection
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES
One
MODEM SPEED
Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD
MH, MR, MMR, JBIG
RESOLUTION
400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE
Statement to Legal
FAX MEMORY
Up to 30,000 Pages
SPEED DIALS
Max. 200
GROUP DIALS / DESTINATIONS
Max. 199 Dials
SEQUENTIAL BROADCAST
Max. 256 Addresses
MEMORY BACKUP
Yes
FAX FEATURES
Original Type Selection, Two-Sided Original, Density for Scanning, Sharpness, Erase Frame, Job Build, Sender's Name (TTI), Direct Send, Delayed Send, Preview, Job Done Notice, TX Report, Multi Sheet Feed Detection
STORE SPECIFICATIONS
MAIL BOX SIMPLE (NUMBER SUPPORTED)
100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored
ADVANCED BOX
Communication Protocol: SMB or WebDAV
Supported Client PC: Windows 7/8.1/10
Concurrent Connections (Max.)
SMB: 64
WebDAV: 3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACE
Approx. 16 GB
ADVANCED BOX FEATURES
Authentication for Advanced Box Log-in, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
MEMORY MEDIA
Standard: USB
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Universal Login Manager (Device and Function Level Log-in), uniFLOW Online Express,11 User Authentication, Department ID Authentication, Access Management System
Optional: uniFLOW
DATA
Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), Verify System at Startup, McAfee Embedded Control12
Optional: IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW)
NETWORK
Standard: IP/Mac Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration
DOCUMENT
Standard: Secure Print, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device signature, Secure Watermark
Optional: User Signatures
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86 ºF
Humidity: 20 to 80 % RH (Relative Humidity)
POWER REQUIREMENTS
120-127V AC 60 Hz, 8.4 A
PLUG (MAIN UNIT)
NEMA 5-15P
POWER CONSUMPTION
Maximum: Approx. 1,500 W
Standby: Approx. 54.3 W13
Sleep Mode: Approx. 1 W14
Typical Electricity Consumption (TEC) Rating 0.54 kWh*
STANDARDS
ENERGY STAR® Certified
Rated EPEAT® Gold15
CONSUMABLES
TONER
TONER T04 BK/C/M/Y
TONER YIELD (ESTIMATED @ 5% COVERAGE)
TONER T04 BK: 33,000 pages16
TONER T04 C/M/Y: 27,500 pages16
FOOTNOTES
  1. Time from device power-on, until copy ready (not print reservation).
  2. Time from exiting Sleep mode to when printing is operational.
  3. Time from device power-on to when key operation can be performed on the touch screen.
  4. Includes consumables.
  5. PDF print from Web sites is supported.
  6. Requires the optional PCL International Font Set-A1.
  7. Requires the optional Barcode Printer Kit-D1.
  8. Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
  9. Only for Letter/Legal.
  10. Detect Feeder Multi Sheet Feed is supported.
  11. No charge for this solution; however activation is required.
  12. Requires Unified Firmware Platform v3.9.
  13. Reference value (measured one unit).
  14. 0.8 W sleep mode not available in all circumstances due to certain settings.
  15. For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
  16. Toner Cartridge yield in accordance with ISO/IEC 19798.
* Based on ENERGY STAR Product Specification for Imaging Equipment Version 3.0.
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
