Canon Support for imageRUNNER ADVANCE C7580i II | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
imageRUNNER ADVANCE C7500i II Series Spec Sheet
imageRUNNER ADVANCE C7580i II | |
MAIN UNIT | |
TYPE | Color Laser Multifunctional |
CORE FUNCTIONS | Standard:Print, Copy, Scan, Send, StoreOptional:Fax |
PROCESSOR | Canon Dual Custom Processor (Shared) |
CONTROL PANEL | Standard:10.1" TFT LCD WSVGA Color Touch-panel Optional:10.4" TFT LCD WSVGA Color Upright-panel |
MEMORY | 4.0 GB RAM |
HARD DISK DRIVE | Standard:250 GB Maximum:1 TB |
MIRRORING HARD DISK DRIVE | Optional (250 GB, 1 TB)Method:Raid1 |
PRINT RESOLUTION | 2400 dpi x 2400 dpi |
INTERFACE CONNECTION | NetworkStandard:1000Base-T/100Base-TX/10Base-T,Wireless LAN (IEEE 802.11 b/g/n) Optional:NFC, Bluetooth OthersStandard:USB 2.0 x2 (Host), USB 3.0 x1 (Host),USB 2.0 x1 (Device) Optional:Serial Interface, Copy Control Interface |
PAPER CAPACITY (LTR, 20LB BOND) | Standard:3,550 Sheets Maximum:9,300 Sheets |
PAPER SOURCES (LTR, 20LB BOND) | Standard:Two 1,100-sheet Paper Drawers,Two 550-sheet Paper Cassettes,250-sheet Stack Bypass Optional:3,500-sheet Paper Deck (Paper Deck Unit-E1), 3,500-sheet Paper Deck (Pod Deck Lite-C1), 6,000-sheet Paper Deck (Multi-Drawer Paper Deck-C1) Maximum:9,300 Sheets (With Multi-Drawer Paper Deck-C1) |
PAPER OUTPUT CAPACITY (LTR, 20LB BOND) | 250 Sheets (with Copy Tray-R2) 3,500 Sheets (with External Finisher-V2) 4,250 Sheets (with External Finisher-X1) |
FINISHING CAPABILITIES | Standard:Collate, GroupWith Finishers:Collate, Group, Offset, Staple, Booklet, Hole Punch, Staple-Free Staple, Staple On Demand, Document Insertion, Z-Fold, Accordion Z-Fold, C-Fold, Half-Fold, Double Parallel Fold, Trimming |
SUPPORTED MEDIA TYPES | Paper Drawers(1/2):Thin, Plain, Recycled, Color, Heavy,Pre-punched, Letterhead, Bond, Transparency Paper Cassettes(3/4):Thin, Plain, Recycled, Color, Heavy,Pre-punched, Letterhead, Bond, Transparency, Tab, EnvelopeStack Bypass:Thin, Plain, Recycled, Color, Heavy,Pre-punched, Labels, Letterhead,Bond, Coated, Transparency, Tab,Tracing, Envelope, Textured |
SUPPORTED MEDIA SIZES | Paper Drawers(1/2):LetterPaper Cassettes (3/4):13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch,DL, ISO-C5], Custom Size (5-1/2" x 7-1/8" to 13" x 19-1/4"), Envelope Custom Size (3-7/8" x 5-7/8" to 13" x 19-1/4") Stack Bypass:13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (4" x 5-7/8" to13" x 19-1/4"), Envelope Custom Size(3-1/2" x 5-7/8" to 13" x 19-1/4"), Free Size (4" x 7-1/8" to 13" x 19-1/4") |
SUPPORTED MEDIA WEIGHTS | Paper Drawers:14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) Paper Cassettes:14 lb. Bond to 140 lb. Index (52 to 256 g/m2) Stack Bypass:14 lb. Bond to 110 lb. Cover (52 to 300 g/m2) Duplexing:14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) |
WARM-UP TIME | From Power On:30 Seconds or Less From Deep Sleep Mode:30 Seconds or Less Quick Startup Mode:4 Seconds1 |
DIMENSIONS (W X D X H) | 27-1/8" x 37-1/8" x 48" (689 mm x 941 mm x 1,220 mm) |
INSTALLATION SPACE (WXD) | Basic [With Booklet Finisher-V2 (Stack Bypass and Cassette Drawers Open)]:75-3/8" x 60" (1,913 mm x 1,524 mm) Fully Configured [With Multi-Drawer PaperDeck-C1+Document Insertion Unit-N1+Multi Function Professional Puncher-A1+Paper Folding Unit-J1+Booklet Finisher-X1 (Cassette Drawers Open)]:150-3/8" x 60" (3,818 mm x 1,524 mm) |
WEIGHT | Approx. 595.2 lb. (270 kg)2 |
PRINT SPECIFICATIONS | |
PRINT / COPY SPEED (BW AND COLOR) | Up to 80/70 ppm (Letter); Up to 60/52 ppm (Letter-R); Up to 47/41 ppm (Legal);Up to 40/35 ppm (11" x 17") |
DATA PROCESSING RESOLUTION | Up to 1200 dpi x 1200 dpi |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, Adobe® PS® 3 |
DIRECT PRINT | Available from USB, Advanced Box, Remote UI,and Web Access3 |
SUPPORTED FILE TYPES | PDF, TIFF, JPEG, EPS,4 XPS |
PRINTING FROM MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet-connected devices and cloud-based services depending on your requirements. |
FONTS | PCL fonts:93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),5 Barcode Fonts6 PS fonts:136 Roman |
OPERATING SYSTEM8 | UFRII:Windows Vista®/Server 2008/Windows® 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7 or later) PCL:Windows Vista/Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016 PS:Windows Vista/Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7 or later) PPD:MAC OS X (10.3.9 or later), Windows Vista/Windows 7/Windows 8/Windows 8.1/Windows 10 |
PRINT FEATURES | Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing |
COPY SPECIFICATIONS | |
FIRST-COPY-OUT-TIME | As fast as 4.4 seconds (BW) /5.4 seconds (Color) |
COPY RESOLUTION | Reading:Up to 600 dpi x 600 dpi Printing:2400 dpi x 2400 dpi |
MULTIPLE COPIES | Up to 9,999 copies |
COPY EXPOSURE | Automatic or Manual (9 Levels) |
MAGNIFICATION | 25%-400% (1% Increments) |
PRESET REDUCTIONS | 25%, 50%, 64%, 73%, 78% |
PRESET ENLARGEMENTS | 121%, 129%, 200%, 400% |
BASIC COPY FEATURES | Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
SPECIAL COPY FEATURES | Book to Two Pages, Two-sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Print on Tab, Store in Mail Box, Superimpose Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original, Color Balance, Adjust One-Touch Color, Area Designation |
SCAN SPECIFICATIONS | |
TYPE | Color Platen and Single-pass Duplexing Automatic Document Feeder |
DOCUMENT FEEDER PAPER CAPACITY | 300 Sheets (20 lb. Bond) |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES | 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R |
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | BW Original:13 lb. Bond to 80 lb. Cover(50 to 220 ) CL Origg/m2inal:17 lb. Bond to 80 lb. Cover(64 to 220 g/m2) |
PLATEN ACCEPTABLE ORIGINALS | Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)] |
PULL SCAN | Color Network ScanGear2 for both Twain and WIA Supported OS:Windows Vista/7/8.1/10Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/Server 2016 |
SCAN RESOLUTION | 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100dpi |
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of solutions is available to provide scanning tomobile devices and cloud-based services depending onyour requirements. |
SCAN SPEED (LETTER) | Single-sided Scanning (BW):120 ipm (300 dpi)/120 ipm (600 dpi) Single-sided Scanning (Color):120 ipm (300 dpi)/70 ipm (600 dpi) Double-sided Scanning (BW):240 ipm (300 dpi)/150 ipm (600 dpi) Double-sided Scanning (Color):220 ipm (300 dpi)/90 ipm (600 dpi) |
SEND SPECIFICATIONS | |
DESTINATION | E-mail/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional) |
COLOR MODE | Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White),Full color, Grayscale, and Black-and-White |
ADDRESS BOOK | LDAP (2,000)/Local (1,600)/Speed dial (200) |
SEND RESOLUTION | 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi,100 x 100dpi |
COMMUICATION PROTOCOL | File:FTP, SMB 3.0, WebDAVE-mail/I-Fax:SMTP, POP3, I-Fax (Simple, Full) |
FILE FORMAT | Standard:TIFF, JPEG, PDF (Encrypted, Compact, Searchable, Apply Policy, Optimize for Web, PDF A/1-b), XPS (Compact, Searchable),Office Open XML (PowerPoint®, Word), Digital Signature (PDF/XPS) Optional:PDF (Trace & Smooth) |
UNIVERSAL SEND FEATURES | Original Type Selection,Two-sided Original, Book to Two Pages, Different-size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, E-mail Priority, TX Report, Original Content Orientation, Skip Blank Originals, Detect Feeder Multi Sheet Feed |
FAX SPECIFICATIONS | |
MAXIMUM NUMBER OF LINES | 4 |
MODEM SPEED | Super G3:33.6 Kbps G3:14.4 Kbps |
COMPRESSION METHOD | MH, MR, MMR, JBIG |
RESOLUTION | 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi |
SENDING / RECORDING SIZE | Statement-R to 11" x 17" |
FAX MEMORY | Up to 30,000 pages |
SPEED DIALS | Max. 200 |
GROUP DIALS / DESTINATIONS | Max. 199 dials |
SEQUENTIAL BROADCAST | Max. 256 addresses |
MEMORY BACKUP | Yes |
FAX FEATURES | Original Type Selection, Two-sided Original, Book to Two Pages, Different-size Originals, Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Sender's Name (TTI), Select Line, Selecting the Telephone Line (when sending fax), Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, TX Report, Detect Feeder Multi Sheet Feed |
STORE SPECIFICATIONS | |
MAIL BOX SIMPLE(NUMBER SUPPORTED) | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored |
ADVANCED BOX | Communication Protocol: SMB or WebDAV SupportedClient PC:Windows (Windows Vista/7/8/8.1/10) Concurrent Connections (Max.) SMB:64 WebDAV:3 (Active Sessions) |
ADVANCED BOX AVAILABLE DISC SPACE | Approx. 16 GB (Standard HDD) Approx. 480 GB (1 TB HDD) |
ADVANCED BOX FEATURES | Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
MEMORY MEDIA | Standard: USB |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard:Universal Login Manager, uniFLOWOnline Express,9,10 User Authentication, Department ID Authentication,Access Management System,Device and Function Level Log-in Optional:uniFLOW |
DATA | Standard:Trusted Platform Module (TPM),Hard Disk Password Lock, Hard DiskDrive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated) Optional:Hard Disk Drive Mirroring, Hard Disk Drive removal, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW) |
NETWORK | Standard:Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP |
DOCUMENT | Standard:Secure Watermark, Secure Print, Forced Hold Printing, Adobe LiveCycle® Rights Management ES2.5 Integration,Encrypted PDF, Encrypted Secure Print, Device SignaturesOptional:User Signatures, Document Scan Locking |
ENVIRONMENTAL SPECIFICATIONS | |
OPERATING ENVIRONMENT | Temperature:50 to 86ºF Humidity:20 to 80% RH (no condensation) |
POWER REQUIREMENTS | 208 V AC, 60 Hz,12 A |
PLUG (MAIN UNIT) | NEMA 6-15P |
POWER CONSUMPTION | Maximum: Approx. 2.5 kWh Standby:Approx. 119.2 W Sleep Mode:Approx. 0.9 W8 Typical Electricity Consumption (TEC) Rating: 5.5 kWh |
STANDARDS | ENERGY STAR® Certified Rated EPEAT® Gold11 RoHS Compliant |
CONSUMABLES | |
TONER | GPR-56 Toner |
TONER YIELD (ESTIMATED @ 5% COVERAGE) | Black:82,000 Images Color (C,M,Y):66,500 Images |
FOOTNOTES 1 Time from device power-on to when copy jobs can be programmed. 2 Includes main unit, ADF, and consumables. 3 PDF print from Web sites is supported. 4 EPS can be printed directly only from the Remote User Interface. 5 Requires the optional PCL International Font Set-A1. 6 Requires the optional Barcode Printer Kit-D1. 7 Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative. 8 0.9 W Sleep mode is not available in all circumstances due to certain settings. 9 No charge for this solution; however activation is required. 10 Check for availability. 11 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net. |
