Canon Support for imageRUNNER ADVANCE C9065S PRO | Canon U.S.A., Inc.
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Model Name | imageRUNNER ADVANCE C9065S PRO |
System Type | Color Digital Multifunction Imaging System |
Functions | Copy, Scan, Print |
Operation Panel | PRISMAsync 15" LCD Standard Configuration: imageRUNNER ADVANCE C9075S PRO/ C9065S PRO Main Unit, Duplex Color Image Reader Unit-A1, PRISMAsync iR-ADV C9000S PRO, Operator Panel, Scanning-B1,⟩ Scheduler-A1,⟩ Multiple Queues/Hot Folders-A1,⟩ E-shredding-B1,⟩ X-Rite Eye-One Spectrophotometer |
Memory | Standard/Maximum: 2.5GB RAM |
HDD Drive | Standard: 80GB Maximum: 1TB |
Network Interface Connection | Standard: Ethernet (10Base-T/100Base-TX/1000Base-T) |
Other Interface | Standard: USB (at Operator Panel) |
Copy/Print Speed (BW/Color) | Letter: Up to 65/65 ppm Legal/11" x 17": Up to 39/39 ppm / Up to 33/33 ppm |
Paper Source | (20 lb. Bond): Standard: Dual 1,100-sheet Paper Drawers/Dual 550-sheet Cassettes/100-sheet Stack Bypass Optional: 3,500-sheet Paper Deck-A1, 3,500-POD Deck Lite-A1, or 6,000-sheet/Multi-Drawer Paper Deck-A1 Maximum: 9,300 Sheets (with Multi-Drawer Paper Deck option)* |
Output Paper Capacity | (20 lb. Bond): With Copy Tray: 250 Sheets With Staple or Booklet Finisher: 4,250 Sheets |
Output Paper Sizes | Drawers: Letter Cassettes: 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 13" x 19-1/4") Bypass: 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (4" x 5-7/8" to 13" x 19-1/4") |
Acceptable Paper Weights | Drawers/Cassettes: 14 lb. Bond to 80 lb. Cover Bypass: 14 lb. Bond to 110 lb. Cover |
Duplexing | Paper Size: Standard Automatic Trayless Duplexing (Up to 13" x 19") Paper Weights: 14 lb. Bond to 80 lb. Cover |
Special Media Support | Drawers: Transparency Cassettes: Transparency, Tab Bypass: Transparency, Tracing, Labels, Coated, Textured, Envelopes |
Warm Up Time | From Power On: 5 Minutes From Sleep Mode: 5 Minutes From Energy Saver Mode: 90 Seconds |
Power Requirements | Main Unit: 208V AC, 60Hz, 15A/NEMA 6-15P PRISMAsync: 120V AC, 60Hz, 10-5A/NEMA 5-15P |
Power Consumption | (Maximum): Main Unit: 2.5kW or Less; Sleep Mode: 1.5W PRISMAsync: 181W or Less: Sleep Mode: 117W Total: 2.68kW or Less; Sleep Mode: 118.5W |
Plug | Main Unit: 15A/NEMA 6-15P PRISMAsync: 10-5A/NEMA 5-15P |
Dimensions | Main Unit: 55-1/10" x 44-1/10" x 36-3/4"** PRISMAsync: 16-1/2" x 7-9/10 x 16-9/10" |
Installation Space | 50-1/5" x 57-1/10" (1275mm x 1450mm) (when Stack Bypass is extended, Operator Panel is in right-most position, and the Cassette is drawn) |
Weight | Main Unit:♦ Approx. 635 lb. PRISMAsync: Approx. 35.3 lb. Total:♦ Approx. 670 lb. |
Image Reader Unit
Scan Resolutions | Up to 600 x 600 dpi |
Acceptable Originals | Sheet, Book, 3-Dimensional Objects (up to 4.4 lb.) |
Maximum Original Size | Up to 11" x 17" |
Document Feeder
Scan Method | Single-Pass Duplexing Automatic Document Feeder |
Acceptable Originals | Paper Sizes: 11" x 17", Legal, Letter, Letter-R,Statement, or Statement-R Paper Weights: BW Originals: 13 lb. Bond to 80 lb. Cover Color Originals: 17 lb. Bond to 80 lb. Cover |
Scanning Speed | Copy/Scan Simplex: 45/45 ipm (600 dpi) Copy/Scan Duplex: 44/44 ipm (600 dpi) |
Paper Capacity | (20 lb. Bond): 300 Sheets |
Copy Specifications
First Copy Output Time | BW: 15 Seconds Color: 15 Seconds |
Multiple Copies | 1 to 9,999 |
Color Mode | Black and White, Color |
Magnification | 25% - 400% (1% Increments) |
Copy Features | Original: 1- or 2-sided, Original type, Size, Background Output: 1- or 2-sided, Binding edge, Media, Cover, Layout, Zoom, Align, Shift, Print delivery, Margin erase, Adjust image, Color/Black & white, Punching,† Folding,† Binding,† Trimming† Job: Job name, Number of sets, Destination, Separator sheets, Account ID |
Print Specifications
Processor | Intel® Quad CoreTM i7 Type: External Operating System: Windows® XPe® SP3 First-Print-Out-Time: (Letter): BW: 8 Seconds Color: 8 Seconds |
Memory | 4GB |
Hard Disk | 3 x 3.5" SATA II, 250GB, 7200 RPM DVD-ROM: Standard Interface Connections: 10/100/1000Base-T, TCP/IP (LPR/LPD), 9100 Socket (SMB), Static IP/Auto-IP (DHCP) |
Engine Resolution | 1200 x 1200 dpi |
PDL Support | Adobe® PS3 (3019), PDF 1.7, [Extension Level 3 (for Acrobat® 9)], PDF/X, Optimized PS, Optimized PDF |
Print Driver Supported OS | Windows Vista®, Windows 7 (32-bit and 64-bit), MAC® OS X10.4/10.5/10.6 (32-bit), PPD |
Print Features | Waiting/scheduled jobs queues, printed jobs archive; One queue and job management for printing and copying; Streaming (spool-while-RIP-while-print while- clean-up), unlimited job length at constant print speed via clearing up while printing; Multiple standard and customizable workflow profiles; Media based operation with PRISMA media catalog; Web-based controller Settings Editor; Professional high-speed color management with Adobe ACE Color Management module and dedicated GPU; Calibration per media family and halftone; Spot color editing including CMYK value definition for spot color tints; Unlimited color pre-set definition for easy and timesaving re-use; Scheduler at operating panel: 8 hours plan-ahead functionality for multiple jobs simultaneously; Workflow automation via LPR queues and PDF/PS Hot Folders Fonts: 136 Type 1 fonts for Roman languages; User import of PS fonts via Settings Editor Spot Color Libraries: HKS K, HKS K3000+, HKS N, HKS N 3000+, PANTONE® Goe un/coated, PANTONE®+ Solid un/coated Scan Specifications Standard: Scan-to-E-mail, Scan-to-FTP, Scan-to-USB Option: Scan-to-PRISMAaccess Scan Resolution: Up to 600dpi File Format: (Single/Multi-page) TIFF, JPEG, PDF |
Security Specifications | Standard: E-shredding, HTTPS, Password protection per user role (key operator, system administrator, service technician) Optional: Removable HDD |
Environmental Information | ENERGY STAR® Qualified RoHS Compliant WEEE Directive |
Paper Supply Options
Description | Paper Deck Unit-A1 |
Paper Capacity | 3,500 Sheets (20 lb. Bond) |
No Of Drawers | 1 |
Acceptable Paper Weight | 14 lb. Bond to 80 lb. Cover |
Acceptable Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-Punched |
Acceptable Paper Size | Letter |
Power Source | From Main Unit |
Maximum Power Consumption | 44W |
Dimensions | 22-1/2" x 12-3/4" x 23" |
Weight | Approx. 81.6 lb |
Description | POD Deck Lite-A1 |
No Of Drawers | 1 |
Acceptable Paper Weight | 14 lb. Bond to 110 lb. Cover |
Acceptable Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-punched, Transparency, Labels, Bond, Letterhead, Coated, Textured |
Acceptable Paper Size | 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R |
Power Requirement | 120-127V AC, 60Hz, 5A |
Maximum Power Consumption | 288W |
Plug | NEMA 5-15P |
Dimensions | 22-1/2" x 23-5/8" x 24-1/2" |
Weight | Approx. 110 lb. |
Description | Multi-Drawer Paper Deck-A1 |
Paper Capacity | 6,000 Sheets (20 lb. Bond) |
No Of Drawers | 3 (2,000 Sheets each) |
Acceptable Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Labels, Tab, Bond, Letterhead, Coated, Textured |
Acceptable Paper Size | 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Custom Size [5-1/2" x 7-1/8" to 13" x 19-1/4" (140mm x 182mm to 330mm x 488mm)] |
Power Requirement | 120-127V 60Hz 4A |
Maximum Power Consumption | Approx. 753W |
Plug | NEMA 5-15P |
Dimensions | 41" x 37-3/8" x 31-3/8" |
Output Options
Description | Copy Tray-P1 |
Total Output Capacity | 250 Sheets (20 lb. Bond) |
Acceptable Paper Size | 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size [4" x 5-7/8" to 13" x 19-1/4" |
Dimensions | 6-7/8" x 16-1/2" x 15" |
Weight | Approx. 2.9 lb. |
Description | Staple Finisher-A1 |
Number Of Trays | 3 |
Tray Capacity | Tray A: 1,500 Sheets (Letter, Statement-R, Executive) 750 Sheets (13" x 19", 12" x 18", 11" x 17", Legal, Letter-R) Tray B: 250 Sheets (Letter) 125 Sheets (13" x 19", 12" x 18", 11" x 17", Legal, Letter-R, Executive) Tray C: 2,500 Sheets (Letter) 1,250 Sheets (Statement-R, Executive) 750 Sheets (13" x 19", 12" x 18", 11" x 17", Legal, Letter-R) |
Total Output Capacity | 4,250 Sheets (Letter, Statement-R,Executive) |
Acceptable Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Tab, Bond, Letterhead, Coated, Textured, Envelopes |
Acceptable Paper Size | 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size [(4" x 5-7/8" to 13" x 19-1/4") (100mm x 148mm to 330mm x 488mm)] |
Staple Positions | Corner/Double Stapling: 11" x 17", Legal, Letter, Letter-R,Executive |
Max Stapling Capacity | 100 Sheets (20 lb. Bond) (Letter, Executive) 50 Sheets (20 lb. Bond) (11" x 17", Legal, Letter-R) |
Paper Capacity of Staple Mode | Tray A/C: 1,500 Sheets/100 Sets(Letter, Statement-R, Executive),750 Sheets/50 Sets (13" x 19", 12" x 18",11" x 17", Legal, Letter-R) |
Type of Staples | Staple-G1 (5,000 x 3) |
Power Requirement | 100-240V, 50/60Hz, 2.8A |
Max Power Consumption | 207W |
Plug | NEMA 5-15P |
Dimensions | 41" x 25-3/4" (30-3/4"††) x 30-1/8" |
Weight | Approx. 134 lb. |
Description | Booklet Finisher-A1 |
Total Output Capacity | 4,250 Sheets (Letter, Statement-R, Executive) |
Acceptable Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre- Punched, Transparency, Tracing, Labels, Tab, Bond, Letterhead, Coated, Textured, Envelopes |
Acceptable Paper Size | 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size [4" x 5-7/8" to 13" x 19-1/4" (100mm x 148mm to 330mm x 488mm)] |
Staple Positions | Corner Stapling: 11" x 17", Legal, Letter, Letter-R, Executive Double Stapling: 11" x 17", Legal, Letter, Letter-R, Executive Saddle-Stitch: 13" x 19", 12" x 18", 11" x 17", Legal, Letter-R |
Max Saddle Stitch Capacity | 20 Sheets (including one cover page 110 lb. Bond) (20 lb. Bond) |
Paper Capacity Saddle Stich Mode | 1 to 5 Sheets/25 Sets, 6 to 10 Sheets/ 15 Sets, 11 to 16 Sheets/10 Sets, 17 to 20 Sheets/5 Sets |
Type of Staples | Staple-G1 (5,000 x 3) Staple-P1 (5,000 x 2) |
Power Requirement | 100-240V 50/60Hz, 2.8A |
Max Power Consumption | 255W |
Plug | NEMA 5-15P |
Dimensions | 41" x 30-1/4" (35-1/4"††) x 30-1/8" |
Weight | Approx. 238 lb. |
Description | Document Insertion Unit-H1ΔΔ |
Number Of Trays | 2 |
Acceptable Media | Covers and Inserts |
Tray Capacity | Upper: 200 Sheets (20 lb. Bond) Lower: 200 Sheets (20 lb. Bond) |
Acceptable Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-punched, Tab, Bond, Letterhead, Coated, Textured |
Acceptable Paper Size | 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Custom Size [7-1/8" x 7-1/8" to 13" x 19-1/4" (140mm x 182mm to 330mm x 488mm)] |
Power Requirement | 100-240V/2.8A, 50/60Hz |
Max Power Consumption | 103W |
Plug | NEMA 5-15P |
Dimensions | 55-3/8" x 13-1/4" x 31-1/4" 55-3/8" x 29-3/8" x 31-1/4" (with Insertion Feeding Tray) |
Description | Paper Folding Unit-G1ΔΔ |
Folding Method | Roller Pressure Folding |
Folding Type | Z-Fold, Accordion Z-Fold, C-Fold, Half-Fold, Double Parallel Fold |
Acceptable Paper Weight | 14 lb. Bond to 28 lb. Bond |
Acceptable Paper Type | Thin, Plain, Color, Recycled, Bond |
Acceptable Paper Size | Accordion Z-Fold, C-Fold, Half-Fold: Letter-R Z-Fold: 11" x 17", Legal, Letter-R Double Parallel Fold: Legal, Letter-R |
Power Requirement | From Finisher |
Max Power Consumption | 130W |
Dimensions | 46-7/8" x 13-1/4" x 31-1/4" |
Weight | Approx. 156.5 lb. |
Description | Puncher Unit-BF1††† |
Acceptable Punch Paper Weight | 14 lb. Bond to 140 lb. Index |
Acceptable Punch Paper Type | Thin, Plain, Heavy, Color, Recycled, Tab, Bond, Letterhead, Coated, Textured |
Acceptable Punch Paper Size | 11" x 17", Legal, Letter, Letter-R |
Punch Type | 2 Holes (Legal, Letter-R) 3 Holes (11" x 17", Letter) |
Distance Between Punch Holes | 2 Holes: 2-3/4" (70mm) 3 Holes: 4-1/4" (108mm) |
Punch Waste Tray Capacity | Approx. 5,000 Sheets (20 lb. Bond) |
Max Power Consumption | Approx. 56W (when in operation) |
Dimensions | Inside the Finisher (15-1/2" x 3-3/4" x 15-1/2") |
Weight | Approx. 8.2 lb. |
Description | Professional Puncher-C1/ Professional Puncher Integration Unit-B1ΔΔ |
Acceptable Punch Paper Weight | Letter (3-hole, 5-hole, Velo Bind 11-hole, Plastic Comb 19-hole, Twin Loop 21-hole/ 32-hole, Color Coil 44-hole): 20 lb. Bond to 80 lb. Cover Letter (ProClick 32-hole): 20 lb. Bond to 65 lb. Cover |
Acceptable Punch Paper Type | Plain, Heavy, Color, Recycled, Tab, Coated |
Acceptable Punch Paper Size | Letter |
Punch Patter Die Sets | Plastic Comb (19-hole) Twin Loop (21/32-hole) Color Coil (44-hole) Velo Bind (11-hole) Loose Leaf (3/5-hole) ProClick (32-hole) |
Punch Waste Tray Capacity | Approx. 25,000 Sheets or more of 20 lb. Bond with 4 holes punched |
Power Requirement | 120-127V/5.5A-60Hz |
Max Power Consumption | Professional Puncher-C1: 300W Professional Puncher Integration Unit-B1: 130W Max. |
Plug | NEMA 5-15P |
Dimensions | Professional Puncher-C1: 41" x 12" x 31-1/4" Professional Puncher Integration Unit-B1: 41" x 9-7/8" x 31-1/4" |
Weight | Professional Puncher-C1: Approx. 176 lb. Professional Puncher Integration Unit-B1: Approx. 88.2 lb. |
Description | Inner Booklet Trimmer-A1Δ |
Trimming Method | Face Trim |
Trim Thickness | 40 Sheets (2mm to 20mm Trimming Width) |
Waste Tray Capacity | 1,500 Sheets of Trimmed Strips (Width 0.78" (20mm), Letter, 20 lb. Bond) |
Acceptable Paper Weight | 16 lb. Bond to 110 lb. Cover |
Acceptable Paper Type | Thin, Plain, Heavy, Recycled, Color, Coated |
Total Output Capacity | 30 Booklets |
Max Power Consumption | 51W (when in operation) |
Dimensions | Inside the Finisher 15-7/8" x 9-7/8" x 24-5/8" |
Weight | Approx. 70.5 lb. Other Optional Accessories: Operator Attention Light Removable HDD Kit-AB1 3.5-inch/1TB HDD-B1 Key Switch Unit-B1 ADF Access Handle-A1 Remote Viewer-B1 Fontset Simplified Chinese-B1 Fontset Traditional Chinese-B1 Fontset Japanese-B1 Fontset Korean-B1⟩ PRISMAsync license accessories. * Stack Bypass is not available when Multi-Drawer Paper Deck is installed. ** With Operator Panel in left-most position. *** With Operator Panel in right-most position. ♦ Includes ADF, consumables, Operator Panel. † Requires optional accessories. †† When the Auxiliary Tray is extended. ††† Puncher Unit-BF1 installs internally with either Staple Finisher-A1 or Booklet Finisher-A1. Δ Option for Booklet Finisher-A1. ΔΔ Requires Staple Finisher-A1 or Booklet Finisher-A1. |
