Canon Support for imageRUNNER ADVANCE DX C5735i | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
MAIN UNIT |
TYPE | Color Laser Multifunctional |
CORE FUNCTIONS | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
PROCESSOR | 1.75GHz Dual Core Processor |
CONTROL PANEL | 10.1" TFT LCD WSVGA Color Flat-panel |
MEMORY | 4.0 GB RAM |
HARD DISK DRIVE | Standard: 250 GB/Maximum: 1 TB |
PRINT RESOLUTION | 1200 x 1200 |
INTERFACE CONNECTION | Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n) Others Standard: USB 2.0 (Host) x1, USB 3.0 x1 (Host), USB 2.0 x1 (Device) Optional: Serial Interface, Copy Control Interface |
PAPER CAPACITY (LETTER, 20 LB. BOND) |
Standard: 1,200 Sheets Maximum: 6,350 Sheets |
PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: Dual 550-sheet Paper Cassettes, 100-sheet Stack Bypass Optional: Dual 550-Sheet Paper Cassettes (Cassette Feeding Unit-AM1), 2,450-Sheet High Capacity Paper Cassette (High Capacity Cassette Feeding Unit-A1), 2,700-Sheet Paper Deck (Paper Deck Unit-F1) |
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) | Standard: 250 Sheets Maximum: 3,450 Sheets (with External Finisher and Copy Tray) |
FINISHING CAPABILITIES | Standard: Collate, Group With Options: Collate, Group, Offset, Staple, Saddle-Stitch, Hole Punch, Eco Staple, Staple On Demand |
SUPPORTED MEDIA TYPES | Multi-Purpose Tray: Thin, Plain, Recycled, Color, Heavy, Coated, Tracing, Bond, Transparency, Label, Pre-punched, Letterhead, Tab, Envelope Paper Cassettes: Thin, Plain, Recycled, Color, Heavy, Bond, Transparency, Pre-punched, Letterhead, Envelope1 |
SUPPORTED MEDIA SIZES |
Upper Cassette: Letter, Executive, Statement-R, Envelope [No.10 (COM10), DL, ISO-C5], Custom Size (3-7/8" x 5-7/8" to 11-3/4" x 8-1/2") Lower Cassette: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 7-1/8" to 12" x 18") Multi-Purpose Tray: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Envelope Custom Size (3-7/8" x 3-7/8" to 12-5/8" x 18"), Custom Size/ Free Size (3-7/8" x 5-1/2" to 12-5/8" x 18") |
SUPPORTED MEDIA WEIGHTS | Cassettes: 14 lb. Bond to 140 lb. Index (52 to 256 g/m2) Stack Bypass: 14 lb. Bond to 110 lb. Cover (52 to 300 g/m2) Duplexing: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) |
PRINT/COPY SPEED (BW AND COLOR) | Up to 35 ppm (Letter); Up to 23 ppm (Letter-R); Up to 21 ppm (Legal); Up to 18 ppm (11" x 17") |
WARM-UP TIME | From Power On: Approx. 10 Seconds2 From Sleep Mode: Approx. 10 Seconds3 Quick Startup Mode: Approx. 4 Seconds4 |
DIMENSIONS (W x D x H) | 24-3/8" x 28-1/2" x 36-7/8" (620 x 722 x 937 mm)5 |
INSTALLATION SPACE (W x D x H) | Basic: 42-5/8" x 45-3/4" (1,083 x 1,162 mm) (Right Cover Open with Multi-purpose tray extended + Cassette Drawers Open) Fully Configured: 73-1/2" x 45-3/4" (1,866 x 1,162 mm ) (Booklet Finisher-Y1 with the extension tray extended + Paper Deck Unit-F1 + Cassette Drawers open) |
WEIGHT | Approx. 310.9 lb. (141 kg)6 |
PRINT SPECIFICATIONS |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL6, Adobe PS 3 |
SUPPORTED FILES | PDF, TIFF, JPEG, EPS,7 XPS |
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES | A range of standard and optional software and MEAP-based solutions (including AirPrint, Mopria, Universal Print by Microsoft, Canon PRINT Business, and uniFLOW Online) are available to provide printing from mobile devices or internet-connected devices and cloud-based services depending on your requirements. Please contact your sales representative for further information. |
FONTS | PCL: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),8 Barcode Fonts9 PS: 136 Roman |
OPERATING SYSTEM 10 | UFRII/PS: Windows® 7/8.1/10/Server2008/ Server2008 R2/Server2012/Server2012 R2/Server2016/Server2019, Mac OS X (10.10 or later) PCL: Windows® 7/8.1/10/Server2008/ Server2008 R2/Server2012/Server2012 R2/Server2016/Server2019 PPD: Windows® 7/8.1/10, Mac OS X(10.9 or later) |
COPY SPECIFICATIONS |
FIRST-COPY-OUT-TIME | As fast as 4.9 seconds (BW)/ 7.4 seconds (Color) |
COPY RESOLUTION (dpi) | 600 x 600 |
MULTIPLE COPIES | Up to 999 |
MAGNIFICATION | 25%-400% (1% Increments) |
PRESET REDUCTION / ENLARGEMENT | 25%, 50%, 64%, 73%, 78%, 100% (1:1), 121%, 129%, 200%, 400% |
SCAN SPECIFICATIONS |
TYPE | Single-Pass Duplexing Automatic Document Feeder |
DOCUMENT FEEDER PAPER CAPACITY | Up to 200 Sheets (20 lb. Bond) |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES | 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R, Custom Size: 2-3/4" x 5-1/2" to 12" x 17" |
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | Single-Sided Scanning: 13.3 lb. Bond to 80 lb. Cover (50 to 220 gsm) (BW, CL) Double-Sided Scanning: 13.3 lb. Bond to 80 lb. Cover (50 to 220 gsm) (BW, CL) |
PLATEN ACCEPTABLE ORIGINALS | Sheet, Book, 3-Dimensional Objects |
PULL SCAN | Color Network ScanGear2 for both Twain and WIA Supported OS: Windows® 7/8.1/10/Server 2008/ Server 2008 R2/Server 2012/ Server 2012 R2/Server 2016 |
SCAN RESOLUTION (dpi) | Scan for Copy: 600 x 600 Scan for Send: (Push) 600 x 600 (SMB/FTP/WebDAV/ IFAX), (Pull) 600 x 600 Scan for Fax: 600 x 600 |
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of solutions is available to provide scanning to compatible mobile devices and certain cloud-based services depending on your requirements. |
SCAN SPEED (LETTER) | Single-sided Scanning: 135/135 (300 dpi), 80/80 (600 dpi), Double-sided Scanning: 270/270 (300 dpi), 160/90 (600 dpi) |
SEND SPECIFICATIONS |
DESTINATION | Standard: E-mail/Internet FAX (SMTP), SMB3.0, FTP, WebDAV, Mail Box Optional: Super G3 FAX, IP Fax |
ADDRESS BOOK | LDAP (2,000)/Local (1,600)/Speed Dial (200) |
SEND RESOLUTION | Push: Up to 600 x 600 Pull: Up to 600 x 600 |
COMMUICATION PROTOCOL | File: FTP(TCP/IP), SMB3.0 (TCP/IP), WebDAV Email: SMTP, POP3 |
FILE FORMAT | Standard: TIFF, JPEG, PDF (Encrypted, Compact, Searchable, Apply Policy, Optimize for Web, User Signature, PDF A/1-b, Limited Color, Device Signature, User Signature), XPS (Compact, Searchable, Device Signature, User Signature), Office Open XML (PowerPoint, Word) |
FAX SPECIFICATIONS |
MODEM SPEED | Super G3: 33.6 Kbps G3: 14.4 Kbps |
COMPRESSION METHOD | MH, MR, MMR, JBIG |
RESOLUTION | 400 x 400, 200 x 400, 200 x 200, 200 x 100 |
SENDING / RECORDING SIZE | Statement-R to 11" x 17" |
FAX MEMORY | Up to 30,000 Pages (2,000 jobs) |
SPEED DIALS | Max. 200 |
GROUP DIALS / DESTINATIONS | Max. 199 Dials |
SEQUENTIAL BROADCAST | Max. 256 Addresses |
MEMORY BACKUP | Yes |
STORE SPECIFICATIONS |
MAIL BOX SIMPLE (NUMBER SUPPORTED) | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, Maximum 10,000 Pages (2,000 jobs) Stored |
ADVANCED BOX | Communication Protocol: SMB or WebDAV Supported Client PC: Windows (Windows 8.1/10) Concurrent Connections (Max.) SMB: 64 WebDAV: 3 |
ADVANCED BOX AVAILABLE DISC SPACE | Approx. 16 GB (Standard HDD) Approx. 480 GB (With Optional 1 TB HDD) |
SECURITY SPECIFICATIONS |
AUTHENTICATION | Standard: Universal Login Manager, uniFLOW Online Express,11 User Authentication, Department ID Authentication, Access Management System, Device and Function Level Log-in Optional: uniFLOW |
DATA | Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), Verify System at Startup,3 McAfee Embedded Control Optional: Hard Disk Drive Mirroring, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW) |
NETWORK | Standard: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication (v1.0/1.1/1.2/1.3), SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration |
DOCUMENT | Standard: Secure Watermark, Secure Print, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Digital Signature User Signature |
ENVIRONMENTAL SPECIFICATIONS |
OPERATING ENVIRONMENT | Temperature: 50 to 86º F Humidity: 20 to 80% RH (Relative Humidity) |
POWER REQUIREMENTS | 110-127V, 60Hz, 10A |
POWER CONSUMPTION | Maximum: Approx. 1,800 W Standby: Approx. 63.1 W12 Sleep Mode: Approx. 0.8 W13 Typical Electricity Consumption (TEC) Rating14 0.47 kWh |
STANDARDS | ENERGY STAR® Certified Rated EPEAT® Gold |
CONSUMABLES |
TONER | GPR-55 Toner15 |
TONER YIELD (ESTIMATED @ 5% COVERAGE) | Black: 69,000 Images |
FOOTNOTES |
