Canon Support for imageRUNNER LBP3580 | Canon U.S.A., Inc.
imageRUNNER LBP3580
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Model Name | imageRUNNER LBP3580 |
Type | Desktop Laser Printer Printing Method: Electrophoto Method (RAPID Fusing System) |
Developing System | Contact Developing System Standard PDL: UFR II, PCL 5e/6, Adobe PostScript 3 |
Image Server Memory | Standard/Maximum: 768MB RAM CPU: ARM11-528MHz + ARM9-264MHz |
Network Interface Connection | Shared 10/100/1000Base-T (RJ-45) |
Other Interface | USB Hi-Speed (Device) x1 USB Hi-Speed (Host) x2 User Interface: LCD 22 Characters x 5 Lines 8 LED Indicators 12 Operation Keys |
Printing Resolution | UFR II, PCL 5e/6, PostScript 3: 600 x 600 dpi, 1200 x 1200 dpi Equivalent, 2400 Equivalent x 600 dpi Engine: 600 x 600 dpi Print Drivers: UFR II, PCL 5e/6, PostScript 3: Windows® (XP/Windows Vista®/Windows 7/Windows 8/Server 2003/Server 2008/Server 2008 R2/Small Business Server 2011/Server 2012), Windows Terminal Servers (Server 2003/Server 2008/Server 2008 R2/Small Business Server 2011), Microsoft® Failover Cluster (Server 2003/Server 2008/Server 2008 R2),Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5, XenDesktop 4.0/5.0/5.5/5.6), Macintosh® (OS X 10.5.8 or later), VMware (vSphere 4, 5), SAP (PCL 5e/6, PostScript 3 only) |
Halftone | 256 Gradations (Continuous-Tone) |
Letter | (BW): Up to 42 ppm |
First Copy Time | 8.5 Seconds |
Maximum Original Size | Legal (8-1/2" x 14") |
Standard Paper Capacity | 500-sheet Paper Cassette (20 lb. Bond) 100-sheet Multi-Purpose Tray |
Optional | 500-sheet Paper Cassette (Up to 2) |
Maximum Paper Capacity | 1,600 Sheets |
Output Paper Capacity | Face-down Paper Output: Face-down/Face-up Output Tray: Approx. 250 Sheets Face-up Output Slot: Approx. 50 Sheets |
Warm Up Time | 28 Seconds or Less |
Power Requirements | 120-127V, 60Hz |
Power Consumption | (Approx., Average): Operating: 700W Standby: 14W Deep Sleep Mode: Approx. 0.9W |
Plug | NEMA 5-15P |
Dimension | 13-5/8" x 17-7/8" x 16-3/4" (345mm x 454mm x 424mm) |
Installation Space | 17-7/8" x 28-1/4" (454mm x 622mm) (when Multi-Purpose Tray is extended) |
Weight | Approx. 36.6 lb. (16.6kg)* |
Output Sizes
Cassette | Legal, Letter, Executive, Custom Sizes (Width: 4-1/8" to 8-1/2"; Length: 5-7/8" to 14") |
Bypass | Legal, Letter, Executive, Index Card, Custom Sizes (Width: 3" to 8-1/2"; Length: 5" to 14") and Envelopes |
Acceptable Paper Weights
Cassette | 16 lb. Bond to 32 lb. Bond (60 - 120g/m2) |
Bypass | 16 lb. Bond to 53 lb. Bond (60 - 199g/m2) |
Duplexing
Duplexing | Standard Automatic Trayless Duplexing (Legal, Letter) |
Estimated Toner Yield | Black (Starter): 6,000 Standard Copies** Black: 12,500 Standard Copies** |
Feeders
Description | Paper Feeder Unit PF-45 (Optional) |
Acceptable Originals | Legal, Letter, Executive, Statement, Custom Sizes (Width: 4-1/8" to 8-1/2" Length: 5-7/8" to 14") |
Capacity | 500 Sheets (20 lb. Bond) |
Dimensions | 5-5/8" x 17-7/8" x 18-1/2" (141mm x 454mm x 470mm) |
Weight | Approx. 12.1 lb. (5.5kg)Other Optional Accessories SD Card-B1 (8GB)Barcode Printing Kit-F1* Excluding the the toner cartridges. ** Toner cartridge yield in accordance with ISO/IEC 19752. ♦ Up to two Paper Feeder Units can be added. |
