Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 01.01.04
File Size 500.84 KB
Date 04.01.07
File Size 2.26 MB
Date 04.01.07
File Size 3.47 MB
Date 04.01.07
File Size 402.69 KB
Date 01.01.04
File Size 500.84 KB
Date 04.19.10
File Size 2.25 MB
Date 04.19.10
File Size 402.0 KB
Date 04.19.10
File Size 3.46 MB
Date 04.19.10
File Size 359.0 KB
Power Supply (rated) 7.4 V DC
Power Consumption 4.7 W (using viewfinder), 5.5 W (using LCD screen)
Television System EIA standard (525 lines, 60 fields) NTSC color signal
Video Recording system 2 rotary heads, helical scanning system, DV system; VCR SD/SDL System
Audio Recording system PCM digital sound: 16 bit (48 Khz/2 ch.); 12 bit (32 khz/ 4 ch)
Image Sensor 1/4" CCD (charge coupled device); 380,000 pixels (approx. 360,000 effective pixels)
Tape Format Video casettes bearing the MiniDV mark
Tape Speed Sp: 3/4 ips (18.81mm/sec); LP: 1/2 ips (12.56mm/sec)
Maximum Recording Time (with an 80-min. cassette) SP: 80 min; LP: 1/2 ips (12.56mm/sec)
Fast Forward/Rewind Time 2 min. 30 sec. (with a 60 min cassette)
Lens f/1.6 - 2.5, 12x power zoom, 4.1 - 49.2mm
Focusing System TTL autofocus, manual focusing possible
Focusing System 3 ft. 3 3/8 in (1m); 3/8 in. (1cm) on maximum wide angle
Minimum Illumination 2.5 lux using the Low-Light program during tape recording
Recommended Illumination More than 100 lux
Filter Diameter 30.5 mm
Viewfinder 0.55 in., color LCD (approx 113,00 pixels)
LCD Screen 3.5 in measured diagonally (approx 200,000 pixels)
Microphone Stereo electret condenser microphone
DV Terminal Special 4-pin connector (Based on IEEE 1394 )
Video Terminal 1Vp-p/75 ohms unbalanced
S-video Terminal 1Vp-p (Y signal) 0.286 Vp-p (C signal)
Audio Terminal -10 dBV/47 kohms, unbalanced; Output level; -10 dBV, less than 3 kohms, unbalanced
Operating Temperature range 32- 104&deg: F (0-40&deg; C)
Dimensions 2 5/8 x 3 3/8 x 5 7/8 in. (68 x 87 x 148mm)
Weight (not including lens and battery pack) 1 lb. 6 7/8 oz. (650g)
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
