Canon Support for PIXMA MP800R | Canon U.S.A., Inc.
PIXMA MP800R
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 12.31.13
File Size 803.12 KB
File Name Setup Guide
Date 04.01.07
File Size 4.90 MB
File Name User's Guide
Date 04.01.07
File Size 4.53 MB
image icon
Canon PRINT - iOS
image icon
Canon PRINT - Android
Products Windows 7 Windows 8 Windows 10 Windows 10s
PIXMA MP800R 1
Printer
Print Speed (up to) 4" x 6" borderless photo: approximately 36 seconds1
Black:Black: Up to 30 ppm (approximately 2.0 seconds per page)1
Color:Color: Up to 24 ppm (approximately 2.5 seconds per page)1
Number of Nozzles Black: 512
Color: 512 x 2 (Y, Bk)
1,024 x 2 (C,M)
Total: 3,584
Picoliter Size (color) 1 and 5
Print Resolution (Up to) Black:600 x 600 dpi2
Color:9600 x 2400 dpi
Paper Sizes Letter, Legal, Credit Card (2.13" x 3.39"), 4" x 6," 4" x 8," 5" x 7," 8" x 10,"
Copier
Copy Speed (up to) Black: 30 cpm (approximately 2.0 seconds per page)
Color: 24 cpm (approximately 2.5 seconds per page)1
Reduction / Enlargement 25% - 400%
Copy Features Borderless, AE (Auto Exposure), 4 on 1, 2 on 1, Fit-to-Page, Image Repeat
Scanner
Scanning Element Charged-Coupled Device (CCD)
Max. Resolutions Optical:2,400 x 4,800 dpi
Interpolated:19,200 x 19,200 dp
Scanning Mode Color: 48-bit internal/24-bit external
Color Depth Maximum: 48-bit internal
Max. Document Size Print: 8.5" x 11.7" maximum
Photo Connect
Direct Connect Direct Print Port (cable not included)
Media Card Support CompactFlash&reg;, Microdrive,&reg; SmartMedia,&reg; Memory Stick,&reg; Memory Stick Pro,&trade; SD Card&trade; and MultiMediaCard.&trade; The following can be used with the addition of a special adapter sold separately: xD-Picture Card,&trade; Memory Stick Duo,&trade; Memory Stick Duo Pro,&trade; and miniSD&trade; Card.&trade;
General
OS Compatibility Windows&reg; 7, Windows XP/2000/Me/98 and Mac OS X version 10.2.4 to 10.4.x7
Standard Interface USB 2.0 Hi-Speed3 (cable not included), IrDA4 1.2 (JPEG only), Bluetooth5 v1.2 (Optional)
Wireless LAN interface (IEEE802.11g/IEEE802.11b)
Wired LAN Interface (RJ-45)
Software Included CD-ROM including MP Driver, MP Navigator, Setup Software and User's Guide, Electronic Photo Application Guide, Electronic User's Guide, e-registration, ScanSoft&reg; Omnipage&reg; SE,6 ArcSoft&reg; PhotoStudio,&reg; Easy-PhotoPrint version 3.3, and Easy-WebPrint (Windows only, requires Microsoft&reg; Internet Explorer7
Power Source AC 120 - 240V, 50/60Hz
Dimension (W x D x H) 18.6" W x 19.3" D x 9.5" H
Weight 27.3 lbs
Warranty Toll-free technical phone support plus 1-year limited warranty with InstantExchange program.8
*Specifications are subject to change without notice. All viewscreen and printer output images are simulated.
1 PPM print speeds are based on the highest speed printer driver mode. Photo print speeds are based on the default mode driver setting using Canon Photo Paper Plus Glossy paper. Print speeds will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. CPM copy speeds are based on fast mode setting using plain paper. Copy speeds may vary based on document complexity, copy mode, page coverage and number of copies.
2 Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/9600 inch at minimum.
3 USB 2.0 Hi-Speed requires Windows XP, 2000 or Mac OS X operating systems. For Windows 98, Me and Mac OS X v.10.2 to 10.2.6 operating systems, the printer will operate at USB 1.1 specifications.
4 JPEG files 3MB or smaller only. Requires mobile phone with IrDA port and support for IrMC version 1.1 protocol, with phone positioned no more than 7.9 inches from printer.
5 Bluetooth v1.2 with optional Canon Bluetooth Unit BU-20. Bluetooth operation depends on the devices and software version used. Operating distance is approximately 10 meters but may vary due to obstacles, radio signals, locations where radio interference occurs, magnetic fields from microwave ovens, device sensitivity and/or antenna performance.
6 System requirements vary by application.
7 ScanSoft OmniPage SE (OCR Software) does not support Windows 98 first edition.
8 Warranty programs are subject to certain conditions and restrictions. See www.canontechsupport.com for details.
Limited Warranty & InstantExchange Program Details
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon USA") with respect to the new or refurbished Canon-brand product ("Product") packaged with this limited warranty, when purchased and used in the United States only.
The Product is warranted against defects in materials and workmanship under normal use and service (a) for a period of one (1) year from the date of original purchase when delivered to you in new condition in its original container or (b) for (1) year from the date of original purchase for refurbished Products. Product returned to a Canon USA repair facility or a Canon USA Authorized Service Facility ("ASF"), and proven to be defective upon inspection will be (a) repaired utilizing new, remanufactured, repaired and/or recycled parts (b) exchanged for new or; (c) exchanged for a refurbished Product, as determined by the Canon USA repair facility or the ASF. Warranty repair or replacement shall not extend the original warranty period of the Product. A dated proof of purchase is required at the time of warranty service. A copy of your dated bill of sale will satisfy this requirement. This warranty does not cover any accessories, or any consumables, such as paper or ink cartridges, as to which there shall be no warranty or replacement.
This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. Non-Canon brand equipment and software that may be distributed with the Product are sold "as is" and without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose, and all such warranties are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
  1. Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's user's manual or other documentation, or services performed by someone other than a Canon USA repair facility or ASF. Without limiting the foregoing, dropping the Product, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the user's manual or other documentation for the Product.
  2. Use of parts, media, software or supplies (other than those sold by Canon USA), including non-Canon ink cartridges or refilled ink cartridges, that cause damage to the Product or cause abnormally frequent service calls or service problems.
  3. If the Product has had its serial number or dating defaced, altered or removed.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CD-ROMS ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON OR ENTITY WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA, OR ITS ASF. (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE, OR INABILITY TO USE THE PRODUCT REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA OR ITS ASF HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ITS ASF BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT SOLD BY CANON USA NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA, OR ITS ASF. (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE EXCLUSION OR LIMITATION MAY NOT APPLY TO YOU.) THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY.
Canon USA offers a full range of customer technical support* options:
Interactive troubleshooting, the latest driver downloads, hours of operation, and answers to frequently asked questions (www.usa.canon.com/support)
Toll-free live technical support Monday–Friday (excluding Canon-observed holidays) at 1-800-OK-CANON (1-800-652-2666)
Telephone Device for the Deaf (TDD-1-855-270-3277)
Repair or Exchange Service Options: In the event service is required for the Product during the limited warranty period, Canon USA offers two hardware support options:
Canon USA's Carry-In/Mail-In Service provides repair or exchange, at Canon USA's option, through Canon USA's Authorized Service Facility (ASF) network. The name and telephone number of the ASF(s) near you may be obtained from Canon USA's Web site at www.canontechsupport.com or by calling the Canon USA Customer Care Center at 1-800-828-4040, or any time while speaking to a technical support person. A Product covered by this limited warranty will be repaired or exchanged, as determined by Canon USA, and returned without charge by the ASF.
InstantExchange Service**
The Canon USA repair facility will ship out the replacement Product prepaid by Canon USA. After receipt of the replacement Product (with instructions and a prepaid waybill), follow the enclosed instructions on how to ship your product to the Canon USA repair facility. Your Product must be returned in the shipping carton in which the replacement Product was packed and include the reference number, A COPY OF YOUR DATED PROOF OF PURCHASE (BILL OF SALE), and a complete explanation of the problem. DO NOT INCLUDE ANY OTHER ITEMS WITH THE YOUR PRODUCT IN THE RETURN SHIPPING CARTON, AND BE SURE TO RETAIN YOUR PRINTHEAD, INK CARTRIDGE(S) AND TANK(S).
InstantExchange Service exchanges your Product with a replacement Product, which will normally be shipped the same day if your request for this service is by 3 p.m. E.T. Monday through Friday, except holidays. Canon USA does not guarantee same day shipment in the event of the occurrence of factors beyond its reasonable control. The replacement Product you receive may be a refurbished or reconditioned unit and will be covered for the balance of the period remaining on your original limited warranty. NOTE THAT BY USING THIS SERVICE YOU WILL KEEP THE REPLACEMENT PRODUCT THAT IS SENT TO YOU. CANON USA WILL RETAIN THE PRODUCT THAT YOU ORIGINALLY PURCHASED, WHICH SHALL BECOME THE PROPERTY OF CANON USA. InstantExchange warranty program service is available only during the express limited-warranty period for your Product and only in the continental United States, Alaska and Hawaii during such period.
InstantExchange warranty service is subject to the availability of refurbished or new replacement units.
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747
USA
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
