Canon Support for PowerShot A20 | Canon U.S.A., Inc.
PowerShot A20
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 04.01.07
File Size 1.46 MB
Date 01.01.02
File Size 13.35 MB
Date 04.01.07
File Size 3.59 MB
Date 04.01.07
File Size 2.71 MB
Date 04.01.07
File Size 3.84 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Image Capture Device
Type 1/2.7 in. charge-coupled device (CCD)
Total Pixels Approx. 2.11 million
Effective Pixels Approx. 2.02 million
Lens
Focal Length f/2.8
Digital Zoom Maximum 2.5x (Maximum 7.5x with optical zoom)
Focusing Range Normal: 76cm (2.5 ft.) - infinity
Macro: 16 - 76cm (6.3 in. - 2.5 ft.)(Wide angle); 26 - 76cm (10.2 in. - 2.5 ft.)(Telephoto)
Autofocus System TTL 3 point AiAF
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 1.5-inch low-temperature polycrystalline silicon TFT color LCD
LCD Pixels 117,600 effective pixels
LCD Coverage Approx. 80%
Aperture and Shutter
Maximum Aperture f/2.8 - 4.8; 5.4mm (Wide angle) - 16.2mm (Telephoto) (35mm film equivalent: 35 - 105mm)
Shutter Speed 1 - 1/1500 sec.* 1 sec. in manual mode with the flash off or in slow synchro mode.* Noise reduction processing on speeds slower than 1/6 sec.
Exposure Control
Sensitivity ISO 100 equivalent (automatically raised to ISO 150 in low light)
Light Metering Method Evaluative metering (linked to focusing point)
Exposure Control Method Program AE; Exposure is locked once focusing is complete.
Exposure Compensation +/-2 stops in 1/3-stop increments. (Manual mode only.)
White Balance
White Balance Control TTL Auto/Pre-set (daylight, cloudy, tungsten, fluorescent)/Black & White
Flash
Built-in Flash Red-eye reduction Auto/Auto/On/Off
Flash Range Normal Mode: 76cm - 4.2m (2.5 - 13.8 ft.) (Wide angle), 76cm - 2.5m (2.5 - 8.2 ft.) (Telephoto)
Macro Mode: 26 - 76cm (10.2 in. - 2.5 ft.) (Wide angle/Telephoto)
Shooting Specifications
Shooting Modes Auto/Manual/Stitch Assist/Playback
Self Timer Shoots after approx. 10 sec.
Continuous Shooting Approx. 2.5 images/sec (Large/ Fine mode, LCD monitor off)
Image Storage
Storage Media CompactFlash Card (Type I)
File Format JPEG (Design rule for Camera File system, DPOF compliant)
JPEG Compression Mode Superfine/Fine/Normal
Number of Recording Pixels Large: 1,600 x 1,200 pixels; Medium: 1,024 x 768 pixels; Small: 640 x 480 pixels
Number of Recordable Images
Image data
Playback Specifications
Playback Modes File Single image replay/Index replay (9 thumbnails)/Zoomed view (LCD monitor zooms images up to 2.5x)/Auto play/Printing with Card Photo Printer CP-10 (print image directly)
Interfaces
Computer Interface USB (mini-B)
Video Out Video output terminal (NTSC or PAL, selectable)
Power Supply Four AA alkaline batteries or four AA rechargeable NiMH batteries
Compact Power Adapter CA-PS500
Power Source Four AA alkaline batteries or four AA rechargeable NiMH batteries
Physical Specifications
Operating Temperature 0 - 40&deg;C (32 - 104&deg;F)
Operating Humidity 10 - 90 %
Dimensions (W x H x D) 110.3 x 71.0 x 37.6mm (4.3 x 2.8 x 1.5 in.) (excluding protrusions)
Weight Approx. 250g (8.8 oz.) (excluding batteries and CF card)
Computer System Requirements
Mac Requirements Hardware: Power Macintosh, PowerBook, iMac or iBook
OS: Mac OS 8.6 through 9.1, Quicktime 3.0 or higher
CPU: Power PC
Interface: USB - Cable connection via camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface (Power Macintosh NEW G3/G4, PowerBook G3/G4, iMac, iBook)
RAM: 20MB or more of application memory
PC Requirements Hardware: IBM PC/AT compatible.
OS Windows 98 (including the Second Edition)/ Windows 2000/Windows ME.
CPU: Pentium 133 MHz or better.
Interface: USB - Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME systems.
RAM: 32MB or more (Windows 98); 64MB or more (Windows 2000/Windows ME).
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: PowerShot A10/A20/A40
Advisory Type
Date 12.31.08
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
