Canon Support for PowerShot A300 | Canon U.S.A., Inc.
PowerShot A300
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Type of Camera
Type | Compact digital still camera with built-in flash and 5.1x digital zoom |
Image Capture Device
Type | 1/2.7 inch charge coupled device (CCD) |
Total Pixels | Approx. 3.3 million |
Effective Pixels | Approx. 3.2 million |
Lens
Focal Length | 5mm f/3.6 (35mm film equivalent: 33mm) |
Digital Zoom | 5.1x |
Focusing Range | Normal AF: 20cm - infinity; Macro AF: 5 - 20cm |
Autofocus System | 5-point AiAF/ 1-point AF (Fixed to center) |
Viewfinders
Optical Viewfinder | Inverted Galilean type |
LCD Monitor | 1.5 inch amorphous silicon TFT color LCD |
LCD Pixels | Approximately 67,000 pixels |
LCD Coverage | 100% |
Aperture and Shutter
Maximum Aperture | f/3.6 - 5.6 |
Shutter Speed | 1 - 1/2000 sec.; Slow shutter speed of 1/6 sec. is only available in select modes |
Exposure Control
Sensitivity | AUTO /ISO 50/ 100 / 200 / 400 equivalent |
Light Metering Method | Evaluative / Center-weighted average / Spot |
Exposure Control Method | Program AE |
Exposure Compensation | +/- 2.0 EV in 1/3-stop increments |
AE Lock | Not Available |
White Balance
White Balance Control | Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, or Flash), or Custom. |
Flash
Built-in Flash | Auto, Red-Eye Reduction On/ Off, Slow-Sync |
Flash Range | 20cm - 2.0m/0.67 ft. - 6.7 ft. (When ISO speed is set to AUTO) |
Recycling Time | Approx. 10 sec. or less. |
Flash Exposure Compensation | +/- 2.0 EV in 1/3-stop increments. |
Shooting Specifications
Shooting Modes | Auto, Manual, Stitch Assist, Movie |
Photo Effects | Vivid, Neutral, Low Sharpening, Sepia and Black & White. |
Self Timer | Operates with approx. 2 sec. or approx 10 sec. count-down. |
Wireless Control | Not Available |
Continuous Shooting | Approx. 2.2 shots/sec. (Large / Fine Mode and LCD monitor is Off) |
Image Storage
Storage Media | CompactFlash (CF) Card Type I |
File Format | QuickTime™ AVI |
Print Order Format | Digital Print Order Format (DPOF) Version 1.1 |
Image Recording Format | Still Image: JPEG (Exif 2.2 compliant) |
JPEG Compression Mode | SuperFine, Fine or Normal |
Number of Recording Pixels | 2048 x 1536 (Large), 1600 x 1200 (Medium 1), 1024 x 768 (Medium 2), 640 x 480 pixels (Small) Movie: 640 x 480, 320 x 240 or 160 x 120 |
Number of Recordable Images
Image data |  These figures reflect standard shooting conditions established by Canon. Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode. |
Time of Recordable Movies
Movie data |  Individual movie clips are limited to 30sec. (640 x 480) or 3 minutes each maximum per clip. Above figures show total movie capacity on various CF cards, measured under Canon's standard test conditions, and may vary depending upon scene, subjects or camera settings. |
Playback Specifications
Playback Modes File | Single, Index (9 thumbnails), Magnification (2x to 10x), Slide Show or Movie |
Erasing Specifications
Erase Modes | Single Image, All Images |
Interfaces
Computer Interface | Universal Serial Bus (USB)(mini-B jack) |
Video Out | None |
Other | CF card slot (accept type I cards). Direct connection to Canon CP Printers and select Bubble Jet Photo Printers (no computer required). |
Power Supply | 1. Size AA Alkaline battery x2 2. Rechargeable size AA NiMH battery x2 (NB4-100) 3. AC Adapter kit ACK-800Approx. 75 shots/Approx. 200 shots (LCD monitor ON) Approx. 210 shots/Approx. 450 shots (LCD monitor OFF) (Alkaline battery/NB4-100)Approx. 90 min/Approx 120 min. (Alkaline battery/NB-1AH) |
Power Source | 1. Size AA Alkaline battery x2 2. Rechargeable size AA NiMH battery x2 (NB4-100) 3. AC Adapter kit ACK-800 |
Shooting Capacity | Approx. 75 shots/Approx. 200 shots (LCD monitor ON) Approx. 210 shots/Approx. 450 shots (LCD monitor OFF) (Alkaline battery/NB4-100) |
Playback Time | Approx. 90 min/Approx 120 min. (Alkaline battery/NB-1AH) |
Physical Specifications
Operating Temperature | 32 - 104°F (0 - 40°C) |
Operating Humidity | 10 - 90% |
Dimensions (W x H x D) | 4.37 x 2.28 x 1.44 in./110.0 x 58.0 x 36.6mm (Excluding protrusions) |
Weight | Approx. 6.17 oz./175g (Camera body only) |
Computer System Requirements
Mac Requirements | Hardware: Power Macintosh, PowerBook, iMac, iBook or eMac. A CD-ROM drive is required to install the software. OS: Mac OS 9.0 through 9.2, OS X (Version 10.1/10.2). (Please see our Mac OS X Compatibility Statement); Note: USB Mounter software is not supported in Mac OS X. CPU: PowerPC Interface: USB: Cable connection via the camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface. Free Hard Drive Space: 200MB or more for Canon Utilities RAM: 20MB or more of application memory (Mac OS 9.x), 128MB or more (Mac OS X) Display: 800 x 600 pixels/32,000 colors or better is required, 1024 x 768 pixels or better is recommended. |
PC Requirements | Hardware: IBM PC/AT compatible with CD-ROM Drive. OS: Windows 98 (including the Second Edition), Windows 2000, Windows Me, Windows XP (Home, Professional) (Please see our Windows XP compatibility statement) CPU: Pentium 150 MHz or higher processor (Windows 2000/Windows ME/Windows 98); 300MHz or higher processor (Windows XP) Interface: USB: Cable connection via the camera's USB port is limited to computers pre-installed with an OS listed above. Free Hard Drive Space: 300MB or more for Canon Utilities/Drivers. RAM: 64MB or more (Windows 2000/Windows ME/Windows 98), 128MB or more (Windows XP) Display: 800 x 600 pixels/High Color (16 bit) or better is required, 1024 x 768 pixels or better is recommended. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
CONTACT US
