Canon Support for PowerShot ELPH 170 IS | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Type | 20.0 Megapixel, 1/2.3-inch CCD |
Total Pixels | Approx. 20.5 Megapixels |
Effective Pixels | Approx. 20.0 Megapixels* *Image processing may cause a decrease in the number of pixels. |
Focal Length | 4.5 (W) - 54.0 (T) mm (35mm film equivalent: 25-300mm) |
Digital Zoom | 4.0x |
Focusing Range | Auto: 0.4 in. (1 cm) - infinity (W), 3.3 ft. (1 m) - infinity (T); Normal: 2.0 in. (5 cm) - infinity (W), 3.3 ft. (1 m) - infinity (T); Macro: 0.4 in. - 1.6 ft. (1-50 cm) (W)Infinity: 9.8 ft. (3 m) - infinity (W, T) |
Autofocus System | TTL Autofocus |
Optical Viewfinder | Not Available |
LCD Monitor | 2.7-inch TFT Color LCD with wide viewing angle (4:3) |
LCD Pixels | Approx. 230,000 dots |
LCD Coverage | Approx. 100% |
Maximum Aperture | f/3.6 (W), f/7.0 (T) |
Shutter Speed | 1-1/2000 sec. 15-1 sec. (Long Shutter mode) |
Sensitivity | Auto, ISO 100-1600 |
Light Metering Method | Evaluative*, Center-weighted average, Spot** * Facial brightness is evaluated in Face Detection AF ** Metering frame is fixed to the center |
Exposure Control Method | Manual Exposure, Program Shift, Safety Shift, AE Lock |
Exposure Compensation | Still Images: ±2 stops in 1/3-step increments |
White Balance Control | Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom * Camera automatically sets the optimal ISO speed according to shooting mode. |
Built-in Flash | Auto, Flash On, Slow Synchro, Flash Off Facial brightness is also evaluated in Face Detect. |
Flash Range | 1.6 ft. - 13 ft. (W), 3.3 - 6.6 ft. (T) (50cm - 4.0m (W), (1.0m - 2.0m (T)) Image brightness may diminish depending on the shooting distance |
Recycling Time | 10 sec. or less (battery voltage: 3.7 V) |
Flash Exposure Compensation | Not available |
Shooting Modes | Auto, P, Live View Control, Portrait, Face Self-Timer, Low Light, Fish-eye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect, Snow, Fireworks, Long Shutter |
Photo Effects | Not available |
Self Timer | Approx. 10-sec. delay/approx. 2-sec. delay/custom* * Delay time (0-15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified. |
Wireless Control | Not available |
Continuous Shooting | Normal: Approx. 0.8 shots/sec. (in P mode) Normal: Approx. 2.2 shots/sec. (in Low Light mode) Under conditions where the flash does not fire automatically. Differs depending on the zoom position. |
Storage Media | SD Memory Card, SDHC Memory Card, SDXC Memory Card |
File Format | Design rule for Camera File system, DPOF (Version 1.1) compliant |
Image Recording Format | Fine |
JPEG Compression Mode | Still Image: Exif. 2.3 (JPEG) Video: MOV (Image: MPEG-4 AVC/H.264; Audio: Linear PCM (Monaural)) |
Number of Recording Pixels | Still Images (4:3 Aspect Ratio): Large: 5152 x 3864 Medium 1: 3648 x 2736 Medium 2: 2048 x 1536 Small: 640 x 480 Wide: 5152 x 2896 Medium: 2560 x 1920 (in Low Light mode) Videos: HD 1280 x 720: 25 fps Miniature Effect HD 1280 x 720: 5 fps / 2.5 fps / 1.25 fps Miniature Effect 640 x 480: 6 fps / 3 fps / 1.5 fps |
Image data | Note: F=Fine* When in Low Light.• The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly. |
Movie data | *1 Using an SD Speed Class 10 / UHS-I compatible memory card. • Recording stops automatically once the file size reaches 4 GB or the memory card becomes full. • Recording may stop unexpectedly if a memory card with a low Speed Class is used. *2 Actual frame rate is 29.97 fps. |
Playback Modes File | Stills & Videos: Auto Rotate (Automatic vertical/horizontal detection), Image Advance (Transition Effects, Scroll Display), Rotate, Favorites, Smart Shuffle, Group Playback, Slideshow (Repeat, Interval, Effect) Still Images: Single, Index (6-100 thumbnails), Magnification (2-10x), Information Display, Red-eye Correction, i-Contrast, Resize, Overexposure Warning Videos: Normal Playback*1, Skip Backward*2, Previous Frame*3, Next Frame*3, Skip Forward*2 Displays playback position and shooting time *1 Audio settings available in 5 levels *2 Approximately 4 seconds *3 Slow motion available |
Erase Modes | Select Image, Select Range, Select All Images The image data in the memory card stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased). Using the Movie editing function, sections of the movie can be deleted. |
Video Out | NTSC/PAL (dedicated connector (female) with unified type of digital, audio and video) |
Audio Out | Monaural (dedicated connector (female) with unified type of digital, audio and video) |
Other | SD memory card slot; direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers |
Power Source | Battery Pack NB-11LH/NB-11L, AC Adapter Kit ACK-DC90 |
Shooting Capacity | Approx. 200 shots Approx. 255 shots in ECO Mode |
Playback Time | Approx. 5 hours |
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 3.92 x 2.27 x 0.89 in. / 99.6 x 57.6 x 22.6mm |
Weight | 4.97 oz. / 141g (CIPA standard) 4.37 oz. / 124g (Body only)All data are based on Canon's Standard Test Method. Subject to change without notice. Canon, DIGIC, ELPH, PIXMA, PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
