Canon Support for PowerShot G5 | Canon U.S.A., Inc.
PowerShot G5
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Type of Camera
Type | Compact digital still camera with built-in flash, 4x Optical/ 4x Digital/ 16x Combined Zoom |
Image Capture Device
Type | 1/1.8 inch Charge-Coupled Device (CCD) |
Total Pixels | Approx. 5.0 million |
Lens
Focal Length | 7.2-28.8mm, f/2.0-3.0 zoom Lens(35mm film equivalent: 35-140mm) |
Digital Zoom | 4.0x (Maximum 16x digital zoom is available when combined with optical zoom) |
Focusing Range | Normal AF: 20 in. - infinity/50cm - infinity Macro AF: 2 - 20 in./5 - 50cm (WIDE), 6 - 20 in./15 - 50cm (TELE) |
Autofocus System | 1-point AF (Center Point or FlexiZone AF is available according to shooting mode) |
Viewfinders
Optical Viewfinder | Real-image optical zoom viewfinder |
LCD Monitor | 1.8 inch low temperature polycrystalline silicon TFT color LCD |
LCD Pixels | Approx. 118,000 pixels [521 (H) x 218 (V)] |
LCD Coverage | 100% |
Aperture and Shutter
Maximum Aperture | f/2.0-8.0 (W), f/3.0-8.0 (T) |
Shutter Speed | 15-1/2,000 sec. Slow shutter of 1.3 sec. and more operates with noise reduction |
Exposure Control
Sensitivity | AUTO/ ISO 50/ 100/ 200/ 400 equivalent |
Light Metering Method | Evaluation/ Center-weighted average/ Spot |
Exposure Control Method | Program AE, Shutter-Priority AE, Aperture-Priority AE, Manual |
AE Lock | Available |
ND Filter | Built-in |
White Balance
White Balance Control | Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, or Flash), or Custom (2 positions) |
Flash
Built-in Flash | Operation Modes: Auto, Red-Eye Reduction On/ Off |
Flash Range | WIDE: 2.3-16.4 ft. (70cm-5.0m)TELE: 2.3-13 ft. (70cm-4.0m)(When sensitivity is set to ISO 100 equivalent) |
Recycling Time | Approx. 10 sec. or shorter |
Terminals for External Flash | Sync-terminals at accessory shoe. Automatic E-TTL Flash is possible with EX-Series Speedlites: Canon Speedlite 550EX, 420EX, 220EX, and Macro Ring Lite MR-14EX and Macro Twin Lite MT-24EX. |
Flash Exposure Compensation | +/- 2.0EV (at every 1/3-stop) |
Shooting Specifications
Shooting Modes | Auto, Creative (P, Av, Tv, M, Custom 1, Custom 2), Image (Portrait, Landscape, Night Scene, Stitch Assist, Movie) |
Photo Effects | Vivid, Neutral, Low Sharpening, Sepia and Black & White |
Self Timer | Operates with approx. 2 sec. or approx 10 sec. count-down |
Wireless Control | Available (playback is available too) |
Continuous Shooting | High-Speed: Approx. 2.0 images/sec., Normal: Approx. 1.5 images/sec.(at Large/ Fine mode and LCD viewfinder is OFF) |
Image Storage
Storage Media | CompactFlash (CF) Card Type I or Type II |
Print Order Format | Digital Print Order Format (DPOF) Version 1.1 |
Image Recording Format | Still Image: JPEG (Exif 2.2 compliant) |
JPEG Compression Mode | SuperFine, Fine or Normal |
Number of Recording Pixels | Still image: Large: 2,592 x 1,944, Medium 1: 1,600 x 1,200, Medium 2: 1,024 x 768, Small: 640 x 480 Movie: 320 x 240 or 160 x 120 |
Number of Recordable Images
Image data |  These figures reflect standard shooting conditions established by Canon. Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode. |
Time of Recordable Movies
Movie data |  Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings. Total length of movie files recordable on specific CF cards; Individual movie clips are limited to 3 minutes maximum per clip. |
Playback Specifications
Playback Modes File | Single, Index (9 thumbnail images), Magnification (approx. 2.0x to 10x), Slide Show or Movie |
Erasing Specifications
Erase Modes | Single Image, All Images |
Interfaces
Computer Interface | Universal Serial Bus (USB) (mini-B jack) |
Video Out | Audio/Video Output (Video:NTSC or PAL selectable monaural audio) |
Other | CF card slot (accept type I and type II cards). Direct connection to Canon CP Printer and select BJ Printers (no computer required) |
Power Supply | 1. Rechargeable Lithium-ion battery (type: BP-511 or BP-512) 2. AC adapter (type: CA-560)3. Car battery adapter (type: CR-560)4. Coin-type secondary Lithium battery (CR-2025)Approx. 450 images (under Canon's standard conditions*1with full-charged battery)Approx. 360 minutes (under Canon's standard conditions*2 with full-charged battery) |
Power Source | 1. Rechargeable Lithium-ion battery (type: BP-511 or BP-512) 2. AC adapter (type: CA-560)3. Car battery adapter (type: CR-560)4. Coin-type secondary Lithium battery (CR-2025) |
Shooting Capacity | Approx. 450 images (under Canon's standard conditions*1with full-charged battery) |
Playback Time | Approx. 360 minutes (under Canon's standard conditions*2 with full-charged battery) |
Physical Specifications
Operating Temperature | 32-104°F (0-40°C) |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 4.76 x 2.91 x 2.75 in./121.0 x 73.9 x 69.9mm (Excluding protrusions) |
Weight | Approx. 14.5 oz./410g (camera body only) |
Computer System Requirements
Mac Requirements | Computer Model: Power Macintosh, PowerBook, eMac, iMac or iBook. CD-ROM drive required for installing software. OS: OS 9.0-9.2 or OSX 10.1-10.2 CPU: PowerPC Interface: USB (Models with Apple genuine USB interface only). |
PC Requirements | Computer Model: IBM PC/AT compatible. CD-ROM drive required for installing software. OS: Microsoft Windows 98 (including Second Edition)/ME/2000/XP CPU: Pentium 150MHz or higher processor (Windows 98/ME/2000), Pentium 300MHz or higher processor (Windows XP) Interface: USB (Windows 98/ME/2000/XP pre-install model only) |
Canon's standard conditions of measuring shooting capacity are as follows: Normal temperature (23 °C). LCD viewfinder is ON. Shoot images at wide angle end and at telephoto end alternately with 20 second intervals. Use flash every 4th shot. Turn camera off and on every 8th shot. Canon's standard conditions of measuring playback time are as follows: Normal temperature (23 °C). Repeat playback automatically at a speed of 1 image per 5 seconds. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
CONTACT US
