Canon Support for PowerShot G9 X | Canon U.S.A., Inc.
PowerShot G9 X
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | 20.2 Megapixel*, 1.0-inch CMOS (sensor aspect ratio: 3:2) *Image processing may cause a decrease in the number of pixels. |
Total Pixels | Approx. 20.9 Megapixels |
Effective Pixels | Approx. 20.2 Megapixels |
Focal Length | 10.2 (W) - 30.6 (T) mm (35mm film equivalent: 28-84mm) |
Optical Zoom | Approx. 3x |
Digital Zoom | Approx. 4x |
Focusing Range | Auto/Manual: 2.0 in. (5cm) - infinity (W), 1.1 ft. (35cm) - infinity (T) Normal: 2.0 in. (5cm) - infinity (W), 1.1 ft. (35cm) - infinity (T) Macro: 2.0 in. - 1.6 ft. (5-50cm) (W) |
Autofocus System | TTL Autofocus (Continuous, Servo AF), Manual Focus |
Optical Viewfinder | N/A |
LCD Monitor | 3.0-type TFT color liquid crystal |
LCD Pixels | Approx. 1.04 million dots |
LCD Coverage | Approx. 100% |
Maximum Aperture | f/2.0 (W), f/4.9 (T) |
Shutter Speed | 1-1/2000 sec. (in Auto mode) 30-1/2000 sec. (in Tv, M, and Manual Movie Modes) BULB (in M mode only) 1/8 minimum in Manual Movie Mode |
Sensitivity | Auto, ISO 125/160/200/250/320/400/500/640/800/1000/1250/1600/2000/2500/3200/4000/5000/6400 (When in Auto mode) Max. ISO Speed 12800 (When in P mode) |
Light Metering Method | Evaluative, Center Weighted Average, Spot |
Exposure Control Method | Manual Exposure, Program Shift, Safety Shift, AE Lock |
Exposure Compensation | Still Images: ±3 stops in 1/3-stop increments Videos: ±3 stops in 1/3-stop increments |
White Balance Control | Auto, Day Light, Shade, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Custom1-2 |
Built-in Flash | Auto, On, Slow Synchro, Off * Facial brightness is also evaluated in Face Detect. |
Flash Range | 1.6 (50cm) -20 ft. (6.0m) (W), 1.6 ft. (50cm) - 7.9 ft. (2.4m) (T) Image brightness may diminish depending on the shooting distance. |
Flash Exposure Compensation | ±2 stops in 1/3-stop increments |
Shooting Modes | C, M, Av, Tv, P, Hybrid Auto, Auto, Creative Shot, Portrait, Star Portrait, Star Nightscape, Star Trails, Star Time-Lapse Movie, Handheld Night Scene, Fireworks, High Dynamic Range, Nostalgic, Fish-eye Effect, Miniature Effect, Toy Camera Effect, Background Defocus, Soft Focus, Monochrome, Super Vivid, Poster Effect, Standard Movie, Short Clip, Manual Movie, iFrame Movie Shooting movies is done with the movie button. |
Photo Effects | My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color |
Self Timer | Off, Approx. 2 sec. delay, Approx. 10 sec. delay, Custom |
Wireless Control | Not available |
Continuous Shooting | One Shot: Approx. 6.0 shots/sec. Servo: Approx. 4.3 shots/sec. |
Storage Media | SD/SDHC/SDXC and UHS-I Memory Cards |
File Format | Design rule for Camera File system (DCF) compliant; DPOF (Version 1.1) compatible |
Image Recording Format | Superfine / Fine |
JPEG Compression Mode | Still Image: Exif 2.3 (DCF 2.0), RAW (Canon original: 14-bit, CR2) Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC [Stereo]) |
Number of Recording Pixels | Still Images: 1) 16:9 - Large: 5472 x 3080; Medium 1: 4320 x 2432; Medium 2: 1920 x 1080; Small: 720 x 408 2) 3:2 - Large: 5472 x 3648, Medium 1: 4320 x 2880, Medium 2: 2304 x 1536, Small: 720 x 480 3) 4:3 - Large: 4864 x 3648, Medium 1: 3840 x 2880, Medium 2: 2048 x 1536, Small: 640 x 480 4) 1:1 - Large: 3648 x 3648; Medium 1: 2880 x 2880; Medium 2: 1536 x 1536; Small: 480 x 480 Videos: Full HD 1920 x 1080: 59.94 fps Full HD iFrame: 1920 x 1080: 29.97 fps Full HD Star Time-Lapse Movie: 1920 x 1080: 14.985 fps / 29.97 fps HD 1280 x 720: 29.97 fps 640 x 480: 29.97 fps Miniature Effect: 1280 x 720: 6 fps (5x speed) / 3 fps (10x speed) / 1.5 fps (20x speed) Miniature Effect: 640 x 480: 6 fps (5x speed) / 3 fps (10x speed) / 1.5 fps (20x speed) Short Clip: 1280 x 720: 29.97 fps |
Image data | Approx. Number of Shots Recordable to 16 GB Memory Card Note: SF=Superfine F=Fine • The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly. |
Movie data | Time of Recordable Videos *1 Using an SD Speed Class 10 / UHS-I compatible memory card. • Recording stops automatically once the file size reaches 4 GB or the memory card becomes full. • Recording may stop unexpectedly if a memory card with a low Speed Class is used. *2 Actual frame rate is 23.976 fps. |
Playback Modes File | Story Highlights, Protect, Favorites, Erase, Print, Group Playback, Play Movie, List/Play Digest Movies, Image Search, Slideshow, Rotate, Play Creative Shot Movies, Short Clip Mix, i-Contrast, Resize, Cropping, Red-Eye Correction, My Colors, Face ID Info, Print Settings, Photobook Set-up, Transition Effect, Index Effect, Scroll Display, Group Images, Auto Rotate, Resume, Image Jump with Control Ring, Set Touch Actions |
Erase Modes | Select Image, Select Range, Select All Images The image data in the memory card stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased). Using the Movie editing function, sections of the movie can be deleted. RAW + JPEG images can be erased individually. |
Video Out | NTSC/PAL |
Audio Out | Stereo |
Other | Direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers Wired USB (Micro-B), HDMI (Type D) Wireless Specifications: IEEE 802. 11b/g/n Frequency: 2.4 GHz Channels: 1-11 Security: WEP, WPA-PSK (AES/TKIP), WPA2-PSK (AES-TKIP) |
Power Source | Battery Pack NB-13L, AC Adapter Kit CA-DC10 (ACK-DC110)In-Camera Charging via USB Cable available through Compact Power Adapter CA-DC30 (Charging time: Approx. 5 hr.)* * Charging time varies considerably depending on the remaining battery power. |
Shooting Capacity | Approx. 220 shots with Screen On Approx. 335 shots with ECO Mode Approx. 410 shots with ECO Mode |
Playback Time | Approx. 5 hr. |
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 3.86 x 2.28 x 1.21 in. / 98.0 x 57.9 x 30.8mm |
Weight | 7.37 oz. / 209g (including battery and memory card) 6.53 oz. / 185g (camera body only) |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
