Canon Support for PowerShot Pro 90 IS | Canon U.S.A., Inc.
PowerShot Pro 90 IS
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Image Capture Device
Type | Interline transfer CCD |
Total Pixels | Approx. 3.34 million (2,140 x 1,560) |
Effective Pixels | Approx. 3.24 million (2,088 x 1,550) |
Lens
Focal Length | 7mm (Wide-angle) - 70mm (Telephoto)(37mm (Wide-angle) - 370mm (Telephoto) (35mm film equivalent) |
Focusing Range | Wide-angle: 10cm (3.9 in.) - infinity Telephoto: 1m (39 in.) - infinity Normal: 3.3 ft. (1m) - Infinity (63mm equivalent - T) Normal+Tele-converter: 7.2 ft. (2.2m) - Infinity (126mm equivalent - T) Normal+Close-up Lens: 1.1 - 1.6 ft. (33 - 50cm) (T) Macro: 3.9 in. - 1.6 ft. (10 - 50cm) (W - 63mm equivalent) Macro: 1.0 - 1.6 ft. (30 - 50cm) (63 - 90mm equivalent) Super Macro: 1.2 in. - 1.0 ft.(3 - 30cm) (42 - 90mm equivalent) Manual: 3.9 in. (10cm) - Infinity (W - 63mm equivalent) Manual: 1.0 ft. (30cm) - Infinity (63mm - 90mm equivalent) Manual: 3.3 ft. (1m) - Infinity (90mm equivalent - T) |
Autofocus System | 13 elements in 10 groups |
Viewfinders
Optical Viewfinder | Color LCD viewfinder |
LCD Monitor | 46mm diagonal (1.8 inch) Low-temperature polycrystalline silicon TFT LCD |
LCD Pixels | 113,578 dot (521 (H) x 218 (V)) |
LCD Coverage | 100% |
Aperture and Shutter
Maximum Aperture | Wide-angle : f/2.8-f/8.0 / Telephoto : f/3.5-f/8.0 |
Shutter Speed | 8 - 1/1000 sec. |
Exposure Control
Sensitivity | Auto/ISO 50/100/200/400 |
Light Metering Method | Center-weighted averaging/Spot |
Exposure Control Method | Program AE/Shutter speed-priority AE/Aperture-priority AE/Manual |
Exposure Compensation | Compensation +/-2.0 in 1/3-stop increments |
White Balance
White Balance Control | TTL auto / preset (Daylight, Cloudy, Tungsten, Fluorescent and Flash) or Custom |
Flash
Built-in Flash | Auto, Red-Eye Reduction auto, Red-Eye Reduction ON, ON or OFF |
Flash Range | 0.7 - 4.2 m (Wide-angle) / 1 - 3.4 m (Telephoto) |
Recycling Time | 10 sec. or shorter (full flash, battery voltage = 7.4 V) |
Flash Exposure Compensation | +/-2.0 EV (at every 1/3-stop) |
Shooting Specifications
Shooting Modes | Auto, Creative zone (Manual / Shutter speed-priority / Aperture-priority / Program), Image zone (Pan-focus / Portrait / Landscape / Night Scene / Black & White / Stitch Assist / Movie) |
Self Timer | Operates with approx. 10-sec. countdown |
Wireless Control | Shooting and playback are available (Wireless controller is included in the camera kit)When shooting, image is captured 2 seconds after shutter release operation. |
Continuous Shooting | 0.7 images/sec. (at Large / Fine) |
Image Storage
Storage Media | CompactFlash Card Type I, II |
File Format | Design rule for Camera File system (DCF) (main image and thumbnail: JPEG)(DCF is an abbreviation of "Design rule for Camera File System" standardized by Japan Electronics and Information Technology Industries Association (JEITA)) |
Print Order Format | DPOF ver. 1.0 |
Image Recording Format | JPEG or RAW (still image)AVI (Motion JPEG : image, WAVE: audio (monaural)) (movie) |
JPEG Compression Mode | Super Fine, Fine and Normal/CCD RAW |
Number of Recording Pixels | Large: 1,856 x 1,392, Middle: 1,024 x 768, Small: 640 x 480, Movie: 320 x 240 |
Number of Recordable Images
Image data | |
Power Supply |
Physical Specifications
Operating Temperature | 0 - 40°C (32 - 104°F) |
Operating Humidity | 10 - 90% |
Dimensions (W x H x D) | 4.98 in. x 3.3 in x 5.48 in./126.5 x 83.9 x 139.1mm (excluding protrusions) |
Weight | Approx. 680 g (23.9oz) (excluding batteries and CF card) |
Computer System Requirements
Mac Requirements | Hardware: Power Macintosh, PowerBook, iMac or iBook OS: Mac OS 8.1, QuickTime 3.0 or higher (QuickTime 4.1 is in the CD-ROM "DIGITAL CAMERA Solution Disk" included in this package) (Please see our Mac OS X Compatibility Statement.) CPU: Power PC Interface: USB (iMac, iBook and Power Macintosh NEW G3 / Power Macintosh G4 or PowerBook G3 with Apple genuine USB interface only. IMac Update 1.0 and iMac Firmware Update 1.0 must be installed for use in your iMac computer under Mac OS 8.1); RS-422 (Modem port or printer port - optional Interface Cable IFC-200MC is required). RAM: 20MB RAM minimum for application memory Display: 800 x 600 pixels - 256 colors minimum, 1024 x 768 pixels - thousands of colors or more recommended |
PC Requirements | Hardware: IBM PC/AT compatible OS: Windows 95/98 (including the Second Edition), Windows NT 4.0 (Service Pack 3 or higher required), Windows 2000, Windows ME(Please see our Windows XP Compatibility Statement.) CPU: Pentium 133 MHz or better. Interface: USB: Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME systems. RS-232C: Serial or COM port. RAM: 32MB or more (Windows 95/98), 64MB or more (Windows NT 4.0/Windows 2000/Windows ME) |
Plug-In Module requires Adobe Photoshop 3.0 or higher (Adobe Photoshop 5.0LE is included in this package). * Warranty program is subject to certain restrictions and limitations. See warranty card for full details. All data are based on Canon's standard test method. Subject to change without notice. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
CONTACT US
