Canon Support for PowerShot S330 | Canon U.S.A., Inc.
PowerShot S330
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Type of Camera
Type | Compact Digital Still Camera with Built-in Flash, 3x Optical Zoom Lens, and 2.5x Digital Zoom |
Image Capture Device
Type | 1/2.7 inch Charge-Coupled Device (CCD) |
Total Pixels | Approx. 2.1 million |
Effective Pixels | 2 million |
Lens
Focal Length | 5.4-16.2mm (35mm film equivalent: 35-105mm) |
Digital Zoom | 2.5x Digital Zoom (Maximum 7.5x digital zoom is available when combined with the 3x optical zoom.) |
Autofocus System | TTL AiAF (3 focusing points), TTL AF (center focusing point) |
Viewfinders
Optical Viewfinder | Real-image optical zoom viewfinder, approx. 82% coverage |
LCD Monitor | 1.5 inch low temperature polycrystalline silicon TFT color LCD |
Aperture and Shutter
Maximum Aperture | f/2.8- f/4.7 |
Shutter Speed | 15-1/1500 sec. |
Exposure Control
Sensitivity | Equivalent to ISO 50/100/200/400 |
Light Metering Method | Evaluative Metering or Spot Metering |
Exposure Control Method | Full Auto exposure control; Manual slow shutter speeds from 1 sec-15 sec can be user-set in low light |
Exposure Compensation | +/- 2.0 EV in 1/3-stop increments |
White Balance
White Balance Control | TTL Auto White Balance, Pre-Set White Balance (Available Settings: Daylight, Cloudy, Tungsten, Fluorescent, or Fluorescent H), Custom |
Flash
Built-in Flash | Operation Modes: Auto/On/Off, Auto Red-Eye Reduction Auto/On, Slow-Sync. |
Shooting Specifications
Shooting Modes | Auto (Program AE), Manual (Slow shutter speeds only), Stitch Assist, Movie, Photo Effect (Vivid Color, Neutral Color, Low Sharpening, Sepia, Black & White). |
Continuous Shooting | Approx. 2.5 images/sec. |
Image Storage
Storage Media | CompactFlash (CF) Card Type I |
File Format | Design rule for Camera File system (DCF*1) |
Print Order Format | Digital Print Order Format (DPOF) Version 1.1; EXIF Print Compliant (EXIF 2.2) |
Image Recording Format | Still Image: JPEG Movie: AVI |
JPEG Compression Mode | SuperFine, Fine or Normal |
Number of Recording Pixels | Small: 640 x 480, Medium: 1,024 x 768, Large: 1,600 x 1,200, Movie: 320 x 240 or 160 x 120. |
Number of Recordable Images
Image data |  These figures reflect standard shooting conditions established by Canon. Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode. |
Time of Recordable Movies
Movie data |  Figures for Movie Mode represent total capacity of CompactFlash Card. Individual clips are limited to 10 or 30 seconds. Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings. |
Playback Specifications
Playback Modes File | Single, Index (9 thumbnail images), Magnification (2x to 10x), or Slide Show |
Erasing Specifications
Erase Modes | Single Image, All Images |
Interfaces
Computer Interface | Universal Serial Bus v.1.1(USB) |
Video Out | Audio/Video Output (Video:NTSC or PAL selectable, Audio: monaural) Other CF card slot (complied with CF Type I standard). Direct connection to Canon Card Photo Printer CP-100 and CP-10 (no computer required). |
Power Supply | Lithium ion battery NB-1LH or NB-1L. Compact Power Adapter CA-PS500. Important safety informationLCD ON: 150 images, LCD OFF: 420 images100 minutes |
Power Source | Lithium ion battery NB-1LH or NB-1L. Compact Power Adapter CA-PS500. Important safety information |
Shooting Capacity | LCD ON: 150 images, LCD OFF: 420 images |
Playback Time | 100 minutes |
Physical Specifications
Dimensions (W x H x D) | 3.7 x 2.5 x 1.2 in. / 94.8 x 62.5 x 31.5mm |
Weight | 8.6 oz. / 245g |
Computer System Requirements
Mac Requirements | Hardware: Power Macintosh, PowerBook, iMac or iBook OS: Mac OS 8.6 through 9.1 (Please see our Mac OS X Compatibility Statement)CPU: Power PC Interface: USB: Cable connection via camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface (Power Macintosh NEW G3/G4, PowerBook G3, iMac, iBook). RAM: 20MB and over for application |
PC Requirements | Hardware: IBM PC/AT compatible. OS: Windows 98 (including the Second Edition), Windows 2000, Windows Me, Windows XPCPU: Pentium 150 MHz and over Interface: USB: Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME or Windows XP systems. RAM: 32MB or more (Windows 98)RAM: 64MB or more (Windows 2000/Windows ME)RAM: 128MB or more (Windows XP) |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
CONTACT US
