Canon Support for PowerShot S60 | Canon U.S.A., Inc.
PowerShot S60
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.07 MB
Date 03.05.10
File Size 6.23 MB
Date 04.01.07
File Size 3.45 MB
Date 04.01.07
File Size 349.02 KB
Date 04.01.07
File Size 937.87 KB
Date 04.01.07
File Size 1.60 MB
Date 04.01.07
File Size 4.14 MB
Date 04.01.07
File Size 2.36 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash and 3.6x optical zoom
Image Capture Device
Type 1/1.8 inch charge coupled device (CCD)
Total Pixels Approx. 5.3 Million
Effective Pixels Approx. 5.0 Million
Lens
Focal Length 5.8 (W) - 20.7 (T)mm zoom lens (35mm film equivalent: 28 - 100mm)
Digital Zoom 4.1x
Focusing Range Normal AF: 50cm (1.6 ft.) - infinity (W/T); Macro AF: 4 - 50cm/1.6 in. - 1.6 ft. (W)/30 - 50cm/1.0 - 1.6 ft. (T)
Autofocus System 9-point AiAF (Automatic Focus Point Selection)/1-point AF (Fixed to center)
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 1.8-inch low temperature polycrystalline silicon TFT color LCD
LCD Pixels Approximately 118,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.8 - f/8.0 (W); f/5.3 - f/8.0 (T)
Shutter Speed 15-1/2,000 sec.
Exposure Control
Sensitivity AUTO*/ISO 50/100/200/400 equivalent (*Camera automatically sets optimum speeds.)
Light Metering Method Evaluation/Center-weighted average/Spot* (*Metering frame selectable from center fixed/ AF point-linked)
Exposure Control Method Program AE, Shutter priority AE, Aperture priority AE or Manual
Exposure Compensation +/- 2 EV in 1/3-stop increments
Auto Exposure Bracketing (AEB) is available
White Balance
White Balance Control TTL Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, or Flash, Underwater), or Custom White Balance (1 position)
Flash
Built-in Flash Operation Modes: Auto/On/Off, Red-Eye Reduction On/Off, Slow Syncro
Flash Range Normal: 55cm - 3.7m/1.8 - 12 ft. (W); 55cm - 2.0m/1.8 - 6.6 ft. (T) (when ISO is set to AUTO)
Recycling Time Approx. 10 sec. or less.(battery voltage=3.7V)
Flash Exposure Compensation +/- 2.0 EV in 1/3-stop increments
Shooting Specifications
Shooting Modes Creative zone: P, Av, Tv, M, Custom; Image zone: Portrait, Landscape, Night Scene, Fast Shutter, Slow Shutter, Stitch Assist, Movie
Photo Effects Vivid, Neutral, Low Sharpening, Sepia, Black and White and Custom
Self Timer Operates with approx. 2 sec. or approx 10 sec. countdown
Wireless Control Available (playback is available too)
Continuous Shooting High Speed: Approx. 2.0 shots/sec.; Normal Speed: Approx. 1.5 shots/sec.; (Large/Fine Mode and LCD monitor is Off)
Image Storage
Storage Media CompactFlash (CF) Card Type I or Type II
File Format Design rule for Camera File System (DCF*1)
Print Order Format Digital Print Order Format (DPOF) Version 1.1
Image Recording Format Still Image: JPEG (Exif 2.2 compliant)/RAW
JPEG Compression Mode SuperFine, Fine or Normal
Number of Recording Pixels Still Image: 2,592 x 1,944 (Large), 2,048 x 1,536 (Medium 1), 1,600 x 1,200 (Medium 2), 640 x 480 (Small); Movie: 640 x 480, 320 x 240, 160 x 120
Number of Recordable Images
Image data
Description These figures reflect standard shooting conditions established by Canon.
Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode.
Time of Recordable Movies
Movie data
Description Individual movie clips are limited to 3 minutes maximum per clip (30 seconds maximum for Movie/High). Above figures show total movie capacity on various CF cards, measured under Canon's standard test conditions, and may vary depending upon scene, subjects or camera settings.
Playback Specifications
Playback Modes File Single, Index (9 thumbnails), Magnification (2x to 10x), Slide Show or Movie
Erasing Specifications
Erase Modes Stil Images: Single Image, All Images; Movie: Part of Movie, All Movie
Interfaces
Computer Interface Universal Serial Bus (USB) (mini-B jack)
Video Out NTSC/ PAL
Other CF card slot (accepts Type I & Type II cards). Direct connection to Canon CP Printers and select BJ Photo Printers (no computer required)
Power Supply Rechargeable Lithium-ion battery (NB-2LH or NB-2L); Compact Power Adapter CA-PS700; Car Battery Charger CBC-NB2NB-2LH: Approx. 240*2 (LCD on), Approx. 550 (LCD off)Approx 210 min. *3
Power Source Rechargeable Lithium-ion battery (NB-2LH or NB-2L); Compact Power Adapter CA-PS700; Car Battery Charger CBC-NB2
Shooting Capacity NB-2LH: Approx. 240*2 (LCD on), Approx. 550 (LCD off)
Playback Time Approx 210 min. *3
Physical Specifications
Operating Temperature 32 - 104 &deg;F (0 - 40 &deg;C)
Operating Humidity 10 - 90%
Dimensions (W x H x D) 4.49 x 2.22 x 1.53 in./ 114.0 x 56.5 x 38.8mm (Excluding protrusions)
Weight Approx. 8.11 oz./ 230g (Camera body only)
Computer System Requirements
Mac Requirements OS: Mac OS 9.0 - 9.2, Mac OS X (v10.1/10.2); Computer Model: The above OS should be pre-installed on computer with built-in USB ports; CPU: PowerPC; Interface: USB (Models with Apple genuine USB interface only)
PC Requirements OS: Microsoft Windows 98 (including Second Edition)/Me/2000/XP; Computer Model: The above OS should be pre-installed on computer with built-in USB ports; CPU: Pentium 150MHz or higher processor (Windows 98/ Me/2000), Pentium 300MHz or higher processor (Windows XP); Interface: USB (Windows 98/Me/2000/ XP pre-install model only)
*1 "DCF" is an abbreviation of "Design rule for Camera File system" standardized by Japan Electronics and Information Technology Industries Association (JEITA).
*2 Using fully charged NB-2LH. Normal temperature (23 &deg;C). Shoot images at wide angle and at telephoto end alternatively with 20 seconds intervals. Use flash at every 4-time shooting. Turn camera off and on at every 8-time shooting. LCD brightness setting by Factory default.
*3 Using fully charged NB-2LH. Normal temperature (23 &deg;C). Repeat playback at a speed of 1 image per 3 seconds. LCD monitor brightness setting by Factory default.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
