Canon Support for PowerShot SD110 | Canon U.S.A., Inc.
PowerShot SD110
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Type of Camera
Type | Compact digital still camera with built-in flash and 2.0x Optical / 3.2x Digital /6.4x Combined Zoom |
Image Capture Device
Type | 1/2.7 inch Charge-Coupled Device (CCD) |
Total Pixels | Approx. 3.3 Million |
Effective Pixels | Approx. 3.2 Million |
Lens
Focal Length | 5.4 (W) - 10.8 (T)mm, f/2.8 (W) - 3.9 (T) zoom lens (35mm film equivalent: 35 - 70mm) |
Digital Zoom | 3.2x |
Focusing Range | Normal: AF: 1.5 ft. - Infinity/47cm - Infinity Macro AF: 3.9 in. - 1.5 ft./10 - 47cm (W); 9.1 in. - 1.5 ft./ 23 - 47cm (T) |
Autofocus System | 9-point AiAF/1-point AF (Fixed to center) |
Viewfinders
Optical Viewfinder | Real-image Optical Zoom viewfinder |
LCD Monitor | 1.5 inch low temperature polycrystalline silicon TFT color LCD |
LCD Pixels | Approx. 118,000 pixels |
LCD Coverage | 100% |
Aperture and Shutter
Maximum Aperture | f/2.8/7.1 (W), f/3.9/10.0 (T) |
Shutter Speed | 15 - 1/1,500 sec.* * Manual setting is available from 15 to 1 sec. when in Long Shutter mode. |
Exposure Control
Sensitivity | Auto*; ISO 50/100/200/400 (equivalent ISO) *Camera automatically sets optimum speeds. |
Light Metering Method | Evaluative, Center-weighted average or Spot* *Metering frame when spot is center fixed. |
Exposure Control Method | Program AE |
AE Lock | Available |
White Balance
White Balance Control | Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H), or Custom White Balance |
Flash
Built-in Flash | Auto, Red-Eye Reduction On/Off, Slow-Sync |
Flash Range | Normal: 1.5 - 9.8 ft./47cm - 3.0m (W); 1.5 - 6.6 ft./47cm - 2.0m (T)Macro: 10.6 in. - 1.5 ft./ 27 - 47cm (W/T)(When ISO is set to AUTO) |
Recycling Time | Approx. 10 sec. or less |
Shooting Specifications
Shooting Modes | Auto, Manual*1, Stitch Assist*2, Movie. *1 Long Shutter mode is also available.*2 Selectable from Rec. Menu |
Photo Effects | Vivid, Neutral, Low Sharpening, Sepia, Black & White |
Self Timer | Operates with approx. 2 sec. or 10 sec. count-down. |
Wireless Control | Not Available |
Continuous Shooting | Approx. 2.2 shots/sec. (Large/Fine Mode and LCD monitor is Off) |
Image Storage
Storage Media | SD Memory Card (If Multimedia card [MMC] is used, the performance is not guaranteed.) |
File Format | Design Rule for Camera File System, (DCF) |
Print Order Format | Digital Print Order Format (DPOF) Version 1.1 |
Image Recording Format | Still Image: JPEG (Exif 2.2 compliant) |
JPEG Compression Mode | SuperFine, Fine or Normal |
Number of Recording Pixels | Large: 2,048 x 1,536, Medium1: 1,600 x 1,200, Medium2: 1,024 x 768, Small: 640 x 480 pixels Movie: 640 x 480, 320 x 240 or 160 x 120 |
Number of Recordable Images
Image data |
Time of Recordable Movies
Movie data |
Playback Specifications
Playback Modes File | Single, Index (9 thumbnail images), Magnification (2x to 10x) |
Erasing Specifications
Erase Modes | Still images: Single Image, All Images Movie: Part of Movie, All Movie |
Interfaces
Computer Interface | USB (mini-B jack) |
Video Out | NTSC or PAL |
Other | SD memory card slot. Direct connection to Canon CP Printers and BJ Photo Printers (no computer required), using camera's USB cable. |
Power Supply | 1. Rechargeable Lithium-ion battery (NB-3L) 2. Compact Power Adapter (CA-PS500 & DC Coupler DR-900)NB-3L: LCD On - Approx. 210; LCD Off - Approx. 550Approx. 180 min. |
Power Source | 1. Rechargeable Lithium-ion battery (NB-3L) 2. Compact Power Adapter (CA-PS500 & DC Coupler DR-900) |
Shooting Capacity | NB-3L: LCD On - Approx. 210; LCD Off - Approx. 550 |
Playback Time | Approx. 180 min. |
Physical Specifications
Operating Temperature | 32 - 104°F (0 - 40°C) |
Operating Humidity | 10 - 90% |
Dimensions (W x H x D) | 3.35 x 2.20 x 0.94 in./ 85 x 56 x 23.9mm (Excluding protrusions) |
Weight | Approx. 5.82 oz./ 165g (Camera body only) |
Computer System Requirements
Mac Requirements | OS: Mac OS 9.0 - 9.2, Mac OS X (v10.1/10.2). Computer Model: The above OS should be pre-installed on computer with built-in USB ports. CPU: PowerPC. Interface: USB (Models with Apple genuine USB interface only). |
PC Requirements | OS: Microsoft Windows 98 (including Second Edition)/Me/2000/XP. Computer Model: The above OS should be pre-installed on computer with built-in USB ports. CPU: Pentium 150MHz or higher processor (Windows 98/ Me/2000), Pentium 300MHz or higher processor (Windows XP). Interface: USB (Windows 98/Me/2000/ XP pre-install model only). |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
CONTACT US
