Canon Support for PowerShot SD3500 IS | Canon U.S.A., Inc.
PowerShot SD3500 IS
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Type | 14.1 Megapixel, 1/2.3-inch type Charge Coupled Device (CCD) |
Total Pixels | Approx. 14.5 Megapixels |
Effective Pixels | Approx. 14.1 Megapixels |
Focal Length | 4.3 (W) - 21.5 (T) mm (35mm equivalent: 24 - 120mm) |
Digital Zoom | 4x |
Focusing Range | Normal: 2.0 in./5 cm - infinity, 3.0 ft./90cm (T) - infinity Macro: 2.0 in. - 1.6 ft./5 - 50cm (W) - infinity |
Autofocus System | TTL Autofocus |
Optical Viewfinder | N/A |
LCD Monitor | 3.5-inch LCD with wide viewing angle and Touch Panel Technology |
LCD Pixels | Approx. 461,000 dots |
LCD Coverage | Approx. 100% |
Maximum Aperture | f/2.8 (W) - f/5.9 (T) |
Shutter Speed | 1 - 1/3000 sec. 15 - 1/3000 sec. (Total shutter speed range), Long Shutter operates with noise reduction when manually set at 1.3 - 15 sec. Shutter speeds differ depending on the shooting mode Shutter speeds available in Long Shutter: 15, 13, 10, 8, 6, 5, 4, 3.2, 2.5, 2, 1.6, 1.3, 1 (unit: sec.) |
Sensitivity | Auto*, ISO 80/100/200/400/800/1600 equivalent (Standard output sensitivity. Recommended exposure index) * Camera automatically sets the optical ISO speed according to the shooting mode and subject brightness. The ISO speed also varies according to subject movement and camera shake when the shooting mode is set in Auto. |
Light Metering Method | Evaluative*, Center-Weighted average, Spot** * Facial brightness is also evaluated in Face AiAF ** Metering frame is fixed to the center |
Exposure Control Method | Program AE; i-Contrast; AE Lock |
Exposure Compensation | +/-2 stops in 1/3-stop increments |
White Balance Control | Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom * Facial color is evaluated in Face AiAF |
Built-in Flash | Auto, Red-eye Reduction, Auto Red-eye Correction, Flash On, Flash Off; FE lock, Slow Synchro |
Flash Range | 1.6 - 11 ft./50cm - 3.5m (W), 3.0 - 6.6 ft./90cm - 2.0m (T) Image brightness may diminish depending on the shooting distance. |
Recycling Time | 12 sec. or less (battery voltage=3.7V) |
Flash Exposure Compensation | N/A |
Shooting Modes | Auto*, P, Portrait, Night Snapshot, Kids & Pets, Indoor, Smart Shutter*, Low Light, Color Accent, Color Swap, Fisheye Effect, Miniature Effect, Creative Light Effect, Beach, Foliage, Snow, Fireworks, Long Shutter, Movie*Automatically detects shooting scene**Smile, Wink Self-timer, Face Detection Self-timer |
Photo Effects | My Colors Off, Vivid, Neutral, Sepia, Black & White, Lighter Skin, Darker Skin, Vivid Blue, Vivid Green, Vivid Red, Custom* *Adjustment of contrast, sharpness saturation red, green, blue and skin tone are available. |
Self Timer | Approx. 10 sec. delay/approx. 2-sec. delay custom* *Shooting start time (0-10 sec. (in 1-second increments) 15/20/30 sec.) and number of shots (1-10 shots (in 1-shot increments) can be specified. |
Wireless Control | N/A |
Continuous Shooting | Approx. 0.7 shots/sec (approx. 2.7 shots/sec. in Low Light) |
Storage Media | SD/SDHC/SDXC Memory Card, MultiMediaCard, MMCplus Card, HC MMCplus Card |
File Format | Design rule for camera file system, DPOF (Version 1.1) compliant |
Image Recording Format | Normal, Fine |
JPEG Compression Mode | Still Image: Exif 2.2 (JPEG) Movie: MOV (Image: H.264; Audio: Linear PCM (Monaural)) |
Number of Recording Pixels | Still Image: 4,320 x 3,240 (Large), 3,456 x 2,592 (Medium 1), 2,592 x 1,944 (Medium 2), 1,600 x 1,200 (Medium 3/Date Stamp), 640 x 480 (Small), 4,320 x 2,432 (Widescreen), 2,144 x 1,608 (Low Light)Movie: HD 1,280 x 720 (30 fps available up to 10 min. or 4GB per clip), 640 x 480 (30 fps), 320 x 240 (30 fps) available up to 60 minutes or 4GB per clip |
Image data |
Movie data | *Actual frame rate is 29.97 fps Note: N=Normal F=Fine Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media. |
Playback Modes File | - Auto Rotate (Automatic vertical/horizontal detection), Resume Playback, Image Advance (Operation Tools, Transition effects, Scroll Display, Active Display), Rotate, Favorites, My Category, Smart Shuffle, Filtered Playback, Slide Show (Playback Interval, Repeat, Effect, Playlist) - Still Image: Single, Magnification (approx. 2x-10x), Auto Rotate, Rotate, Resume, My Colors, My Category, Transition Effects (3 types), Histogram, Overexposure Warning, Index (4 - 130 thumbnails), Slide Show, Red-eye Correction, Trimming, Resize, i-Contrast - Movie: Normal Playback, Special Playback, Editing, Resume *Auto settings available in 5 levels **5 levels (including normal playback), sound not available. |
Erase Modes | Still Image: Select image, select all images (all filtered images) Movie: part of movie, all of movie |
Computer Interface | Hi-Speed USB (Dedicated connector (female) with unified type of digital, audio, and video*) HDMI (HDMITM mini connector) * mini-B compatible. |
Video Out | NTSC/PAL (Dedicated connector (female) with unified type of digital, audio, and video) |
Audio Out | Monaural |
Other | SD Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable |
Power Supply | 1. Rechargeable Lithium-ion Battery NB-6L 2. AC Adapter Kit ACK-DC40 (optional)Still Image: approx. 220 shots* *LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used. Approx. 5 hours. * LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used. |
Power Source | 1. Rechargeable Lithium-ion Battery NB-6L 2. AC Adapter Kit ACK-DC40 (optional) |
Shooting Capacity | Still Image: approx. 220 shots* *LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used. |
Playback Time | Approx. 5 hours. * LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used. |
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 3.91 x 2.20 x 0.87 in./99.3 x 55.7 x 22.0 mm |
Weight | Approx. 5.64 oz./160g (including batteries and memory card)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi) All data are based on Canon's Standard Test Method. Subject to change without notice. Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
CONTACT US
