Canon Support for REALiS WX6000 D Pro AV | Canon U.S.A., Inc.
Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Date 11.12.13
File Size 144.61 KB
Date 11.28.12
File Size 1.53 MB
Date 10.08.12
File Size 488.0 KB
Image Mode
Standard, Presentation, Vivid Photo, Photo/sRGB, DICOM SIM, Dynamic, Video, Cinema
Image Mode
PC: Standard/Presentation, Vivid Photo, User (1-5)<br/>Video: Dynamic, Photo/sRGB/Video, Cinema, User (1-5)
(Input) HDMI
Digital RGB Input
(Input) DVI-D 29pin
Digital RGB / Digital Video Input (supports Deep Color)
(Input) Mini D-Sub 15pin
Analog RGB / Component Video Input
Power
336W
Throw Ratio
1.5:1 - 2.25:1
Focal Length
23.0 - 34.5 mm, 1.5x Optical Zoom
F-Number
1.89 - 2.65
Projection Distances
4.26 - 95.14 ft. (1.3 - 29 m)
Lens Shift (Vertical)
Down 15% - Up 55%
Lens Shift (Horizontal)
Left 10% - Right 10%
Screen Sizes
40" - 600"
Throw Ratio
2.2:1 - 3.75:1
Focal Length
34.0 - 57.7 mm, 1.7x Optical Zoom
F-Number
2.0 - 2.8
6.23 - 159.12 ft. (1.9 - 48.5 m)
Down 15% - Up 55%
Screen Sizes
40" - 600"
Throw Ratio
0.8:1
Focal Length
12.8 mm
F-Number
2.0
2.29 - 17.06 ft. (0.7 - 5.2 m)
Down 5% - Up 5%
Left 2% - Right 2%
Screen Sizes
40" - 300"
Throw Ratio
3.7 &sim; 7.3:1
Focal Length
53.6 - 105.6mm
F-Number
2.34 - 2.81
15.1 &sim; 290.7 ft.
-15% &sim; 55%
&plusmn;10%
Screen Sizes
60" - 600"
Throw Ratio
1.03:1 - 1.54:1
Focal Length
15.56 - 23.34mm
F-Number
2.09 - 2.34
2.95-65.28 Feet (0.9 - 19.9m)
Down 15% - Up 55%
Screen Sizes
40" - 600"
Projector Specifications
Imaging Device 0.70" LCOS Reflective LCD panels x 3
Aspect Ratio 16:10
Native Resolution WXGA+ (1440 X 900)
Brightness 5700 Lumens
Uniformity 88%
Contrast Ratio 1000:1
Digital Keystone (Vertical) ± 20 degrees
Digital Keystone (Horizontal) ± 20 degrees
Optics
Projection Lens Projector does not ship with lens. 4 optional interchangeable lenses are available (see Optics listed below).
Image Adjustments
Mounting Ceiling, Rear, Rear-Ceiling, Upward, Downward
Tilt Angle Adjustable feet up to 6 degrees
Input Signals
Analog PC Input UXGA / WSXGA+ / SXGA+ / WXGA+ / WXGA / SXGA / XGA / SVGA / VGA
Digital PC Input UXGA / WSXGA+ / SXGA+ / WXGA+ / WXGA / SXGA / XGA / SVGA / VGA
Component Input 1080p / 1080i / 720p / 576p / 576i / 480p / 480i
Digital Video Input 1080p / 1080i / 720p / 576p / 480p
Terminals
(Input) DVI-I 29pin Analog PC / Digital PC input
(Input) HDMI: Digital PC/ Digital Video Input (supports Deep Color)
(Input) D-Sub 15pin Analog PC / Component Video Input
(Input) RJ-45 Yes
(Input) Stereo Mini Jack Audio Input x2
(Output) Stereo Mini Jack Audio Output x1
Built-in Speaker 5W (Mono)
Control Terminal D-sub 9pin: RS-232C
Network: RJ-45 (100BASE-TX / 10BASE-T)
Lamp
Lamp Type 330W NSH (AC)
Power: 336W
Remote Control
Sensor Wireless Infrared, Front/Back Wired Remote Control Connection
Ratings
Fan Noise (Quiet/Normal) 40dB
Power Consumption (Normal/Quiet/Stand-By) 435W / 1.7W (Standby) / 0.35W (Standby with LAN off)
Power Voltage AC 100 , 240V, 50/60Hz
Temperature Operating 41&deg; to 95&deg; F (5&deg; to 35&deg; C)
Temperature Storage 14&deg; to 140&deg; F (-10&deg; to 60&deg; C)
Dimension (WxHxD) 14.9 x 6.69 x 16.9 in. (without lens, including protruding parts)
Weight 18.74 lbs. without lens
Warranty 3 years parts and labor, 120 day lamp
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
