Canon Support for REBEL T3I | Canon U.S.A., Inc.
REBEL T3I
Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Date 07.23.12
File Size 6.38 MB
Date 01.25.12
File Size 10.69 MB
Date 07.23.12
File Size 6.88 MB
Date 10.02.24
File Size 142.00 B
Date 09.30.24
File Size 142.00 B
Date 04.02.12
File Size 18.93 MB
Date 02.07.11
File Size 1.80 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
High-sensitivity, high-resolution, large single-plate CMOS sensor
Pixels
Effective pixels: Approx. 18.0 megapixels
Total Pixels
Total pixels: Approx. 18.70 megapixels
Aspect Ratio
3:2 (Horizontal : Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Fixed position in front of the CMOS sensor
Dust Deletion Feature
(1)Automatic Sensor CleaningRemoves dust adhering to the low-pass filter.Self-cleaning executed automatically (taking 2 sec.) when power is turned on or off. Manual execution also possible (taking 5 sec.).Low-pass filter has a fluorine coating.(2)Dust Delete Data appended to the captured imageThe coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots.(3) Manual cleaning of sensor
Recording Format
Design rule for Camera File System 2.0 and 2.30
File Size
(1) Large: Approx. 17.90 Megapixels (5,184 x 3,456)
(2) Medium: Approx. 8.00 Megapixels (3,456 x 2,304)
(3) Small: Approx. 4.50 Megapixels (2,592 x 1,728)
(4) S2: Approx. 2.50 Megapixels (1,920 x 1,280)
(5) S3: Approx. 0.35 Megapixels (720 x 480)
(6) RAW: Approx. 17.90 Megapixels (5,184 x 3,456)
Exact file sizes depend on the subject, ISO speed, Picture Style, etc.
Recording Functions
Images record directly to the SD card.
File Numbering
Consecutive numbering, auto reset, manual reset.
RAW + JPEG Simultaneous Recording
RAW and Large JPEG images are recorded simultaneously
Color Space
sRGB, Adobe RGB
Picture Style
Auto, Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3
Settings
Auto, Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash, Custom
Auto White Balance
Auto white balance with the image sensor
Color Temperature Compensation
White balance correction:Blue/amber bias: &plusmn;9 levelsMagenta/green bias: &plusmn;9 levelsWhite balance bracketing:&plusmn;3 levels, in single-level increments
Color Temperature Information Transmission
Provided
Type
Eye-level SLR (with fixed pentamirror)
Coverage
Vertical/Horizontal approx. 95% (TD)
Magnification
Approx. 0.85x / 23.8&deg; (with 50mm lens at infinity, -1 m-1 (dpt))
Eye Point
Approx. 19 mm (At -1m-1 from the eyepiece lens center)
Dioptric Adjustment Correction
Adjustable from approx. -3.0 to +1.0 m-1 (dpt)
Focusing Screen
Fixed
Mirror
Quick-return half mirror (transmittance: reflectance ratio of 40:60)
Viewfinder Information
1) AF information (AF points, focus confirmation light)
2) Exposure information (Shutter speed, aperture, ISO speed, AE lock, exposure level, spot metering circle, exposure warning)
3) Flash information (Flash ready, flash exposure compensation, high-speed sync, FE lock, red-eye reduction light)
4) Image information (Highlight tone priority, Monochrome shooting, maximum burst, white balance correction, SD card information)
5) Composition information (Grid, electronic level)
6) Battery check
Depth Of Field Preview
Enabled with depth-of-field preview button
Type
TTL-CT-SIR AF-dedicated CMOS sensor
AF Points
9 points (Center AF point is AF cross-type at f/5.6, Center AF point is vertical line-sensitive at f/2.8.)
AF Working Range
EV -0.5 - 18 (at 23&deg;C/73&deg;F and ISO 100, based on Canon's testing standards)
Focusing Modes
(1) AutofocusOne-Shot AFPredictive AI Servo AFAI Focus AF(2) Manual focus (MF)
AF Point Selection
(1) Manual selection
(2) Auto selection
* Automatically set (2) in Basic Zone modes and A-DEP mode.
Selected AF Point Display
Indicated by superimposed display in the viewfinder and on the LCD monitor
AF Assist Beam
(1) Intermittent firing of built-in flash
(2) Effective range: Approx. 4 m/13.1 ft at center, approx. 3.5 m/11.5 ft at periphery
* With an EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead.
* Compatible with assist-beam (intermittent firing) of 320EX, 270EX II and 270EX flashes.
Metering Modes
TTL maximum aperture metering with 63-zone metering sensorEvaluative metering (linkable to all AF points)Partial metering (center, approx. 9% of viewfinder at center)Spot metering (center, approx. 4% of viewfinder at center)Center-weighted average metering
Metering Range
EV 1.0 - EV 20.0 (at 73&deg;F/23&deg;C with EF50mm f/1.4 USM lens, ISO 100)
Exposure Control Systems
Program AE (Shiftable), Shutter-priority AE, Aperture-priority AE, Manual exposure, Automatic depth-of-field, Scene Intelligent Auto, Flash Off, Creative Auto, Programmed Image Control modes, E-TTL II autoflash program AE
ISO Speed Range
Auto, ISO 100 - 6400 (in whole-stop increments), H: 12800
Exposure Compensation
Manual: &plusmn;5 stops in 1/3- or 1/2-stop increments (AEB &plusmn;2 stops)
* Indicated up to &plusmn;3 stops in the viewfinder.
AE Lock
Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved
Manual: By AE lock button
Type
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled.
Shutter Speeds
1/4000 to 1/60 sec., X-sync at 1/200 sec.
1/4000 to 30 sec., Bulb (Total shutter speed range. Available range varies by shooting mode.)Settable in 1/3- or 1/2-stop increments.
Shutter Release
Soft-touch electromagnetic release
Self Timer
10-sec. or 2-sec. delay
Remote Control
(1) The EOS Rebel T3i has a remote control terminal for Remote Switch RS-60E3.
(2) Compatible with Remote Controller RC-6, RC-1 and RC-5.
Type
Auto pop-up, retractable, built-in flash in the pentaprism
Flash Metering System
E-TTL II autoflash
Guide Number
Approx. 13/43 (at ISO 100 in meters/feet)
Recycling Time
Approx. 3 sec.
Flash Ready Indicator
Flash-ready icon lights in viewfinder
Flash Coverage
Up to 17mm focal length (equivalent to approx. 28mm in 135 format)
FE Lock
Provided
Flash Exposure Compensation
Up to &plusmn;2 stops in 1/3- or 1/2-stop increments
Flash exposure compensation for built-in flash and Speedlite can be set with the camera.
Flash Metering
E-TTL II autoflash
&plusmn;2 stops in 1/3-stop or 1/2-stop increments
FE Lock
Provided
Drive Modes
Single, Continuous, 10-sec. self-timer/Remote control, 2-sec. self-timer, Continuous shooting after 10-sec. self-timer
Continuous Shooting Speed
Max. approx. 3.7 fps [TD] (with One-Shot AF or AI SERVO AF)
* Same as with Battery Grip BG-E8 loaded with size-AA/LR6 alkaline batteries.
Maximum Burst
JPEG (Large/Fine): approx. 34
RAW: approx. 6
RAW+JPEG (Large/Fine): approx. 3
* The number of possible shots and maximum burst apply to a 4GB card based on Canon's testing standards.
* The image file size, number of possible shots, and maximum burst will vary depending on the shooting conditions (3:2 aspect ratio, subject, memory card brand, ISO speed, Picture Style, Custom Functions, etc.).
* "F" indicates that continuous shooting is possible until the card becomes full.
Shooting Modes
Still photo shooting and video shooting
Focusing
(1) Autofocus (Same as focusing with Live View shooting)
Before shooting a movie, 1, 2, and 3 below are possible.
AF during movie shooting is possible with [AF w/ shutter button during video]. When this is set to [Enable], 1 and 2 below are possible:
A. Live mode
B. Face detection Live mode
C. Quick mode
* If 3 has been set when you start shooting a movie, it will switch to 1 automatically.
(2) Manual focusing
* Magnify the image by about 5x or 10x and focus manually.
* Magnified view not possible with digital zoom nor during movie shooting.
Metering Modes
(1) AF point-linked evaluative metering
* Used when the AF mode is Face detection Live mode and a face has been detected.
(2) Center-weighted average metering
* Used during manual focus, when the AF mode is Face detection Live mode and a face has not been detected. Also used in the Live mode and Quick mode.
* Metering range: EV 0 to EV 20 (At 23&deg;C/73&deg;F and ISO 100, with 50mm f/1.4 lens)
Metering Range
Grid Display
Two grids provided (not displayed during movie shooting):
(1) Grid 1: Pair of vertical and horizontal lines
(2) Grid 2: 5 vertical and 3 horizontal lines
Exposure Simulation
Provided
Silent Shooting
Not provided
File Format
MOV (image data: H.264; audio: Linear PCM (monaural))
* Meta information is embedded in the MOV file (no separate THM file)
File Size
Recording Size: 1920 x 1080 (Full HD), 1280 x 720 (HD), 640 x 480 (SD)* The file system limits the file size of a single movie clip to 4 GB. If the movie clip reaches 4 GB, the shooting will stop automatically. This translates to around 11 min. for 1920 x 1080 and 1280 x 720, and around 46 min. for 640 x 480.* Even if the file size of a single movie clip is within 4 GB, movie shooting will automatically terminate when the movie time reaches 29 min. 59 sec.
Frame Rates
24, 25, 30, 50, or 60 fps (30 fps during magnified view)
Focusing
Before shooting a movie, A, B, and C below are possible.
AF during movie shooting is possible with [AF w/ shutter button during video]. When this is set to [Enable], A and B below are possible:
A. Live mode
C. Quick mode
* If C has been set when you start shooting a movie, it will switch to A automatically.
(2) Manual focusing
Exposure Control
Program AE for video shooting, Manual exposure
&plusmn;3 stops in 1/3-stop increments
Type
TFT color, liquid-crystal monitor
Monitor Size
3.0 in. (Screen aspect ratio of 3:2)
Pixels
Approx. 1,040,000 dots
Coverage
Approx. 100%
Viewing Angle: 170&deg;
Brightness Control
Adjustable to one of seven brightness levels
Interface Languages
25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Hungarian, Czech, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean and Japanese)
Display Format
(1) Single image displaySingle image, basic information, detailed information, histogram display(2) Index display4-image index and 9-image index.(3) Jump display (Image jump w/ Main Dial)1/10/100 images, shooting date, by folder, movies, stills, rating
Highlight Alert
On the detailed information and histogram displays, highlight areas with no image data will blink.
Protection
Erase protection can be applied/canceled for a single image, all images in a folder, or all images in the card.
Erase
Erase single image, erase selected images, erase all images on folder, erase all images in a card, or erase only unprotected images.
Compatible Printers
PictBridge-compatible printers
Printable Images
JPEG images complying to Design rule for Camera File SystemRAW images printable.Movies cannot be printed.
DPOF
Version 1.1 compatible
Custom Functions
11 Custom Functions with 34 settings settable with the camera
Camera User Settings
Not provided
USB Terminal
Hi-Speed USB-standard mini-B terminal for personal computer communications and PictBridge.
Video Out Terminal
(1) Video OUT terminal: NTSC/PAL selectable
(2) mini-HDMI OUT terminal
Battery
Battery Pack LP-E8 x 1
* With the AC Adapter Kit ACK-E8, AC power is possible.
* With BG-E8, two battery packs (LP-E8) can be used. Or six size-AA/LR6 batteries can be used.
Battery Life
1) Camera body only:
2) With Battery Grip BG-E8:
The figures above are based on CIPA (Camera & Imaging Products Association) testing standards
Battery Check
Automatic battery level check when power is turned ON.
Battery level indicated in one of four levels on LCD monitor.
Power Saving
Power turns off after the set time of non-operation elapses
* [Auto power off] settable to 30 sec., 1 min., 2 min., 4 min., 8 min., or 15 min.
Date/Time Battery
Built-in secondary battery. When fully-charged, the date/time can be maintained for about three months.
Start-up Time
Approx. 0.1 sec. (Based on CIPA testing standards)
Dimensions (W x H x D)
Approx. 5.2 x 3.9 x 3.1 in./133.1 x 99.5 x 79.7mm
Weight
Approx. 18.2 oz. / 515g (body only)
Working Temperature Range
32-104&deg;F/0-40&deg;C
Working Humidity Range
85% or lessAll data are based on Canon's Standard Test Method. Subject to change without notice.
If a problem occurs with a non-Canon lens attached to the camera, consult the lens maker.
Canon, DIGIC and EOS Rebel are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. HDMI, the HDMI logo and High-Definition Multimedia Interface are registered trademarks or trademarks of HDMI Licensing, LLC in the United States and/or other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
