Canon Support for Refurbished EOS R5 | Canon U.S.A., Inc.
Refurbished EOS R5
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital single-lens non-reflex AF/AE camera |
Recording Media | CFexpress card
SD card
Compatible Lenses | Canon RF lens group (excluding EF, EF-S and EF-M lenses) When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses) |
Lens Mount | Canon RF mount |
Type | CMOS sensor (compatible with Dual Pixel CMOS AF) |
Effective pixels | Approx. 45.0 megapixels |
Pixel Unit | Approx. 4.40 µm square |
Total Pixels | Approx. 47.1 megapixels |
Aspect Ratio | 3:2 (Horizontal:Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Installed in front of the image sensor, non-detachable |
Dust Deletion Feature |
Recording Format | Compliant to Design rule for Camera File system 2.0 and Exif 2.3*. *Supports time difference information in Exif 2.31. |
File Size | 3:2 Aspect Ratio Large/RAW/C-RAW: 8192 x 5464 Medium: 5808 x 3872 Small 1: 4176 x 2784 Small 1: 2976 x 1984 Small 2: 2400 x 1600 1.6x (Crop)* Large/RAW/C-RAW: 5088 x 3392 Small 2: 2400 x 1600 4:3 Aspect Ratio Large: 7280 x 5464 Medium: 5152 x 3872 Small 1: 3712 x 2784 Small 2: 2112 x 1600 RAW/C-RAW: 8192 x 5464 16:9 Aspect Ratio Large: 8192 x 4608 Medium: 5808 x 3264 Small 1: 4176 x 2344 Small 2: 2400 x 1344 RAW/C-RAW: 8192 x 5464 1:1 Aspect Ratio Large: 5456 x 5456 Medium: 3872 x 3872 Small 1: 2784 x 2784 Small 2: 1600 x 1600 RAW/C-RAW: 8192 x 5464
File Numbering | The following file numbers can be set:
RAW + JPEG Simultaneous Recording / HEIF Simultaneous Recording | Simultaneous recording of any combination of RAW/C-RAW and JPEG/HEIF image-recording quality is supported. |
Color Space | Selectable between sRGB and Adobe RGB |
Picture Style |
Settings |
Auto White Balance | Option between ambience priority and white priority settings. |
Color Temperature Compensation | Blue/amber bias: ±9 levels Magenta/green bias: ±9 levels Corrected in reference to the current WB mode's color temperature. |
Type | OLED color electronic viewfinder; approx. 5.76 million dots resolution |
Coverage | Approx. 100% vertically and horizontally relative to the shooting image area (with image quality L, at approx. 23mm eyepoint). |
Magnification / Angle of View | Approx. 0.76x / Approx. 35.5 degrees (with 50mm lens at infinity, -1 m-1) |
Eye Point | Approx. 23mm (at -1 m-1 from the eyepiece lens end) |
Viewfinder Information |
Type | Dual Pixel CMOS AF |
AF Working Range | EV -6 to 20 (f/1.2 lens*, center AF point, One-Shot AF, at 73°F/23°C, ISO 100, One-Shot AF) * Except RF lenses with a Defocus Smoothing (DS) coating. |
AF Methods |
Metering Modes | Real-time metering with image sensor (384 [24x16 zone metering])
Metering Range | EV -3 - 20 (at 73°F/23°C, ISO 100) (Still Photo Shooting) |
Exposure Control Modes |
ISO Speed Range | Available ISO speeds; user-set
User-defined ISO range - still photo shooting
* Expanded ISO speeds are noted as being equivalent to these speeds. User-defined Auto ISO range - still photo shooting
ISO Auto details in still photo shooting
*1 ISO 200 when [Highlight tone priority] is set to [Enable] or [Enhanced]. |
Exposure Compensation |
AE Lock |
Type | Electronically controlled focal-plane shutter
* A shutter release sound is not generated. However, note that the sounds other than the shutter release sound (aperture, focusing lens drive sound/electronic sound, etc.) may be generated. * In electronic shutter shooting under conditions such as flash firing by other cameras or with fluores-cent lighting or other flickering light sources, a strip of light or banding due to the brightness difference may be recorded in the image. |
Shutter Speeds | When [Mechanical] or [Elec. 1st- curtain] is set: 1/8000-30 sec, bulb When [Electronic] is set: 1/8000-0.5 sec. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. delay, 2-sec. delay |
Shutter Lag Time |
E-TTL balance | Ambience priority, standard, flash priority |
Compatible E-TTL Speedlites | Canon EX- and EL-series Speedlites |
E-TTL II Flash Metering |
Flash Exposure Compensation | ±3 stops in 1/3- or 1/2-stop increments |
FE Lock | Provided |
External Flash Settings | The camera can set the following with EX series Speedlites:
Canon Log | Provided (Off / Canon Log / Canon Log 3) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Shooting Times |
*1 Time available for continuous shooting in 23°C / 73°F environment, from a cold start. If the camera is in LV mode standby before shooting or the ambient temperature is high, the shooting time may be shorter.
*2 Recording stops at 7minutes and 30seconds for high frame rate video. Indicates the time when recording can be resumed immediately.
*3 Recording is limited to 29 minutes 59 seconds. Indicates the time when recording can be resumed immediately.
Estimated Camera Recovery Time |
Estimated recovery times are indicated below. These are affected by various factors such as ambient temperature, continued camera operation and the selected shooting resolution.The time until full record time is available will vary with ambient temperature.
Video Recording Size and Frame Rates |
Estimated Cumulative Data | Canon Log: Off, HDR PQ: Off
Focusing | Dual Pixel CMOS AF |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.2-inch (screen aspect ratio of 3:2) 3.15 in./8.01cm diagonal (2.63 in./6.67cm width, 1.75 in./4.44cm height) |
Dots | Approx. 2.1 million dots |
Coverage | Approx. 100% vertically/horizontally |
Brightness Control | Manually adjustable to one of seven brightness levels |
Coating | Clear View LCD II
Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese) |
Display Format |
Highlight Alert | The white areas with no image data will blink. |
Function | The Quick Control screen is accessed by pressing the Quick Control button during still photo shooting. |
Protection |
Erase | Except protected images
Compatible Printers | Not supported |
DPOF | Compliant to DPOF Version 1.1 |
Custom Controls | Customizable Buttons
Customizable Dials
My Menu Registration |
USB Terminal | Equivalent to Hi-Speed USB (USB 3.1 Gen 2)
Video Out Terminal | HDMI micro OUT terminal Type D (Resolution switches automatically) / CEC not compatible
Microphone Input Terminal | 3.5mm diameter stereo mini jack |
Headphone Terminal | 3.5mm diameter stereo mini jack |
Battery | LP-E6NH/LP-E6N/LP-E6
Battery Check | Automatic battery check when the power switch is turned ON.
Start-up Time | Approx. 0.4 sec.
Dimensions (W x H x D) | Approx. 5.45 x 3.84 x 3.46 in. / 138 x 97.5 x 88.0mm
Weight | Approx. 1.63 lbs. / 738g (including battery, CFexpress card; without body cap) Approx. 1.43 lbs. / 650g (body only; without battery, card or body cap) |
Working Temperature Range | 32-104° F / 0-+40°C |
Working Humidity | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
