Canon Support for RF-S7.8mm F4 STM DUAL | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Focal Length | 7.8mm | ||||||||||
Maximum and Minimum Aperture | f/4.0 f/16 (1/3 stops, 1/2 stops) | ||||||||||
Lens Mount Type | Canon RF Mount; Plastic Mount | ||||||||||
Interpupillary Distance / Baseline Length (Distance between Left and Right Lens Centers) | 11.8mm | ||||||||||
Minimum Focusing Distance | 0.66 ft. (7.9 in.) / 0.15 m | ||||||||||
Maximum Magnification | 0.07x | ||||||||||
Angle of View (Diagonal) | 63° 00' | ||||||||||
Lens Construction (each lens) | 9 elements in 7 groups | ||||||||||
Special Elements (each lens) | Two UD lens elements | ||||||||||
Lens Coating | Super Spectra Coating | ||||||||||
Filter Size Diameter | 58mm screw-type filter | ||||||||||
Rear Mounted Gelatin Filter Holder | Not Supported | ||||||||||
Aperture Blades (each lens) | 7 | ||||||||||
Lens Switches | Left-right focus difference adjustment mode switch | ||||||||||
Dust/Water Resistance | Not Provided | ||||||||||
Focusing System | Gear type STM focusing | ||||||||||
Left/right focus difference adjustment | Provided, user-adjustable using the Control Ring | ||||||||||
Dual Pixel CMOS AF | Provided; Horizontal: approx 30%, Vertical: approx. 46% | ||||||||||
Focus Guide |
Full-time Manual Focusing | Both Left and Right lenses support focus guide. | ||||||||||
Control Ring | Video Mode | ||||||||||
IS Mode Selection | Left lens only supports focus guide. | ||||||||||
Optical Image Stabilization | Video Mode with L/R adjustment switch enabled | ||||||||||
Stabilization with in-body IS (EOS R7) | Both Left and Right lenses support focus guide. |
Dimensions | ø2.7" x 1.6" L |
Weight | Approx. 4.6 oz. (131g) |
Lens hood | Not Supported |
Lens Cap | E-58II (bundled) |
Dust Cap | Canon Lens Dust Cap RF (Bundled) |
Lens Case | Canon Lens Case LP1014 (sold separately) |
Extension Tubes | Not compatible |
Close-up Lenses 250D / 500D | Not compatible |
Canon RF Extender 1.4x/2x | Not compatible |
Canon Gelatin Filter Holder III/IV | Not compatible |
Rear Gelatin Filter Holder | Not compatible |
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
