Canon Support for RF20mm F1.4 L VCM | Canon U.S.A., Inc.
RF20mm F1.4 L VCM
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Software Development Kit
Focal length 20mm
Maximum and minimum aperture f/1.4 f/16
Lens mount type RF Mount (Metal Mount)
Compatible cameras Canon EOS R-series, APS-C and full-frame
Minimum focusing distance 7.9 in. (0.20m)
Maximum magnification 0.19x
Field of view, at minimum focus distance Approx. 7.2" x 4.8" (184 × 122mm)
Angle of view (diagonal) Approx. 94º
Lens construction 15 elements in 11 groups
Special elements One Super UD element, two UD elements, one BR Lens, two Aspherical elements
Lens coating Canon SSC (Super Spectra Coating); SWC (Sub-Wavelength structure coating; ASC (Air Sphere Coating); Fluorine protective coating on front element
Filter size diameter 67 mm
Aperture blades 11
Image stabilization (yaw/pitch directions) None
Focusing drive system Canon VCM (Voice Coil Motor) for primary focus drive
Full-time manual focusing Yes
(Supports MF in both ONE SHOT AF and SERVO AF, with compatible EOS R-series cameras)
Dual Pixel CMOS AF coverage (Horizontal x Vertical) EOS R, Ra, RP, R100 Approx. 88% x 100%
EOS R5, R6 Approx. 100% x100%
EOS R7, R10, R50 Approx. 100% x 100%
EOS R1, R3, R5 Mark II, R6 Mark II, R8 Approx. 100% x 100%
Control Ring Control Ring at front of lens; with clickstops
Customizable, using Customize Dials in camera menu
Clickstops removeable by Canon Factory Service, for a fee
Manual Focus ring Electronic ring system
Full-time Manual focus possible
No physical limit to ring rotational angle
AF/MF switch Provided
Iris Ring Provided
Operational for still images with EOS R1, R5 Mark II, and later EOS models
Lens Function button Provided (one button, on lens barrel)
Distance scale None
Distance scale possible in EVF or LCD screen, via Shooting Info Display in camera's red Shooting Menu
Distance Limiter switch None
Dust / Weather resistant construction Yes
Maximum outer diameter x length Approx. ø3.0 in. x 3.9 in. (ø76.5mm x 99.3mm)
Weight Approx. 18.3 oz. / 1.1 lb. / 519g
Lens hood Canon EW-73H (bundled)
Petal-type, 2-catch detachable bayonet hood attachable in reverse.
Lens cap Canon E-67II (bundled)
Dust cap Canon Lens Dust Cap RF (bundled)
Lens case Canon Lens Case LP1219 (bundled)
Extension Tubes Not compatible
Close-up Lenses 250D / 500D Not compatible
Canon RF Extender 1.4x/2x Not compatible
Canon Gelatin Filter Holder III/IV Not compatible
Rear Gelatin Filter Holder Included (accepts user-cut gel or polyester filters)
Removeable rear gel filter holder included; attaches to rear of lens
EOS System Lens Limited Warranty
The limited warranty set forth below is given by Canon U.S.A., Inc. (Canon U.S.A.) in the United States and Canon Canada Inc., in Canada (herein referred to collectively as "Canon") with respect to the Canon Binoculars and Photographic Lens Products packaged with this Limited Warranty and identified by model number on this limited warranty card (each a "Product")when purchased and used in the United States or Canada.
This Limited Warranty is only effective upon presentation of this warranty card and proof of purchase
A Product, when delivered to you in new condition in its original container, is warranted against defects in materials or workmanship as follows: for a period of one (1) year from the date of original purchase, defective parts or a defective Product returned to Canon, or its authorized service providers, and proven to be defective upon inspection, will be repaired with new or comparable rebuilt parts or exchanged for a refurbished Product, as determined by Canon or the authorized service provider n their sole discretion. Replaced parts and exchanged Products will become the property of Canon.
When returning a Product for warranty service, the shipping charges must be prepaid and the Product should be shipped in its original container, or an equivalent, properly packed to withstand the hazards of shipment and be fully insured. A copy of the warranty card and proof of purchase should be enclosed, as well as a description of the problem (including film samples, where appropriate). Repairs will be made and the Product will be returned, shipped at NO CHARGE, within the country of repair.
This warranty only covers defective materials or workmanship encountered in normal use and service of a Product and does not apply in the following cases:
(a) Loss of or damage due to abuse causing deterioration, mishandling, accident or failure to follow operating instructions.
(b) If a Product is defective as a result of leaking batteries or liquid damage.
(c) Defective materials or workmanship where the defect is due to a Product having been serviced or modified by other than Canon or a Canon authorized service provider.
(d) Malfunction resulting from the use of accessories, attachments, product supplies, parts or devices (including, without limitation, batteries, film, flash attachments and other accessories) with this Canon photographic equipment that do not conform to Canon specifications.
(e) Damage resulting during shipment. (Claim must be presented and examined by the shipper.)
(f) Damage or service resulting from modifications or alterations to a Product in any way (including any alteration or removal of its serial number or identification marks).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON OR ENTITY WITH RESPECT TO A PRODUCT SHALL BIND CANON (SOME STATES AND PROVINCES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU). CANON SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES (INCLUDING, WITHOUT LIMITATION, ANY LOSS OF FILM) CAUSED BY THE USE OR MISUSE OF, OR INABILITY TO USE, A PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. IN NO EVENT SHALL RECOVERY OF ANY KIND AGAINST CANON BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT SOLD BY CANON AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE OR MISUSE OF, OR INABILITY TO USE, THE PRODUCT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON (SOME STATES AND PROVINCES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE EXCLUSION OR LIMITATION MAY NOT APPLY TO YOU). THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT, OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY.
Canon U.S.A., Inc., One Canon Park, Melville, NY 11747
Canon Canada Inc., 8000 Mississauga Road, Brampton, Ontario, L6Y 5Z7
  Canon Sales and Service Center
  Canon USA
One Canon Park,
Melville, NY 11747,USA
Tel: (1)-800-828-4040
                Canon Canada Inc,
Brampton, Ontario, L6Y 5Z7, Canada
(1)-800-652-2666
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
