Canon Support for Speedlite 600EX II-RT | Canon U.S.A., Inc.
Filter & Sort
Download Type
<p><b>Find Software &amp; Drivers</b></p> <p>Software &amp; drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Date 05.30.16
File Size 7.49 MB
Compatible Cameras
Type-A EOS cameras (E-TTL II/E-TTL autoflash)
Type-B EOS cameras (TTL autoflash)
Guide Number
The Guide No. is approximately 49.2 ft./15m at ISO 100.
The maximum Guide No. is approximately 196.9 ft./60m at ISO 100 and 200mm flash coverage.
When the extendable wide panel is pulled out, the flash coverage is 14mm.
Number of Flashes
Approx. 100-700 flashes.
* Nominal min. time when using 1900mm Ah type AA/HR6 Ni-MH batteries.
* Based on Canon Testing Standards.
Recycling Time
Normal flash: 0.1-5.5 sec.
Quick flash: 0.1-3.3 sec.
Flash Range
Effective flash range with EF 50mm f/1.4 lens at ISO 100
  1. Normal Flash:
    Approx. 1.6-91.2 ft./0.5-27.8m
  2. Quick Flash (at Guide No. 68.2 ft./20.8m):
    Approx. 1.6-48.6 ft./0.5-14.8m
  3. High-speed Sync (at 1/250 sec. shutter speed):
    Approx. 1.6-48.2 ft./0.5-14.7m
AF Assist Beam
System:
Infrared AF-assist beam
Compatible AF System:
TTL second image formation phase-difference AF
Supporting 1-65 AF points (28mm or longer focal length)
  • Phase-difference AF during viewfinder shooting
  • Quick mode during Live View shooting or movie shooting
Effective Range (Approx.):
At center: 2.0-32.8 ft./0.6-10.0m
At periphery: 2.0-16.4 ft./0.6-5.0m
Custom Functions
15 Functions
6 Functions
Power Source
Four AA-size/LR6 alkaline or AA/HR6 Ni-MH batteries
External Power Source
Compatible (Compact Battery Pack CP-E4N recommended)
Dimensions
Approx. 3.10 x 5.64 x 4.83 in./78.7 x 143.2 x 122.7mm
Weight
Approx. 15.34 oz./435g
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
