Canon Support for VIXIA HF M52 | Canon U.S.A., Inc.
VIXIA HF M52
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Wireless Connection
File Transfer
File Upload
Software Installation
Glossary
SELECT ERROR CODE
Standard Definition or High Definition | High Definition |
Television System | NTSC |
Video Recording system | AVCHD/MPEG-4 |
Image Sensor | 1/3-inch HD CMOS PRO, RGB Primary Color Filter |
Total Pixels | Approx. 2.37 Megapixels |
Effective Pixels | Video: Approx. 2.07 Megapixels (1920 x 1080) Photo:Approx. 2.07 Megapixels (1920 x 1080) |
Maximum recording Time | 32 GB Internal Flash Drive in AVCHD: LP (5Mbps): 12 hours 15 minutes SP (7Mbps): 9 hours 35 minutes XP+ (12Mbps): 5 hours 45 minutes FXP (17Mbps) - Allows 1920 x 1080 recording: 4 hours 10 minutes MXP (24Mbps) - Allows 1920 x 1080 recording: 2 hours 55 minutes 32 GB Internal Flash Drive in MP4: 4Mbps: 16 hours 55 minutes 9Mbps: 7 hours 40 minutes |
Lens | Zoom Ratio: 10x Optical/200x Digital* Focal Length: 6.1-61mm 35mm Film Equivalent: Optical Zoom: 43.4-436mm (in both movies and photos) Zoom Speed: Variable / 3 Fixed Zoom Speeds Max F/Stop: f/1.8-3.0 |
Focusing System | TTL (Through The Lens) + Instant AF |
Manual Exposure | Yes |
Programmed AE | Auto, Manual*1, Cinema Mode*2 *1 P, Tv, Av, SCN*3 *2 P, Tv, Av *3 Portrait, Sports, Snow, Beach, Sunset, Night, Low Light, Spotlight, Fireworks, Underwater, Surface |
Max Shutter Speed | Movie: 1/2000 sec. Still Image: 1/500 sec. |
Minimum Focusing Distance | When tele macro is in effect: 10 mm to ∞ (wide end), 1 m to ∞ (intermediate zooming range), 40 cm to ∞ (tele end) When tele macro is not in effect: 10 mm to ∞ (wide end), 1 m to ∞ (entire zooming range) All figures given are for the distance from the lens front. |
White Balance | Auto, Daylight, Shade, Cloudy, Tungsten, Fluorescent H, Fluorescent |
Minimum Illumination | NTSC: 1.2 lx 0.1 lx in Low Light Mode (shutter speed 1/2 sec.) |
Image Stabilization | Optical System (Lens-shift system) Intelligent IS in Auto mode: - Dynamic IS (default) - Powered IS - Macro IS - Tripod Mode IS Modes other than Intelligent IS; Dynamic IS and Powered IS settings can be made manually in Manual/Cinema Mode: - Standard IS - IS Off |
Filter Diameter | 43mm P0.75 |
Viewfinder | Not Available |
LCD Screen | 3.0-inch Widescreen Color Touch Panel LCD (Approx. 230,000 dots) |
Recording Media | Built-in 32 GB memory and 1 additional SD/SDHC/SDXC memory card slot** |
USB Terminal | mini-AB: Hi-Speed USB supported |
Video Terminal | Composite (output) |
Audio | AVCHD: Dolby Digital AC3 (2 Channel) MP4: MPEG-2 AAC-LC (2 Channel) Sampling Frequency: 48 KHz |
Accessory Shoe | Mini Advanced Accessory shoe available However, only the video light function is provided by the VFL-2 video light flash (the Flash function has no effect). |
Supplied Video Editing Software | Video Browser Editing Disc ImageBrowser Disc Network Utility Disc |
HDMI Terminal | Available; Mini connector, CEC, x.v. Color supported |
Microphone Terminal | 3.5 mm dia. stereo mini-jack |
AV Mini Terminal/Headphone Terminal | 3.5 mm dia. 4 pole mini-jack (video/audio output only) |
Operating Temperature range | 23° to 113° F, 60% relative humidity32° to 104° F, 85% relative humidity (performance) |
Dimensions | (W x H x D) 2.7 x 2.5 x 4.8 in / 68 x 64 x 121 mm (Not including the grip belt) |
Weight (not including battery pack and memory card) | Approx. 12.3 oz. (350g) |
Weight | Approx. 10.9 oz. / 310g (Not including grip belt) Approx. 12.9 oz. / 365g (Including BP-718, memory card and Grip Belt) |
CANON DIGITAL VIDEO EQUIPMENT LIMITED WARRANTY
FOR THE UNITED STATES
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to Canon Consumer Digital Video Equipment (the 'Equipment') purchased in the United States. This limited warranty is only effective upon presentation of your Bill of Sale or other proof of purchase. The Equipment is warranted under normal, non-commercial, personal use, against defective materials or workmanship as follows: Parts: Defective parts will be exchanged for new parts or comparable rebuilt parts for a period of ONE YEAR from the date of original purchase, except for a defective Video Head, which will be exchanged for a period of three months from the date of purchase. Labor: For a period of ONE YEAR from the date of original purchase, labor will be provided free of charge by our factory service centers or designated service facilities located in the United States. When returning Equipment under this warranty, you must pre-pay the shipping charges, and you must enclose the Bill of Sale or other proof of purchase with a complete explanation of the problem. During the ONE-YEAR warranty period, repairs will be made and the Equipment will be return-shipped to you free of charge. For repairs after the warranty period is over, you will be given an estimate of the cost of repair and an opportunity to approve or disapprove of the repair expense before it is incurred. If you approve, repairs will be made and the Equipment will be return-shipped to you. (shipping charges apply). If you disapprove, we will return-ship the equipment at no charge to you.
Canon brand peripheral equipment and software which may be distributed with, or factory loaded on, the Equipment, are sold 'AS IS' without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose. The sole warranty with respect to such non-Canon brand items is given by the manufacturer or producer thereof. If the Equipment contains a hard disk drive, Canon USA recommends that data stored on that drive be duplicated or backed up to prevent its loss in the event of failure or other malfunction of such drive.
Canon USA shall have no responsibility under this limited warranty for use of the Equipment in conjunction with incompatible peripheral equipment and incompatible software. In order to obtain warranty service, contact the authorized Canon retail dealer from whom you purchased the Equipment or call the CANON INFORMATION CENTER AT 1—800-OK-CANON). You will be directed to the nearest service facility for your Equipment.
- Loss or damage to the Equipment due to abuse, mishandling, accident, improper maintenance, or failure to follow operating instructions;
- If the Equipment is defective as a result of leaking batteries, sand, dirt or water damage;
- If defects or damages are caused by the use of unauthorized parts or by service other than by Canon USA's factory service centers or authorized service facilities;
This Limited Warranty does not cover cabinet (exterior finish), video cassette tape, head cleanings, nor does it apply to Equipment purchased outside the United States. This warranty does not cover units sold to rental firms, military operations, hotels, schools, hospitals or for other commercial, industrial, or institutional applications. These uses are covered only by such specific warranty as Canon may issue with such sales. This Limited Warranty does not apply to accessories or consumables for the Equipment, which are sold “AS IS”, without warranty of any kind by Canon USA. Please retain this warranty card and your Bill of Sale as a permanent record of your purchase. This card is most important in order to be sure you are contacted right away should there be a safety inspection, modification or product recall under applicable laws or regulations.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLIES TO THIS EQUIPMENT AFTER THE APPLICABLE PERIOD OF EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU). CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, INCLUDING WITHOUT LIMITATION, LOSS OR CORRUPTION OF DATA STORED ON THE EQUIPMENT’S HARD DRIVE, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE EQUIPMENT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA BE GREATER THAN THE PURCHASE PRICE OF THE EQUIPMENT SOLD BY CANON USA AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE, MISUSE OR INABILITY TO USE THE EQUIPMENT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON USA. (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU).THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from state to state. CANON U.S.A., INC
