Canon Support for Wireless File Transmitter WFT-R10A | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Type | Wireless / wired LAN accessory Wireless File Transmitter (WFT) |
Compatible Cameras | EOS R5 |
EOS Utility | EOS Utility-based control of cameras over a network |
Linked Shooting | Max. 10 receiver cameras Transmission Range: Approx. 492 ft. / 150m from the sender camera (when signal strength is favorable) WFT Server Start: Possible at manual connection with receiver camera |
Transmission Range | Using an access point: Max. approx. 492 ft./150m Linked shooting: Max. approx. 164 ft. / 50m Smartphone connection: Not supported * With no obstructions between the transmitting and receiving antennas and no radio interference |
Charging / Power Supply | EOS R5+ WFT-R10A+ USB Power Adapter PD-E1 (Charging is not possible with WFT-R10A+ PD-E1) |
W x H x D | Approx. 5.64 x 4.50 x 3.19 in. / 143.2 x 114.4 x 81.0mm |
Ounces/grams | Approx. 13.93 oz. / 395g (Including battery magazine, and excluding batteries) |
Temperature | 32°F -104°F/0°C -40°C |
Humidity | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
