Canon Support for ZOOM Compact Telephoto Monocular | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Monocular telephoto compact digital camera |
Imaging Processor | DIGIC 8 |
Type | CMOS sensor, 1/3-inch type^ (sensor aspect ratio: 4:3) ^ The center portion of a 1/2.3-inch type CMOS sensor is used. |
Pixels | Effective Pixels: 12.1 Megapixels Total Pixels: Approx. 12.1 Megapixels * Rounded to the nearest 100,000. |
Self-cleaning Sensor | Not provided. |
Focal Length | Optical 4x lens that switches between two focal lengths. Telephoto side: approx. 100mm 35mm equivalent (13.8mm) Super-tele side: approx. 400mm 35mm equivalent (55.5mm) Digital Zoom: approx. 800mm 35mm equivalent (2x digital) * Focal length can be checked through the viewfinder. |
Lens Configuration | 11 elements in 8 groups * Aspherical lens, extra-low dispersion lens not included * Front lens surface has a cover glass (Not included in the lens construction) |
Digital Zoom | Enables approx. 2x magnification |
Step Zoom | Switches among focal lengths in the following order, as controlled with the (ZOOM) button: Equivalent to approx. 100mm (optical) -> equivalent to approx. 400mm (optical) -> equivalent to approx 800mm (digital). |
Telephoto Magnification |
Focusing Range | Wide-angle: Approx. 3.28 ft. - Infinity / 1m - Infinity. Telephoto: Approx. 14.76 ft. - Infinity / 4.5m - Infinity. * Macro functionality not provided. Measure from the tip of the lens barrel. |
Aperture Number | Wide-angle side: f/5.6 Telephoto side: f/6.3 * No aperture control. |
Autofocus System | TTL Autofocus |
AF Method | Face+Tracking 1-point AF * Fixed at the center of the screen for 1-point AF. |
Lens shift system | * 4-axis correction (Yaw/Pitch/X/Y) * Image stabilization cannot be deactivated. |
Powered IS | Supported. |
Dual Sensing IS | Supported. |
Viewfinder | Electronic Viewfinder (Approx. 2.36 million dots) |
Screen Size | 0.39 inch-type |
Eyepoint | Approx. 22mm (at -1m-1 from eyepiece lens end) |
Dioptric Adjustment | Approx. -3 to +1m-1(dpf) |
LCD Pixels | Approx. 1.04 million dots |
LCD Coverage | Approx. 100% |
Recording Media Type | microSD / microSDHC /microSDXC memory card * SD speed class compatible. * UHS speed class compatible. * UHS-I compatible. |
Card Access Indicator | Lamp lights up / blinks. |
Read Error Warning | The error warnings are displayed in the viewfinder, and the shutter release locks. |
Card Formatting | Low-level formatting. * Logical formatting not available. |
Image Recording Format | Compliant to Design rule for Camera File system 2.0 and Exif. 2.31 * Supports time difference information. |
Image Type / Extension |
* RAW / C-RAW / HEIF shooting are not supported. |
Image Quality /Recorded Pixels |
* Image quality adjustment not available. * Lower image quality when equivalent to approx. 800mm, due to digital cropping. |
Aspect Ratio | Fixed at 4:3 and not adjustable. |
Image File Size / Number of Possible Shots / Maximum Burst |
* Number of shots available and maximum burst in high-speed continuous shooting driving mode. * Number of shots available and maximum burst apply to a 64 GB card conforming to Canon testing standards. * File size, number of possible shots, and maximum burst vary depending on shooting conditions (including subject and memory card brand). |
Exposure Composition | Supported +/- 3 stops |
Drive Mode | Single Shooting, Continuous Shooting |
Movie Recording Format |
Recording Size / Compression Method | Full HD: 1920x1080 / Standard (IPB) * Movie recording size adjustment not available. |
Frame Rate | When set to NTSC: 29.97 / 23.98 fps |
Movie Bit Rate | Approx. 30 Mbps * Video only, not including audio. |
File Size | Approx. 217 MB/min. |
Maximum Recording Time | 9 min. 59 sec. * Movie recording is not possible during Wi-Fi connection |
Total Cumulative Recording Time Available |
Maximum File Size |
Card Performance Requirements (movie recording) | Micro SD card with SD Speed Class 6 or higher |
Color Sampling Method | YCbCr 4:2:0 (8 bit) |
Video Range | Full range (0-255) |
Recording Microphone | Built-in stereo microphone * External microphone IN terminal not provided. |
HDMI Output | Not supported * HDMI OUT terminal not provided. |
Mode | Auto ( White balance presets not provided.) |
White Balance Shift | Not supported. |
White Balance Bracketing | Not supported. |
Built-in Flash | Not provided. |
External Flash | Not supported. |
Playback Methods | Playback in the camera's electronic viewfinder. Playback on a smartphone (requires Camera Connect app (Remote control from app is not available for video)). |
Display Conditions | Still photos: Images saved in Design rule for Camera File system format. Movies: Movie files in MP4 format * May not support playback of images from cameras other than PowerShot Zoom. |
Playback Functions |
* slow motion, editing out first and last scenes, and volume adjustment are not available. |
Shooting Information Display | Basic information display * Display without information and detailed information display are not available. |
Erasing Images | Select and erase images / All images on card. |
Print Order (DPOF) | Not supported. |
Direct Printing (PictBridge) | Wireless connections: Not suppored Wired Connections: Not supported |
Display Device | Shown in the electornic viewfinder |
Description | Shooting settings Playback settings Wireless communication settings Function settings |
Display Languages | 31 languages are available. English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukrainian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turksih, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean, Malay, Indonesian, Persian, Hewbrew, and Japanese. |
Firmware Updates | Provided. * Firmware can be updated using Camera Connect (transferring firmware from Camera Connect to the camera). |
Terminal Type | USB Type-C |
Applications | For charging the built-in battery and supplying the power to the camera. * Recognized as a USB device when connected to a computer, and images on the memory card in the PowerShot Zoom camera can be browsed and imported (transfer speed equivalent to Hi-Speed USB (USB 2.0)). |
HDMI OUT Terminal | Not Provided. |
Time Zone Setting (World Time) | Honolulu, Anchorage, Los Angeles, Denver, Chicago, New York, Caracas, Newfoundland, Sao Paulo, Fernando de Noronha, Azores, London, Paris, Cairo, Moscow, Tehran, Dubai, Kabul, Karachi, Delhi, Kathmandu, Dacca, Yangon, Bangkok, Hong Kong, Tokyo/Seoul, Adelaide, Sydney, Solomon Islands, Wellington, Chatham Islands, Samoa. |
Time Difference Setting | Provided (15 minute increments). |
Date / Time Back-up Battery | Same as battery that powers the camera. |
Charging / Powering Specifications | Built-in rechargeable lithium-ion battery. Rated Voltage: 3.6 V Capacity: 800 mAh |
Power Source |
* During Wi-Fi connection, excluding remote shooting. * To avoid overheating, shooting may stop sooner when connected to a power supply during shooting. |
Compatible Device | Commercially available USB Type-C devices that meet the specification requirements in charging /powering section. USB Power Adapter PD-E1 (Sold seperately). Additional Third-Party Power Supplies*: Anker PowerPort Atom PD1 (Charging adapter) Anker PowerPort III Nano 20W * Canon makes no representations or warranties with respect to any third party accessory or product mentioned. |
Charging Temperature | Approx. 41-104°F / 5-40°C |
Charging / Power Supply Display |
Charging Time |
* To fully recharge a completely depleted battery (unless over-discharge; details conform to Canon testing standards). * Charging time varies depending on remaining battery level and ambient temperature. * For safety, charging takes longer in colder environments (41-50°F / 5-10°C). * Charging time when connected to devices other than PD-E1 varies by device and is beyond the scope of this technical information. |
Number of Shots Available | Approx. 150 shots * Based on CIPA standards, at 73°F / 23°C |
Movie Recording | Approx. 1 hr. 10 min.. * With a fully charged battery, at room temperatue 73°F / 23°C |
Playback Time | Approx 2 hrs. * With a fully charged battery, at room temperatue 73°F / 23°C |
Start-up Time | Approx. 0.7 sec. * Based on CIPA testing standards. |
Power-saving Functions |
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | Approx. 1.31 x 2.00 x 4.06 in. / 33.4 x 50.8 x 103.2mm |
Weight | Approx. 5.12 oz. / 145g (including memory card) Approx. 5.08 oz. / 144g (camera body only) |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
